| | Using MAPI without Outlook Hello all, I just finished a simple VBScript that interfaces with an Exchange inbox usign MAPI. No big deal. Everything works. However, now I need to modify it so that the script doesn't require Outlook installed, because it might not be available on the server where the script will be running. From my research I only found this http://support.microsoft.com/kb/306962 which gives me hope, but it gives me no examples. What I basically need to do is interface with the inbox without having Set objOutlook = CreateObject("Outlook.Application") in the script. If anyone could point me to some code that could help me? |
| Error Initializing MAPI - Export Msgs to Outlook | Vista mail | |||
| MAPI error on import from outlook | Vista mail | |||
| mangling com object in outlook/mapi | PowerShell | |||
| cant export msgs to outlook - error initializing mapi | Vista mail | |||
