Vista - vb script help
Old 08-19-2009   #1 (permalink)
Slu
vb script help
Hi All
i have managed to get a script working that installs a font on to a
windows users PC - which is great, except the problem being that i
intend to have this run as a startup script from group policy, and if
you run the script more than once - it complains that:
"the font is already installed, to install a new version, first remove
the old"
i understand its possible with vbs to check for a files existance
before running - could anyone help me in this respect or maybe suggest
an alternative way of doing things (by the way im totally new to VBS,
do not have a clue where to start.
Thanks for your help - script below
S
Const FONTS = &H14&
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.Namespace(FONTS)
objFolder.CopyHere "\\192.168.104.225\sysvol\EcoFont
\spranq_eco_sans_regular.ttf"
Reference:
http://www.microsoft.com/technet/scr...8/hey0425.mspx
Logon Script Causing Laptops To Hang - Problems in script? VB Script
problem passing args to script 'There is no script engine for file extenstion' VB Script
Include another script, keep variables in included script? PowerShell
Script file has 'OS Handle' error when run from script PowerShell
Can you drag-n-drop a file on top of a PS script to run the script? PowerShell
