| | Determine when a process starts and stops Hi, I would like to write a script that waits for a process to start, starts counting and then record when it stops. So far I have this. It works if I start it after I start the process. I need it to lurk until the process starts: Function isRunning(process) WriteToLog "isRunning", "Looking for process=" & process Set colProcessList = oWMIService.ExecQuery("Select * from Win32_Process Where Name = """ & process & """" ) isRunning = colProcessList.Count End Function Sub WriteToLog(strProg, strData) strCurrentTime = Now() oLogFile.WriteLine(Now() & " | " & strProg & " | " & strData) End Sub Const wbemFlagReturnImmediately = &h10 Const wbemFlagForwardOnly = &h20 Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 Const HKEY_LOCAL_MACHINE = &H80000002 Const HKLM = &H80000002 Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}! \root\cimv2") Set oFSO = CreateObject("Scripting.FileSystemObject") Set oLogFile = oFSO.OpenTextFile("c:\temp\ocsetup.txt", ForWriting, True) If isRunning("ocsetup.exe") Then C = 666 Do Until C = 0 C = isRunning("ocsetup.exe") WScript.Echo "." WriteToLog "main","Runing ocsetup.exe" WScript.Sleep 1000 Loop WriteToLog "main","Finished Runing ocsetup.exe" End If |
| | Re: Determine when a process starts and stops "OldDog" <mikef2691@xxxxxx> wrote in message news:3df93d1b-679d-4e0b-9f62-e2b80cfa1f40@xxxxxx Quote: > Hi, > > I would like to write a script that waits for a process to start, > starts counting and then record when it stops. > > So far I have this. It works if I start it after I start the process. > I need it to lurk until the process starts: > > Function isRunning(process) > WriteToLog "isRunning", "Looking for process=" & process > Set colProcessList = oWMIService.ExecQuery("Select * from > Win32_Process Where Name = """ & process & """" ) > isRunning = colProcessList.Count > End Function > > Sub WriteToLog(strProg, strData) > strCurrentTime = Now() > oLogFile.WriteLine(Now() & " | " & strProg & " | " & strData) > End Sub > > Const wbemFlagReturnImmediately = &h10 > Const wbemFlagForwardOnly = &h20 > Const ForReading = 1 > Const ForWriting = 2 > Const ForAppending = 8 > Const HKEY_LOCAL_MACHINE = &H80000002 > Const HKLM = &H80000002 > > Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}! > \root\cimv2") > Set oFSO = CreateObject("Scripting.FileSystemObject") > Set oLogFile = oFSO.OpenTextFile("c:\temp\ocsetup.txt", ForWriting, > True) > > If isRunning("ocsetup.exe") Then > C = 666 > Do Until C = 0 > C = isRunning("ocsetup.exe") > WScript.Echo "." > WriteToLog "main","Runing ocsetup.exe" > WScript.Sleep 1000 > Loop > WriteToLog "main","Finished Runing ocsetup.exe" > End If WMI query will cause a spike in processor loading each time it runs. To avoid this spike you could use the code below. It is based on an idea by the Microsoft Scripting Guy. iPoll = 5 'Time in seconds between polls sProcess = "notepad" 'Name of application to be monitored Set oWMIService = GetObject("winmgmts:\\.\root\cimv2") Set oWshShell = CreateObject("WScript.Shell") Set cProcesses = oWMIService. _ ExecNotificationQuery("select * from __instanceCreationEvent " _ & " within " & iPoll & " where TargetInstance isa 'Win32_Process'") Do Set oProcess = cProcesses.NextEvent If InStr(oProcess.TargetInstance.CommandLine, sProcess) > 0 _ Then WScript.Echo Date, Time, "Process " & sProcess & ".exe was started." Loop You would need to run two VB Scripts at the same time: One to monitor the launch of your program, the other for shutting it down. Just replace the string "Creation" with "Deletion". |
| | Re: Determine when a process starts and stops On Aug 13, 4:22*pm, OldDog <mikef2...@xxxxxx> wrote: Quote: > Hi, > > *I would like to write a script that waits for a process to start, > starts counting and then record when it stops. > > So far I have this. It works if I start it after I start the process. > I need it to lurk until the process starts: > > Function isRunning(process) > WriteToLog "isRunning", "Looking for process=" & process > Set colProcessList = oWMIService.ExecQuery("Select * from > Win32_Process Where Name = """ & process & """" ) > isRunning = colProcessList.Count > End Function > > Sub WriteToLog(strProg, strData) > * * * * strCurrentTime = Now() > * * * * oLogFile.WriteLine(Now() & " | " & strProg & " | " & strData) > End Sub > > Const wbemFlagReturnImmediately = &h10 > Const wbemFlagForwardOnly = &h20 > Const ForReading = 1 > Const ForWriting = 2 > Const ForAppending = 8 > Const HKEY_LOCAL_MACHINE = &H80000002 > Const HKLM = &H80000002 > > Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}! > \root\cimv2") > Set oFSO = CreateObject("Scripting.FileSystemObject") > Set oLogFile = oFSO.OpenTextFile("c:\temp\ocsetup.txt", ForWriting, > True) > > If isRunning("ocsetup.exe") Then > * * * * C = 666 > * * * * Do Until C = 0 > * * * * * * * * C = isRunning("ocsetup.exe") > * * * * * * * * WScript.Echo "." > * * * * * * * * WriteToLog "main","Runing ocsetup.exe" > * * * * * * * * WScript.Sleep 1000 > * * * * Loop > * * * * WriteToLog "main","Finished Runing ocsetup.exe" > End If I made the main part of the script a Sub called TimeIt and then got it to call itself until the processes started. Sub TimeIt Quote: > If isRunning("ocsetup.exe") Then > C = 666 > Do Until C = 0 > C = isRunning("ocsetup.exe") > WScript.Echo "." > WriteToLog "main","Runing ocsetup.exe" > WScript.Sleep 1000 > Loop > WriteToLog "main","Finished Runing ocsetup.exe" WScript.Sleep 1000 ' Wait a second and try again TimeIt Quote: > End If |
| | Re: Determine when a process starts and stops "OldDog" <mikef2691@xxxxxx> wrote in message news:30565ffc-5b0c-4ca1-be74-56c910fa36b0@xxxxxx Quote: > On Aug 13, 4:22 pm, OldDog <mikef2...@xxxxxx> wrote: Quote: >> Hi, >> >> I would like to write a script that waits for a process to start, >> starts counting and then record when it stops. >> >> So far I have this. It works if I start it after I start the process. >> I need it to lurk until the process starts: >> >> Function isRunning(process) >> WriteToLog "isRunning", "Looking for process=" & process >> Set colProcessList = oWMIService.ExecQuery("Select * from >> Win32_Process Where Name = """ & process & """" ) >> isRunning = colProcessList.Count >> End Function >> >> Sub WriteToLog(strProg, strData) >> strCurrentTime = Now() >> oLogFile.WriteLine(Now() & " | " & strProg & " | " & strData) >> End Sub >> >> Const wbemFlagReturnImmediately = &h10 >> Const wbemFlagForwardOnly = &h20 >> Const ForReading = 1 >> Const ForWriting = 2 >> Const ForAppending = 8 >> Const HKEY_LOCAL_MACHINE = &H80000002 >> Const HKLM = &H80000002 >> >> Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}! >> \root\cimv2") >> Set oFSO = CreateObject("Scripting.FileSystemObject") >> Set oLogFile = oFSO.OpenTextFile("c:\temp\ocsetup.txt", ForWriting, >> True) >> >> If isRunning("ocsetup.exe") Then >> C = 666 >> Do Until C = 0 >> C = isRunning("ocsetup.exe") >> WScript.Echo "." >> WriteToLog "main","Runing ocsetup.exe" >> WScript.Sleep 1000 >> Loop >> WriteToLog "main","Finished Runing ocsetup.exe" >> End If > I found a way to get it to lurk: > I made the main part of the script a Sub called TimeIt and then got it > to call itself until the processes started. > > Sub TimeIt Quote: >> If isRunning("ocsetup.exe") Then >> C = 666 >> Do Until C = 0 >> C = isRunning("ocsetup.exe") >> WScript.Echo "." >> WriteToLog "main","Runing ocsetup.exe" >> WScript.Sleep 1000 >> Loop >> WriteToLog "main","Finished Runing ocsetup.exe" > WScript.Sleep 1000 ' Wait a second and try again > TimeIt Quote: >> End If problems. But this isn't one of them. Each time a sub calls itself, resources are allocated. Sure they are released in turn each time the sub exits, but there needs to be enough resources to allocate. I just ran the very simple script shown below and got an "out of memory" error at just over 1700 recursive calls. count = 0 Call recur sub recur count = count + 1 WScript.Echo count Call recur End Sub In general, there needs to be some control over the depth of the recursion. In this case the control is an external event. If it takes longer than about 28 minutes for the ocsetup process to start running, I'm guessing your script will error out. I'd suggest a non-recursive approach such as: do while not isRunning("ocsetup.exe") WScript.Sleep 1000 ' Wait a second and try again loop do while isRunning("ocsetup.exe") WScript.Echo "." WriteToLog "main","Running ocsetup.exe" WScript.Sleep 1000 ' Wait a second and try again loop WriteToLog "main","Finished Runing ocsetup.exe" This could run for months waiting for ocsetup.exe to start running without forcing an "out of memory" error. /Al |
| | Re: Determine when a process starts and stops "urkec" <urkec@xxxxxx> wrote in message news:17716A99-A42E-46B9-83B4-64A98D29EC8A@xxxxxx Quote: > "OldDog" wrote: > Quote: >> On Aug 13, 4:22 pm, OldDog <mikef2...@xxxxxx> wrote: Quote: >> > Hi, >> > >> > I would like to write a script that waits for a process to start, >> > starts counting and then record when it stops. >> > >> > So far I have this. It works if I start it after I start the process. >> > I need it to lurk until the process starts: >> > >> > Function isRunning(process) >> > WriteToLog "isRunning", "Looking for process=" & process >> > Set colProcessList = oWMIService.ExecQuery("Select * from >> > Win32_Process Where Name = """ & process & """" ) >> > isRunning = colProcessList.Count >> > End Function >> > >> > Sub WriteToLog(strProg, strData) >> > strCurrentTime = Now() >> > oLogFile.WriteLine(Now() & " | " & strProg & " | " & strData) >> > End Sub >> > >> > Const wbemFlagReturnImmediately = &h10 >> > Const wbemFlagForwardOnly = &h20 >> > Const ForReading = 1 >> > Const ForWriting = 2 >> > Const ForAppending = 8 >> > Const HKEY_LOCAL_MACHINE = &H80000002 >> > Const HKLM = &H80000002 >> > >> > Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}! >> > \root\cimv2") >> > Set oFSO = CreateObject("Scripting.FileSystemObject") >> > Set oLogFile = oFSO.OpenTextFile("c:\temp\ocsetup.txt", ForWriting, >> > True) >> > >> > If isRunning("ocsetup.exe") Then >> > C = 666 >> > Do Until C = 0 >> > C = isRunning("ocsetup.exe") >> > WScript.Echo "." >> > WriteToLog "main","Runing ocsetup.exe" >> > WScript.Sleep 1000 >> > Loop >> > WriteToLog "main","Finished Runing ocsetup.exe" >> > End If >> I found a way to get it to lurk: >> I made the main part of the script a Sub called TimeIt and then got it >> to call itself until the processes started. >> >> Sub TimeIt Quote: >> > If isRunning("ocsetup.exe") Then >> > C = 666 >> > Do Until C = 0 >> > C = isRunning("ocsetup.exe") >> > WScript.Echo "." >> > WriteToLog "main","Runing ocsetup.exe" >> > WScript.Sleep 1000 >> > Loop >> > WriteToLog "main","Finished Runing ocsetup.exe" >> WScript.Sleep 1000 ' Wait a second and try again >> TimeIt Quote: >> > End If >> > > You could also try this approach: Issue a WMI notification query to > monitor > instance creation events for Win32_Process instances with a specified name > and when you receive the notification use Win32_Process.ProcessId to wait > for > the Win32_Process deletion event. Here is a sample: > > > > strProcessName = "Notepad.exe" > > Set objWmi = GetObject("winmgmts:") > > Set objCreationSource = objWmi.ExecNotificationQuery _ > ("Select * From __InstanceCreationEvent " _ > & "Within 1 " _ > & "Where TargetInstance Isa 'Win32_Process' " _ > & "And TargetInstance.Name = '" & strProcessName & "'") > > Set objCreationEvent = objCreationSource.NextEvent > > Set objDeletionSource = objWmi.ExecNotificationQuery _ > ("Select * From __InstanceDeletionEvent " _ > & "Within 1 " _ > & "Where TargetInstance Isa 'Win32_Process' " _ > & "And TargetInstance.ProcessId = " _ > & objCreationEvent.TargetInstance.ProcessId) > > Set objDeletionEvent = objDeletionSource.NextEvent > > Set objDate = CreateObject("WbemScripting.SWbemDateTime") > objDate.Value = objCreationEvent.TargetInstance.CreationDate > > WScript.Echo "Process: " & strProcessName > WScript.Echo "Created: " & objDate.GetVarDate > WScript.Echo "Deleted: " & Now > > > -- > urkec in my own reply right at the start of this thread. |
| Vista Starts & stops | General Discussion | |||
| Diagnostic Policy Service starts then stops | Vista networking & sharing | |||
| How can I determine what process is running? | Vista General | |||
| Media Centre stops working just after it starts | Media Center | |||
| Media Center stops working before it Starts | Media Center | |||
