Vista - Must I move the AD Groups I've created to the Default location so my script can see them, or is there another way...?
Old 08-20-2009   #1 (permalink)
Kelvin
I've been playing with a logon script and have a need different need to
check so was playing with this code.
The script seems to check this Default loccation:
domain.local\Users
But not where I've been storing the Groups I've created
domain.local\City\Groups
Do I need to move my Groups to the default location or can I have it also
check the location I've created?
Maybe there's a much better way to do this all together...
Any input would be appreciated
Kelvin
This is the code I was using to check Group membership:
Dim WSHShell, WSHNetwork, objDomain, DomainString, UserString, UserObj, Path
Set WSHShell = CreateObject("WScript.Shell")
Set WSHNetwork = CreateObject("WScript.Network")
' Automatically grab the user's domain name
DomainString = Wshnetwork.UserDomain
'----------------------------8<----------------------------
' Find the Windows Directory
WinDir = WshShell.ExpandEnvironmentStrings("%WinDir%")
Call MsgBox("WinDir is " & WinDir)
' Grab the user name
UserString = WSHNetwork.UserName
Call MsgBox("Users name is " & UserString)
' Grab the computer name for use in add-on code later
strComputer = WSHNetwork.ComputerName
Call MsgBox("Computer name is " & strComputer)
' Bind to the user object to get user name and check for group memberships
later
Set UserObj = GetObject("WinNT://" & DomainString & "/" & UserString)
'Check naming convention for mapping of the P: drive
'Now check for group memberships and map appropriate drives
'Note that this checks Global Groups and not domain local groups.
For Each GroupObj In UserObj.Groups
'Force upper case comparison of the group names, otherwise this is case
sensitive.
Select Case UCase(GroupObj.Name)
'Check for group memberships and take needed action
'In this example below, ADMIN and WORKERB are groups.
'Note the use of all upper case letters as mentioned above.
'Note also that the groups must be Global Groups.
Case "LEASINGSTAFF"
Call MsgBox("Member of LEASINGSTAFF " & GroupObj.Name)
Case "ADMINISTRATION"
Call MsgBox("Member of ADMINISTRATION " & GroupObj.Name)
Case "PARTSSTAFF"
Call MsgBox("Member of PARTSSTAFF " & GroupObj.Name)
Case "SALES"
Call MsgBox("Member of SALES " & GroupObj.Name)
Case "SERVICE"
Call MsgBox("Member of SERVICE " & GroupObj.Name)
Case "BUSINESSOFFICESTAFF"
Call MsgBox("Member of BUSINESSOFFICESTAFF " & GroupObj.Name)
Case "DOMAIN USERS"
Call MsgBox("Member of DOMAIN USERS " & GroupObj.Name)
Case "DOMAIN ADMINS"
Call MsgBox("Member of DOMAIN ADMINS " & GroupObj.Name)
End Select
Next
Old 08-20-2009   #2 (permalink)
Richard Mueller [MVP]
Re: Must I move the AD Groups I've created to the Default location so my script can see them, or is there another way...?
> domain.local\Users
> Kelvin
> Path
> later
> sensitive.
> Case "LEASINGSTAFF"
> Case "PARTSSTAFF"
> Case "SALES"
> Case "SERVICE"
> Case "DOMAIN USERS"
> End Select
> Next
There are better ways, but after a quick glance at your script I think it
should work. There should be no need to move your groups.
You are using the WinNT provider, which is slower and reveals fewer
attributes. It sees Active Directory as a flat namespace. It is blind to
OU's, but still sees all user, group, and computer objects no matter where
they are in AD, as long as you use "pre-Windows 2000" names. The wshNetwork
object retrieves "pre-Windows 2000" names.
I would test your script, not as a logon script, but at a command prompt
after logon. I would have the script echo all groups the user is a member
of. For example, a test script could be:
Wscript.Echo "Current user: " & UserObj.Name
Wscript.Echo "User belongs to groups"
Wscript.Echo GroupObj.Name
Next
The only conditions I can think of where this could fail in a logon script,
is if the client OS is older than Windows 2000. If your script runs after
logon, but seems to fail as a logon script, then perhaps you OS is Windows
95/98. Reply if this is the case, as there is a workaround.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Personal User Shell Folders - Move Location Tutorials
need location of the defender forums/groups Vista General
move pagefile.sys to another location Vista General
How can I move User's profile to another location? Vista General
RE: Default Users/My User location, is it possible to move the default to D:/ drive? Vista General
