Vista - Re: Script works well, but not as scheduled tasks ?
Old 10-12-2009   #1 (permalink)
Pegasus [MVP]
"francois" <francois@newsgroup> wrote in message
news:eVtRfj4SKHA.4028@newsgroup
Quote:
> Hello everybody,
> I have a vbs script which shutdowns all PC in OU. This script works very
> well ! But, when I want to schedule this script with "Scheduled Tasks", it
> does'nt work. It's very simple, when I schedule this script, absolutely
> nothing takes place ! Yet, the configuration of the scheduled tasks seems
> to be correct :
> - Run : C:\xxxxx\script.vbs (it's OK !)
> - Run as : SERVER\admin (account and password are OK !)
> Why does'nt it work ? And how to shedule my script ?
> I'm on Windows Server 2000, and here is my script :
> On Error Resume Next
> ldap_adress = _
> "LDAP://OU=MyPC, DC=yourcenar, DC=local"
> Set objConnection = Wscript.createObject("ADODB.Connection")
> Call objConnection.open ("Provider=ADsDSOObject;")
> Set objCommand = Wscript.createObject("ADODB.Command")
> objCommand.activeConnection = objConnection
> objCommand.commandText = _
> "<" & ldap_adress & ">;" & _
> "(ObjectCategory=computer);" & _
> "name;" & _
> "subtree"
> Set objRecord = objCommand.execute
> Set oShell = WScript.CreateObject ("WSCript.shell")
> objRecord.MoveFirst
> Do Until objRecord.EOF
> name = objRecord.Fields("name").Value
> name = UCase(Trim(name))
> commande = "shutdown -s -m \\" & name & " -t 30"
> Call oShell.run(commande, 0, False)
> objRecord.MoveNext
> Loop
> Thanks in advance for your help.
> François Lafont
I would take the following steps:
1. Check the Task Scheduler log file.
2. Instead of invoking the above script directly, invoke the following batch
file:
@echo off
echo %date% %time% %UserName% >> c:\test.txt
cscript //nologo c:\françois.vbs 1>> c:\test.txt 2>>&1
echo %date% %time% >> c:\test.txt
3. Remove the line "On error resume next" from your script. It makes
debuggin almost impossible.
4. Examine the file c:\test.txt.
Old 10-13-2009   #2 (permalink)
Pegasus [MVP]
news:ekveeE5SKHA.1232@newsgroup
Quote:
> Thank you for the answer.
> Pegasus [MVP] a écrit :
>> batch file:
>> @echo off
> Ok, I have done this. Nothing takes place like with directly the vbs
> script. Here is the test.txt file :
> mar. 13/10/2009 0:56:39,15 Administrateur
> mar. 13/10/2009 0:56:42,65
> Nothing !?!
> It's very curious. When I invoke the script directly, I can see lot of
> processes of the "shutdonwn" command in the "Windows Task Manager". It's
> logical, 1 PC = 1 process. But as scheduled task, with a .bat file (like
> above) or directly with the vbs script (like in my firt message), I don't
> see processes of the "shutdonwn" command. It's very strange, does'nt it ?
> François Lafont
Let's have a look at your script and your version of the batch file I
suggested!
Old 10-13-2009   #3 (permalink)
Pegasus [MVP]
*** See below.
news:%23JVQ%235CTKHA.4144@newsgroup
>> suggested!
> I'm sorry but I don't understand. I have done exactly what you said. I'm
> going to show you.
*** There have been numerous threads where I suggested
*** a certain batch file or script and the OP subsequently
*** claimed that it did not work. In most cases the failure
*** was caused by a poorly understood modification that
*** the OP made. This is why I now always ask for the
*** actual script or batch file.
Quote:
> 1) Here is my vbs script called shutdown.vbs. Notice that I removed the
> line "On Error Resume Next" as you said :
> ldap_adress = "LDAP://OU=Ordinateurs, DC=yourcenar, DC=local"
> "name;" & _
> "subtree"
> objRecord.MoveFirst
> commande = "c:\Windows\System32\shutdown.exe -s -m \\" & name & " -t
> 5"
> objRecord.MoveNext
> Loop
*** The "run" method will execute your command in
*** the background. It will be invisible to you. If you
*** want to see the output generated by a console
*** command then you need to use the Exec method,
*** e.g. like so:
Set oWshShell = CreateObject("WScript.Shell")
commande = "c:\Windows\System32\shutdown.exe -s -m \\" & name & " -t 5"
Set oExec = oWshShell.Exec(commande)
While oExec.Status = 0
WScript.Sleep 500
Wend
While Not oExec.StdOut.AtEndOfStream
WScript.Echo oExec.StdOut.ReadLine
Wend
Quote:
> 2) Here is my batch file, called go.bat :
> @echo off
> cscript //nologo shutdown.vbs 1>> c:\test.txt 2>>&1
> 3) I create a schelude task :
> - Run : C:\xxxxx\go.bat (it's OK !)
> 4) I start the schelude task. Nothing happens ! The test.txt file is
> created. Here is the test.txt file :
> mar. 13/10/2009 19:42:11,27 admin
> mar. 13/10/2009 19:42:14,75
> No signalled error ?!
> Yet, the shutdown.vbs script works very well if I run it directly with the
> command line :
> cscript shutdown.vbs (works very well ?)
> I don't understand. Have I forgotted an instruction that you asked me ?
> François Lafont
No, you did not forget anything. If you modify your VB Script as I suggested
then you will probably see why the shutdown command does not work. You could
also do some experimenting of your own, e.g. like so:
commande = "c:\Windows\System32\cmd.exe dir c:\"
This should write the output from the "dir" command into your log file
c:\test.txt.
Old 10-13-2009   #4 (permalink)
Todd Vargo
> "name;" & _
> "subtree"
> objRecord.MoveFirst
> commande = "shutdown -s -m \\" & name & " -t 5"
> objRecord.MoveNext
> Loop
> @echo off
> file is created. Here is the test.txt file :
> directly with the command line :
Your shutdown.vbs does not contain any lines to create output. I would add a
Wscript.Echo line near the top and another one at the end so test.txt will
reflect that shutdown.vbs is being executed to completion.
Wscript.Echo Wscript.ScriptFullName & " started at " & now
Wscript.Echo Wscript.ScriptFullName & " finished at " & now
Once satisfied the script is running, I would try changing .run method to
..exec method. The difference being .run method creates a new seperate
process while .exec is a child of the current process.
Todd Vargo
(Post questions to group only. Remove "z" to email personal messages)
Old 10-13-2009   #5 (permalink)
Al Dunbar
"Todd Vargo" <tlvargo@newsgroup> wrote in message
news:eE1jXsHTKHA.4360@newsgroup
>> "name;" & _
>> "subtree"
>> objRecord.MoveFirst
>> objRecord.MoveNext
>> Loop
>> @echo off
> a
Has anyone thought to ask if the scheduled batch script is able to find
shutdown.vbs? Is it on the path or in the same directory as go.bat?
/Al
Old 10-14-2009   #6 (permalink)
Pegasus [MVP]
"Al Dunbar" <alandrub@newsgroup> wrote in message
news:OAsBo7HTKHA.1280@newsgroup
>>> "name;" & _
>>> "subtree"
>>> objRecord.MoveFirst
>>> objRecord.MoveNext
>>> Loop
>>> @echo off
>> add a
>> will
> /Al
While it is true that the line
lacks a full path definition for shutdown.vbs, it would still generate the
following error message in c:\test.txt:
Input Error: Can not find script file "shutdown.vbs".
However, there is also a possibility that the OP has more than one file
called "shutdown.vbs", which emphasises the point of your argument: When
running a scheduled task then *all file names must be fully qualified*.
Old 10-14-2009   #7 (permalink)
Todd Vargo
Quote:
Quote:
> >> add a
> >> will
to
> > /Al
Adding the lines I suggested would expose the fact that the intended
shutdown.vbs was not being run, but yes, a fully qualified path would remove
doubt.
Todd Vargo
Old 10-14-2009   #8 (permalink)
acomputerwiz6
On Oct 14, 5:43*am, "Todd Vargo" <tlva...@newsgroup> wrote:
Quote:
> > "Al Dunbar" <aland...@newsgroup> wrote in message
Quote:
Quote:
> > > "Todd Vargo" <tlva...@newsgroup> wrote in message
Quote:
> > >> add a
> > >> will
Quote:
> to
Quote:
Quote:
> > > /Al
> doubt.
> Todd Vargo
Just add this line to the batch file (first line)
cd /d "%~dp0"
Old 10-14-2009   #9 (permalink)
Todd Vargo
francois wrote:
Quote:
> Firstly, thanks everybody for your answer, which I read
> carefully.
Quote:
> To make sure, that there is no ambiguity left, I'm going to
> explain what I exactly did. But, before that, I'd like to
> ask you why it works with the .Exec method and why it
> doesn't with the .Run method ? Sorry, but I like
> understanding what I do. :-)
Read my first post again for explanation.
Todd Vargo
Old 10-14-2009   #10 (permalink)
Pegasus [MVP]
news:OzCRoeRTKHA.504@newsgroup
Quote:
> Todd Vargo a écrit :
Quote:
Quote:
>>> To make sure, that there is no ambiguity left, I'm going to explain what
>>> I exactly did. But, before that, I'd like to ask you why it works with
>>> the .Exec method and why it doesn't with the .Run method ? Sorry, but I
>>> like understanding what I do. :-)
> I have seen already: :-)
> - .run method creates a new seperate process
> - .exec is a child of the current process
> But, it is forbidden to create a new separate process in a scheduled task
> ? Why ?
> François Lafont
It is perfectly OK to use the Run method under a scheduled task. Scheduled
tasks behave in exactly the same way as foreground tasks. It's only that you
cannot capture the console output from a Run command.
When trying to solve a problem, it often helps to simplify things. In order
to prove that the Run method works when scheduled, I created the following
simple script:
sCmd = oWshShell.ExpandEnvironmentStrings("%comspec% /c dir c:\ >
c:\test.txt")
oWshShell.Run sCmd
I then ran it under the Task Scheduler and it worked exactly as I expected,
creating some output lines in c:\test.txt. The scheduled task looked like
so:
cscript c:\test.vbs
In an earlier reply I recommended that you should capture the output from
the Exec method. I did not respond to my suggestion. What did you see?
Using PowerShell script to create a list of Scheduled tasks PowerShell
Where are kept Scheduled tasks? Vista General
scheduled tasks Vista General
Scheduled Tasks Vista General
scheduled tasks Vista performance & maintenance
