read strings to variable
  1. #1
    James Guest
    I have a text file like this:
    1234 45566, 78923 10/02, 10/03, 10/04
    6543 46765, 35643 23/03
    I want the script to look at each line and read the first string to a
    variable(e.g. 1234), then read all strings after and including the
    fourth string to another variable (eg. 10/02 to variable, 10/03 to
    another variable etc) and then write those variables to a line in
    another text file. It would do this for each line in the text file. The
    fourth string and after dates and I would like to write it as 2009/10/02
    for example.
    Basically I want to grab specific text from each line of the text file
    and add them to commands. Can anyone help?
    Thanks,
    James
  2. #2
    Pegasus [MVP] Guest
    Re: read strings to variable
    "James" <jwanders@xxxxxx> wrote in message
    news:Tznom.137737$cf6.136849@xxxxxx
    > variable(e.g. 1234), then read all strings after and including the fourth
    > string to another variable (eg. 10/02 to variable, 10/03 to another
    > variable etc) and then write those variables to a line in another text
    > file. It would do this for each line in the text file. The fourth string
    > and after dates and I would like to write it as 2009/10/02 for example.
    > Basically I want to grab specific text from each line of the text file and
    > Thanks,
    > James
    You need to read each line with the ReadLine method of the File System
    Object. You then split each line into its components like so:
    aComponents = split(sLine)
    This will allow you to access each component separately:
    wscript.echo "String 1 = " & aComponents(0)
    wscript.echo "String 2 = " & aComponents(1)
    etc.
    All of the above is covered extensively, with examples, in the help file
    script56.chm which you can download from the Microsoft site.
read strings to variable problems?
Has anyone sucessfully read the value of the $OFS variable? Bob Landau PowerShell 2 08 Jan 2008
Read-Host issue, won't store to variable when using multiple read-host lines bryan.rutkowski@gmail.com PowerShell 7 09 Feb 2007
Read strings from resource DLL, WinFX , C# keerthana_m_2003@yahoo.com WinFX General 0 06 Nov 2006
Read strings from satellite DLL, Winfx C# keerthana_m_2003@yahoo.com Avalon 0 06 Nov 2006
Variable expansion in strings John Bush PowerShell 5 16 Jul 2006
