| | MSXML Fails to load document larger than 1 GB Forgive me, in advance, for this being vague... First question, is this the right forum? I am using MSXML within a vbScript, not associated with a web page. My problem seems to be with size of an XML document. I am using the .Load method as a simple validation tool to see if a file is well formed. I download the file, via FTP, open it with MSXML, and check the return value for success/failure. This works for files of size less than 1 GB, but fails for files greater than 1 GB. The threshold is close to 1 GB, though I haven't narrowed it with precision. 900 MB definitely works. 1.1 GB definitely fails. Does this sound familiar? Am I omitting anything? -- Trey Shaffer |
| Login screen fails to load | Vista General | |||
| Help - Clean Load of 64-Bit Ultimate Fails | Vista installation & setup | |||
| MMC fails to load event viewer | Vista installation & setup | |||
| Windows Vista RC1 fails to load. | Vista installation & setup | |||
| System Properties Fails To Load | Vista General | |||
