| | BCC Problem A problem with bcc, probably syntax The following code works Set objMail = Server.CreateObject( "CDONTS.NewMail" ) objMail.To = "i...@xxxxxx; "&request.Form("email") objMail.From = "i...@xxxxxx" objMail.Subject = "From us!" It sends to "to " and the adress collected on the form Now I need to add a bcc. I tried Set objMail = Server.CreateObject( "CDONTS.NewMail" ) objMail.To = "i...@xxxxxx; "&request.Form("email") objMail.Bcc = "m...@xxxxxx" objMail.From = "i...@xxxxxx" objMail.Subject = "From us!" It sends to "to " and 2 copies to the the adress collected on the form but none to the newly added bcc. Any help greatly appreciated. Garry Jones Sweden |
| | Re: BCC Problem "GarryJones" <morack@xxxxxx> wrote in message news:afe3a41e-519e-49fd-9ed6-5f2e51269200@xxxxxx Quote: >A problem with bcc, probably syntax > > The following code works > > Set objMail = Server.CreateObject( "CDONTS.NewMail" ) > objMail.To = "i...@xxxxxx; "&request.Form("email") > objMail.From = "i...@xxxxxx" > objMail.Subject = "From us!" > > It sends to "to " and the adress collected on the form > > Now I need to add a bcc. I tried > > Set objMail = Server.CreateObject( "CDONTS.NewMail" ) > objMail.To = "i...@xxxxxx; "&request.Form("email") > objMail.Bcc = "m...@xxxxxx" > objMail.From = "i...@xxxxxx" > objMail.Subject = "From us!" > > It sends to "to " and 2 copies to the the adress collected on the form > but none to the newly added bcc. > > Any help greatly appreciated. > > Garry Jones > Sweden cdoBasic=1 schema = "http://schemas.microsoft.com/cdo/configuration/" Set objEmail = CreateObject("CDO.Message") With objEmail .From = "james.company.com" .To = "jack@xxxxxx" .CC = "jill@xxxxxx" .BCC = "john@xxxxxx" .Subject = "Test Mail" .Textbody = "The quick brown fox " & Chr(10) & "jumps over the lazy dog" With .Configuration.Fields .Item (schema & "sendusing") = 2 .Item (schema & "smtpserver") = "mail.company.com" .Item (schema & "smtpserverport") = 25 .Item (schema & "smtpauthenticate") = cdoBasic .Item (schema & "sendusername") = "smtp@xxxxxx" .Item (schema & "smtpaccountname") = "smtp@xxxxxx" .Item (schema & "sendpassword") = "smtp" End With .Configuration.Fields.Update .Send End With |
| | Re: BCC Problem That code you gave me looks very complicated. I know nothing of vbscript but have inherited a website with the code I quoted. The solution cited has inserted a lot of dots before every row which I did not have in my original code. Maybe it can not be done with that code format so maybe I need to translate the entire section of that part of the website with the code format where dots are needed before rows. Therefore I post the entire section in the hope someone can tell me exactly how to add bcc to this. objRS.Open SQL, objConn, 3,3 Set objMail = Server.CreateObject( "CDONTS.NewMail" ) objMail.To = "info at mywebsite; "&request.Form("email") objMail.From = "info at mywebsite" objMail.Subject = "Confirmation from me" Set objRS2 = Server.CreateObject("ADODB.Recordset") SQL = "select * from tableA where id ="&request.Form("field_id") objRS2.Open SQL, objConn, 3,3 item1= objRs2("field1") &" fritext1 "&objRs2("field2") & " freetext2"&objRs2("field3") objMail.Body = "Hello "&request.Form("field1")&" ("&request.Form ("field10")&")" & vbcrlf & vbcrlf & "Welcome" objMail.Host = "mailout dot isp dot com" objMail.Send Set objMail = Nothing response.redirect("../samepage.asp?mess=It worked") %> How do I add BCC ???? Do I really need to rewrite the entire code and puts dots in. Any help appreciated because I am out of my depth. Garry Jones Sweden |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
