"kulichan2000" <kulichan2000@newsgroup> wrote in message
news:OOT%23CyqPKHA.4208@newsgroupBy far the simplest way is with a batch file. Under WinXP it would looke
> Hi,
> I start vbscript programming under vista.
> I want to clean all links of softs (word, excel, ...) in the start menu
> above the start button left side.
> Do you have any idea?
> Thanks
like this:
@echo off
del /q "%UserProfile%\Start Menu\*.lnk"
del /q "%AllUsersProfile%\Start Menu\*.lnk"
In VB Script you would have to use the File System Object to do this:
1. Get the folder you wish to clean out.
2. Delete all files with a .lnk extension.
Both techniques are described in detail, with examples, in the help file
script56.chm which you can download from the Microsoft site.
