| | simple file copy problem I can't see what I am doing wrong. I modified this script that I found on MS web site. All files are in the same directory. Const ForReading = 1 Const OverwriteExisting = TRUE Set objFSO = CreateObject("Scripting.FileSystemObject") Set objFile = objFSO.OpenTextFile("C:\Scripts\Computers.txt") Do Until objFile.AtEndOfStream strComputer = objFile.ReadLine strRemoteFile = "\\" & strComputer & "\C$\windows \system32\winexit.scr" objFSO.CopyFile "C:\Program Files\Windows Resource Kits\Tools \winexit.scr", strRemoteFile, OverwriteExisting Loop |
| | Re: simple file copy problem On Aug 24, 5:55*pm, wuzzle <wuzz...@xxxxxx> wrote: Quote: > I can't see what I am doing wrong. *I modified this script that I > found on MS web site. *All files are in the same directory. > > Const ForReading = 1 > Const OverwriteExisting = TRUE > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objFile = objFSO.OpenTextFile("C:\Scripts\Computers.txt") > > Do Until objFile.AtEndOfStream > * * strComputer = objFile.ReadLine > * * strRemoteFile = "\\" & strComputer & "\C$\windows > \system32\winexit.scr" > * * objFSO.CopyFile "C:\Program Files\Windows Resource Kits\Tools > \winexit.scr", strRemoteFile, OverwriteExisting > Loop were either sleeping or off. |
| | Re: simple file copy problem On Aug 25, 1:54*pm, wuzzle <wuzz...@xxxxxx> wrote: Quote: > On Aug 24, 5:55*pm, wuzzle <wuzz...@xxxxxx> wrote: > > > > > Quote: > > I can't see what I am doing wrong. *I modified this script that I > > found on MS web site. *All files are in the same directory. Quote: > > Const ForReading = 1 > > Const OverwriteExisting = TRUE Quote: > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > Set objFile = objFSO.OpenTextFile("C:\Scripts\Computers.txt") Quote: > > Do Until objFile.AtEndOfStream > > * * strComputer = objFile.ReadLine > > * * strRemoteFile = "\\" & strComputer & "\C$\windows > > \system32\winexit.scr" > > * * objFSO.CopyFile "C:\Program Files\Windows Resource Kits\Tools > > \winexit.scr", strRemoteFile, OverwriteExisting > > Loop > I figured it out. *Some of the machines I was trying to copy files to > were either sleeping or off. on it. Will speed up your script and give you better logging options. ![]() |
| UAC FAR file copy problem | Vista General | |||
| Problem with file copy over Gb LAN from Vista x64 to XP x86... | Network & Sharing | |||
| Simple? How to copy WWW picture to C drive | VB Script | |||
| Can't simple copy from a Mac to my ext HD | General Discussion | |||
| No need to burn a DVD, simple ISO file problem solution. | Vista General | |||
