| | Shell.Application copy problems This may be a similar problem I saw posted about "copy here", but not sure. I wrote a script using shell.application to copy an end users stuff up to a network drive. It works perfectly on about 75% of the XP Pro machines I run it on, but not the rest. Anyone might know why it won't even do anything on the other 25% of my machines? James |
| shell.application throw error on asp file | VB Script | |||
| shell.application | VB Script | |||
| can shell.application do this? | PowerShell | |||
| Shell.Application Open method doesn't seem to | VB Script | |||
| problem with shell.application | PowerShell | |||
