| | VBS to set system colors I would like to create a simple VBS script to set my system colors (primarily the window title bar color). Any ideas? Thanks@ |
| | Re: VBS to set system colors If you look in the Registry under this key: HKCU\Control Panel\Colors\ you'll find a number of names. For instance, the active title bar color is the value "ActiveTitle". The data is an RGB value formatted as a string with spaces, so it's like R G B. You just have to calculate those values and format the string. (This info. is for Win95 ->XP. I assume Vista/7 is the same, but I'm not certain. Also, there are issues with writing to the Vista/7 64 Registry. 64-bit Windows basically has 2 Registries, which can make things very complicated in some cases. Quote: > I would like to create a simple VBS script to set my system colors Quote: > the window title bar color). Any ideas? > > Thanks@ |
| | Re: VBS to set system colors "mayayana" <mayaXXyana@newsgroup> wrote in message news:OwFxPsNUKHA.4364@newsgroup Quote: > If you look in the Registry under this key: > HKCU\Control Panel\Colors\ > you'll find a number of names. For instance, the > active title bar color is the value "ActiveTitle". > The data is an RGB value formatted as a > string with spaces, so it's like R G B. You > just have to calculate those values and format > the string. > > (This info. is for Win95 ->XP. I assume Vista/7 > is the same, but I'm not certain. Also, there are issues > with writing to the Vista/7 64 Registry. 64-bit Windows > basically has 2 Registries, which can make things > very complicated in some cases. > > Quote: >> I would like to create a simple VBS script to set my system colors Quote: >> the window title bar color). Any ideas? >> >> Thanks@ write to HKCU on Vista computers. If normal users (non-admin) attempt to write to HKLM, Vista may let you believe it happened, but it actually writes to a virtual hive in HKCU. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| colors | Vista General | |||
| COLORS 2 | Vista General | |||
| Colors | Vista General | |||
| GUI colors AWFUL | Live Mail | |||
| Windows Mail Stationery Stopped Working, Also Font colors and background colors... | Vista mail | |||
