| | Sub problem I am trying to put all of my existing vbs into a sub. I need an exit point in my script if a certain parameter is not met. But, when I do this, my code will not execute. Sub ProfileRestore Code here End Sub However, if I remove the lines (Sub ProfileRestore & End Sub) then all of my code executes perfectly. But, I need to put my code into a sub because i need an exit statement if a certain parameter is not met. I cannot do that w/o a sub. This was as simple as pie in VB6 but not so straight forward in vbs. Any reason why nothing happens? James |
| | Re: Sub problem Never mind...found it WScript.Quit [exitcode] James "James" <dontemailme@xxxxxx> wrote in message news:%23UvA43bGKHA.4436@xxxxxx Quote: >I am trying to put all of my existing vbs into a sub. I need an exit point >in my script if a certain parameter is not met. But, when I do this, my >code will not execute. > > Sub ProfileRestore > > Code here > > End Sub > > However, if I remove the lines (Sub ProfileRestore & End Sub) then all of > my code executes perfectly. But, I need to put my code into a sub because > i need an exit statement if a certain parameter is not met. I cannot do > that w/o a sub. This was as simple as pie in VB6 but not so straight > forward in vbs. Any reason why nothing happens? > > James > |
| | Re: Sub problem I think you found how to make your code work the way you want, but not the reasone adding Sub and End Sub statements caused "But, when I do this, my code will not execute". In a .VBS file, all statements are part of the main program unless they are enclosed within a Sub/End Sub or Function/End Function pair of statements. Here is a short example of poor programming techniques: Sub S1 MsgBox "S1 message only occurs if S1 is called." End Sub MsgBox "Line 1 of main has executed." Function F1 MsgBox "F1 message only occures if F1 is called." End function MsgBox "Line 2 of main has executed." S1 F1 -Paul Randall "James" <dontemailme@xxxxxx> wrote in message news:eJtBx7bGKHA.3392@xxxxxx Quote: > Never mind...found it > > WScript.Quit [exitcode] > > James > > "James" <dontemailme@xxxxxx> wrote in message > news:%23UvA43bGKHA.4436@xxxxxx Quote: >>I am trying to put all of my existing vbs into a sub. I need an exit >>point in my script if a certain parameter is not met. But, when I do >>this, my code will not execute. >> >> Sub ProfileRestore >> >> Code here >> >> End Sub >> >> However, if I remove the lines (Sub ProfileRestore & End Sub) then all of >> my code executes perfectly. But, I need to put my code into a sub >> because i need an exit statement if a certain parameter is not met. I >> cannot do that w/o a sub. This was as simple as pie in VB6 but not so >> straight forward in vbs. Any reason why nothing happens? >> >> James >> > |
| | Re: Sub problem I was looking for some comments on my script anyway so maybe you or others can offer up some advice for improvements... You will notice where I used WScript.Quit [exitcode]. My original plan was to use Sub RestoreProfile() then and end sub and then just use and exit sub where I put WScript.Quit [exitcode]. But like I said the script just did nothing when I tried it. That has never happend to me using VB6...but anyway... Set objNetwork = CreateObject("Wscript.Network") Set objSHApp = CreateObject("Shell.Application") Set WshShell = WScript.CreateObject("WScript.Shell") Set filesys=CreateObject("Scripting.FileSystemObject") Const FOF_SIMPLEPROGRESS = 256 '(&H100) Const HKEY_CURRENT_USER = &H80000001 'EnumValues Method of the StdRegProv Class (change as needed) 'HKEY_CLASSES_ROOT = &H80000000 'HKEY_CURRENT_USER = &H80000001 'HKEY_LOCAL_MACHINE = &H80000002 'HKEY_USERS = &H80000003 'HKEY_CURRENT_CONFIG = &H80000004 'HKEY_DYN_DATA = &H80000005 'Check if ProfileBackup Folder exists on G:\ If Not filesys.FolderExists("g:\ProfileBackup") Then msgbox "Please Perform a Backup First..." WScript.Quit [exitcode] End If 'Set registry strings strComputer = "." Set objReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer & "\root\default:StdRegProv") strKeyPath = "Control Panel\Desktop" strKeyName = "Wallpaper" strKeyValue = "C:\WINDOWS\Web\Wallpaper\Bliss.bmp" 'Return User Name strUserName = objNetwork.UserName If filesys.FolderExists("c:\documents and settings\" & strUserName & ".KROLL")Then strUserName = objNetwork.UserName & ".KROLL" Else strUserName = objNetwork.UserName End if 'Set the source path strings strSrcDesktop = "g:\ProfileBackup\Desktop\*.*" strSrcFavs = "g:\ProfileBackup\Favorites\*.*" strSrcMyDocs = "g:\ProfileBackup\My Documents\*.*" strSrcPsiData = "g:\ProfileBackup\PsiData\*.*" strSrcEmailSig = "g:\ProfileBackup\Signatures\*.*" strSrcWallpaper = "g:\ProfileBackup\Wallpaper\*.*" strSrcBliss = "h:\VbScripts\Bliss.bmp" 'Set the destination path strings strDestDesktop = "c:\documents and settings\" & strUserName & "\Desktop\" strDestFavs = "c:\documents and settings\" & strUserName & "\Favorites\" strDestMyDocs = "c:\documents and settings\" & strUserName & "\My Documents\" strDestPsiData = "c:\documents and settings\" & strUserName & "\PsiData\" strDestEmailSig = "c:\documents and settings\" & strUserName & "\Application Data\Microsoft\Signatures\" strDestWallpaper = "C:\WINDOWS\Web\Wallpaper\" ' Using shell.application to copy since faster and displays status/progress 'Restore Wallpaper objSHApp.Namespace(strDestWallpaper).CopyHere strSrcWallpaper objSHApp.Namespace(strDestWallpaper).CopyHere strSrcBliss 'Restore User Desktop objSHApp.Namespace(strDestDesktop).CopyHere strSrcDesktop 'Restore User Favorites objSHApp.Namespace(strDestFavs).CopyHere strSrcFavs 'Restore User My Documents objSHApp.Namespace(strDestMyDocs).CopyHere strSrcMyDocs 'Restore User PsiData If Not filesys.FolderExists (strDestPsiData) Then filesys.CreateFolder (strDestPsiData) objSHApp.Namespace(strDestPsiData).CopyHere strSrcPsiData End If 'Restore User Email Signatures If Not filesys.FolderExists (strDestEmailSig) Then filesys.CreateFolder (strDestEmailSig) objSHApp.Namespace(strDestEmailSig).CopyHere strSrcEmailSig End If ' Set registry value for wallpaper Return = objReg.SetStringValue(HKEY_CURRENT_USER,strKeyPath,strKeyName,strKeyValue) If (Return <> 0) And (Err.Number <> 0) Then 'Wscript.Echo Err.Number End If Set objSHApp = nothing BtnPress = WshShell.Popup("Profile Restore Successfully ",10, "Progress", 0 + 64) James "Paul Randall" <paulr901@xxxxxx> wrote in message news:uYL5YHdGKHA.4620@xxxxxx Quote: >I think you found how to make your code work the way you want, but not the >reasone adding Sub and End Sub statements caused "But, when I do this, my >code will not execute". > > In a .VBS file, all statements are part of the main program unless they > are enclosed within a Sub/End Sub or Function/End Function pair of > statements. Here is a short example of poor programming techniques: > > Sub S1 > MsgBox "S1 message only occurs if S1 is called." > End Sub > MsgBox "Line 1 of main has executed." > Function F1 > MsgBox "F1 message only occures if F1 is called." > End function > MsgBox "Line 2 of main has executed." > S1 > F1 > > -Paul Randall > > "James" <dontemailme@xxxxxx> wrote in message > news:eJtBx7bGKHA.3392@xxxxxx Quote: >> Never mind...found it >> >> WScript.Quit [exitcode] >> >> James >> >> "James" <dontemailme@xxxxxx> wrote in message >> news:%23UvA43bGKHA.4436@xxxxxx Quote: >>>I am trying to put all of my existing vbs into a sub. I need an exit >>>point in my script if a certain parameter is not met. But, when I do >>>this, my code will not execute. >>> >>> Sub ProfileRestore >>> >>> Code here >>> >>> End Sub >>> >>> However, if I remove the lines (Sub ProfileRestore & End Sub) then all >>> of my code executes perfectly. But, I need to put my code into a sub >>> because i need an exit statement if a certain parameter is not met. I >>> cannot do that w/o a sub. This was as simple as pie in VB6 but not so >>> straight forward in vbs. Any reason why nothing happens? >>> >>> James >>> >> > |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
