| | Help with VBScripts Run from the command line CheckREGKeys.vbs. The script seems to work and least for not finding a key or a value but no matter what valid key I use the script all ways tells me its invalid cscript CheckREGKeys.vbs HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft \Windows\WindowsUpdate Any ideas? All I am trying to do is to see if a key/value exists and then see if that value is equal to some specified value. [code= Save as CheckREGKeys.vbs] '************************************ '* Registry Item Exists (Function) '* Returns a value (true / false) '************************************ 'This function checks to see if a passed registry key/value exists, and 'returns true if it does 'Original Source http://www.tek-tips.com/faqs.cfm?fid=5864 'Extended by Matthew Kruer to handel external arguments. ' 'Requirements: The registry key/value you are looking for (RegistryItem) 'Note: RegistryItem MUST end in a backslash (\) if you are looking for a key ' RegistryItem's without a backslash (\) will assume you are looking for a value option explicit Dim objArgs, strArg Set objArgs = WScript.Arguments If (WScript.Arguments.Count = 1) Then Call RegistryItemExists (objArgs(0)) WScript.Quit Else WScript.Echo "USAGE: CheckREGKeys.vbs keyname" WScript.Quit End If '************************************ '* Registry Item Exists (Function) '* Returns a value (true / false) '************************************ 'This function checks to see if a passed registry key/value exists, and 'returns true if it does ' 'Requirements: The registry key/value you are looking for (RegistryItem) 'Note: RegistryItem MUST end in a backslash (\) if you are looking for a key ' RegistryItem's without a backslash (\) will assume you are looking for a value Function RegistryItemExists (RegistryItem) 'If there isnt the item when we read it, it will return an error, so we need to resume On Error Resume Next WScript.Echo("Looking for Key or Value") 'Find out if we are looking for a key or a value If (Right(RegistryItem, 1) = "\") Then 'It's a registry key we are looking for 'Try reading the key WScript.Echo("Looking for Key") WScript.echo RegistryItem WshShell.RegRead RegistryItem 'Catch the error Select Case Err 'Error Code 0 = 'success' Case 0: RegistryItemExists = true WScript.Echo("1. " & RegistryItem) 'This checks for the (Default) value existing (but being blank); as well as key's not existing at all (same error code) Case &h80070002: 'Read the error description, removing the registry key from that description ErrDescription = Replace(Err.description, RegistryItem, "") wscript.echo ErrDescription 'Clear the error Err.clear 'Read in a registry entry we know doesn't exist (to create an error description for something that doesnt exist) WshShell.RegRead "HKEY_ERROR\" 'The registry key exists if the error description from the HKEY_ERROR RegRead attempt doesn't match the error 'description from our RegistryKey RegRead attempt If (ErrDescription <> Replace(Err.description, "HKEY_ERROR\", "")) Then RegistryItemExists = true WScript.Echo("Check Found Key " & RegistryItem) Else RegistryItemExists = false WScript.Echo("Check Failed for Key " & RegistryItem) End If 'Any other error code is a failure code Case Else: RegistryItemExists = false WScript.Echo("Check Failed: Unknown Failure while looking for " & RegistryItem) End Select Else 'It's a registry value we are looking for 'Try reading the value WScript.Echo("Looking for Value") WshShell.RegRead RegistryItem 'Catch the error Select Case Err Case 0: 'Error Code 0 = 'success' RegistryItemExists = true WScript.Echo("Check Found Value for " & RegistryItem) Case Else 'Any other error code is a failure code RegistryItemExists = false WScript.Echo("Check could not find a value for " & RegistryItem) End Select End If 'Turn error reporting back on On Error Goto 0 End Function [code] |
| | Re: Help with VBScripts "Matthew" <mkruer@newsgroup> wrote in message news:7e34de29-f141-4ccd-8d99-043f675b9b8e@newsgroup Quote: > Run from the command line CheckREGKeys.vbs. The script seems to work > and least for not finding a key or a value but no matter what valid > key I use the script all ways tells me its invalid > > cscript CheckREGKeys.vbs HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft > \Windows\WindowsUpdate > > Any ideas? > > All I am trying to do is to see if a key/value exists and then see if > that value is equal to some specified value. > > [code= Save as CheckREGKeys.vbs] > '************************************ > '* Registry Item Exists (Function) > '* Returns a value (true / false) > '************************************ > 'This function checks to see if a passed registry key/value exists, > and > 'returns true if it does > 'Original Source http://www.tek-tips.com/faqs.cfm?fid=5864 > 'Extended by Matthew Kruer to handel external arguments. > ' > 'Requirements: The registry key/value you are looking for > (RegistryItem) > 'Note: RegistryItem MUST end in a backslash (\) if you are looking for > a key > ' RegistryItem's without a backslash (\) will assume you are > looking for a value > option explicit > Dim objArgs, strArg > Set objArgs = WScript.Arguments > If (WScript.Arguments.Count = 1) Then > Call RegistryItemExists (objArgs(0)) > WScript.Quit > Else > WScript.Echo "USAGE: CheckREGKeys.vbs keyname" > WScript.Quit > End If > > '************************************ > '* Registry Item Exists (Function) > '* Returns a value (true / false) > '************************************ > 'This function checks to see if a passed registry key/value exists, > and > 'returns true if it does > ' > 'Requirements: The registry key/value you are looking for > (RegistryItem) > 'Note: RegistryItem MUST end in a backslash (\) if you are looking for > a key > ' RegistryItem's without a backslash (\) will assume you are > looking for a value > Function RegistryItemExists (RegistryItem) > 'If there isnt the item when we read it, it will return an error, so > we need to resume > On Error Resume Next > WScript.Echo("Looking for Key or Value") > 'Find out if we are looking for a key or a value > If (Right(RegistryItem, 1) = "\") Then > 'It's a registry key we are looking for > 'Try reading the key > WScript.Echo("Looking for Key") > WScript.echo RegistryItem > WshShell.RegRead RegistryItem > 'Catch the error > Select Case Err > 'Error Code 0 = 'success' > Case 0: > RegistryItemExists = true > WScript.Echo("1. " & RegistryItem) > 'This checks for the (Default) value existing (but being blank); > as well as key's not existing at all (same error code) > Case &h80070002: > 'Read the error description, removing the registry key from > that description > ErrDescription = Replace(Err.description, RegistryItem, "") > wscript.echo ErrDescription > 'Clear the error > Err.clear > > 'Read in a registry entry we know doesn't exist (to create an > error description for something that doesnt exist) > WshShell.RegRead "HKEY_ERROR\" > > 'The registry key exists if the error description from the > HKEY_ERROR RegRead attempt doesn't match the error > 'description from our RegistryKey RegRead attempt > If (ErrDescription <> Replace(Err.description, "HKEY_ERROR\", > "")) Then > RegistryItemExists = true > WScript.Echo("Check Found Key " & RegistryItem) > Else > RegistryItemExists = false > WScript.Echo("Check Failed for Key " & RegistryItem) > End If > 'Any other error code is a failure code > Case Else: > RegistryItemExists = false > WScript.Echo("Check Failed: Unknown Failure while looking for " & > RegistryItem) > End Select > Else > 'It's a registry value we are looking for > 'Try reading the value > WScript.Echo("Looking for Value") > WshShell.RegRead RegistryItem > 'Catch the error > Select Case Err > Case 0: > 'Error Code 0 = 'success' > RegistryItemExists = true > WScript.Echo("Check Found Value for " & RegistryItem) > Case Else > 'Any other error code is a failure code > RegistryItemExists = false > WScript.Echo("Check could not find a value for " & RegistryItem) > End Select > End If > 'Turn error reporting back on > On Error Goto 0 > End Function > [code] 'Enumerate all values found in the nominated registry key. 'http://www.microsoft.com/technet/scriptcenter/guide/sas_reg_famr.mspx?mfr=True Const HKLM=&H80000002 Const REG_SZ = 1 Const REG_EXPAND_SZ = 2 Const REG_BINARY = 3 Const REG_DWORD = 4 Const REG_MULTI_SZ = 7 Const sKeyPath = "SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU" Set oReg=GetObject("winmgmts:\\.\root\default:StdRegProv") oReg.EnumValues HKLM, sKeyPath, aEntryNames, aValueTypes If VarType(aEntryNames) = 1 Then WScript.Echo "No values found" WScript.Quit End If For i = 0 To UBound(aEntryNames) WScript.Echo "Name: " & aEntryNames(i) Select Case aValueTypes(i) Case REG_SZ oReg.GetStringValue HKLM, sKeyPath, aEntryNames(i),sValue WScript.Echo "String=" & sValue Case REG_EXPAND_SZ oReg.GetExpandedStringValue HKLM, sKeyPath, aEntryNames(i), esValue WScript.Echo "Expanded String=" & esValue Case REG_BINARY oReg.GetBinaryValue HKLM, sKeyPath, aEntryNames(i),aValues Line = "" For Each byteValue In aValues Line = Line & byteValue Next WScript.Echo "Binary=" & Line Case REG_DWORD oReg.GetDWORDValue HKLM, sKeyPath, aEntryNames(i),dwValue WScript.Echo "DWORD=" & dwValue Case REG_MULTI_SZ oReg.GetMultiStringValue HKLM, sKeyPath, aEntryNames(i), aValues Line = "" For Each sValue In aValues Line = Line & sValue & vbLf Next WScript.Echo "Multi String=" & Line End Select Next |
| | Re: Help with VBScripts On Oct 21, 10:13*am, "Pegasus [MVP]" <n...@newsgroup> wrote: Quote: > "Matthew" <mkr...@newsgroup> wrote in message > > news:7e34de29-f141-4ccd-8d99-043f675b9b8e@newsgroup > > > Quote: > > Run from the command line CheckREGKeys.vbs. The script seems to work > > and least for not finding a key or a value but no matter what valid > > key I use the script all ways tells me its invalid Quote: > > cscript CheckREGKeys.vbs HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft > > \Windows\WindowsUpdate Quote: > > Any ideas? Quote: > > All I am trying to do is to see if a key/value exists and then see if > > that value is equal to some specified value. Quote: > > [code= Save as CheckREGKeys.vbs] > > '************************************ > > '* Registry Item Exists (Function) > > '* Returns a value (true / false) > > '************************************ > > 'This function checks to see if a passed registry key/value exists, > > and > > 'returns true if it does > > 'Original Sourcehttp://www.tek-tips.com/faqs.cfm?fid=5864 > > 'Extended by Matthew Kruer to handel external arguments. > > ' > > 'Requirements: The registry key/value you are looking for > > (RegistryItem) > > 'Note: RegistryItem MUST end in a backslash (\) if you are looking for > > a key > > ' * * *RegistryItem's without a backslash (\) will assume you are > > looking for a value > > option explicit > > Dim objArgs, strArg > > Set objArgs = WScript.Arguments > > If (WScript.Arguments.Count = 1) Then > > *Call RegistryItemExists (objArgs(0)) > > WScript.Quit > > Else > > *WScript.Echo "USAGE: CheckREGKeys.vbs keyname" > > *WScript.Quit > > End If Quote: > > '************************************ > > '* Registry Item Exists (Function) > > '* Returns a value (true / false) > > '************************************ > > 'This function checks to see if a passed registry key/value exists, > > and > > 'returns true if it does > > ' > > 'Requirements: The registry key/value you are looking for > > (RegistryItem) > > 'Note: RegistryItem MUST end in a backslash (\) if you are looking for > > a key > > ' * * *RegistryItem's without a backslash (\) will assume you are > > looking for a value > > Function RegistryItemExists (RegistryItem) > > *'If there isnt the item when we read it, it will return an error, so > > we need to resume > > *On Error Resume Next > > * WScript.Echo("Looking for Key or Value") > > *'Find out if we are looking for a key or a value > > *If (Right(RegistryItem, 1) = "\") Then > > * *'It's a registry key we are looking for > > * *'Try reading the key > > WScript.Echo("Looking for Key") > > WScript.echo RegistryItem > > WshShell.RegRead RegistryItem > > * *'Catch the error > > * *Select Case Err > > * * *'Error Code 0 = 'success' > > * * *Case 0: > > * * * *RegistryItemExists = true > > WScript.Echo("1. " & RegistryItem) > > * * *'This checks for the (Default) value existing (but being blank); > > as well as key's not existing at all (same error code) > > * * *Case &h80070002: > > * * * *'Read the error description, removing the registry key from > > that description > > * * * *ErrDescription = Replace(Err.description, RegistryItem, "") > > wscript.echo ErrDescription > > * * * *'Clear the error > > * * * *Err.clear Quote: > > * * * *'Read in a registry entry we know doesn't exist (to create an > > error description for something that doesnt exist) > > * * * *WshShell.RegRead "HKEY_ERROR\" Quote: > > * * * *'The registry key exists if the error description from the > > HKEY_ERROR RegRead attempt doesn't match the error > > * * * *'description from our RegistryKey RegRead attempt > > * * * *If (ErrDescription <> Replace(Err.description, "HKEY_ERROR\", > > "")) Then > > * * * * *RegistryItemExists = true > > * WScript.Echo("Check Found Key " & RegistryItem) > > * * * *Else > > * * * * *RegistryItemExists = false > > * WScript.Echo("Check Failed for Key " & RegistryItem) > > * * * *End If > > * * *'Any other error code is a failure code > > * * *Case Else: > > * * * *RegistryItemExists = false > > WScript.Echo("Check Failed: Unknown Failure while looking for " & > > RegistryItem) > > * *End Select > > *Else > > * *'It's a registry value we are looking for > > * *'Try reading the value > > WScript.Echo("Looking for Value") > > * *WshShell.RegRead RegistryItem > > * *'Catch the error > > * *Select Case Err > > * * *Case 0: > > * * * *'Error Code 0 = 'success' > > * * * *RegistryItemExists = true > > WScript.Echo("Check Found Value for " & RegistryItem) > > * * *Case Else > > * * * *'Any other error code is a failure code > > * * * *RegistryItemExists = false > > WScript.Echo("Check could not find a value for " & RegistryItem) > > * *End Select > > *End If > > *'Turn error reporting back on > > *On Error Goto 0 > > End Function > > [code] > I use the script below for this type of task. It's shorter and it works. > > 'Enumerate all values found in the nominated registry key. > 'http://www.microsoft.com/technet/scriptcenter/guide/sas_reg_famr.mspx... > Const HKLM=&H80000002 > Const REG_SZ = 1 > Const REG_EXPAND_SZ = 2 > Const REG_BINARY = 3 > Const REG_DWORD = 4 > Const REG_MULTI_SZ = 7 > Const sKeyPath = "SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU" > Set oReg=GetObject("winmgmts:\\.\root\default:StdRegProv") > oReg.EnumValues HKLM, sKeyPath, aEntryNames, aValueTypes > > If VarType(aEntryNames) = 1 Then > * *WScript.Echo "No values found" > * *WScript.Quit > End If > > For i = 0 To UBound(aEntryNames) > * *WScript.Echo "Name: " & aEntryNames(i) > * * Select Case aValueTypes(i) > * * * *Case REG_SZ > * * * * * oReg.GetStringValue HKLM, sKeyPath, aEntryNames(i),sValue > * * * * * WScript.Echo "String=" & sValue > * * * *Case REG_EXPAND_SZ > * * * * * oReg.GetExpandedStringValue HKLM, sKeyPath, aEntryNames(i), > esValue > * * * * * WScript.Echo "Expanded String=" & esValue > * * * *Case REG_BINARY > * * * * * oReg.GetBinaryValue HKLM, sKeyPath, aEntryNames(i),aValues > * * * * *Line = "" > * * * * *For Each byteValue In aValues > * * * * * * *Line = Line & byteValue > * * * * * Next > * * * * * WScript.Echo "Binary=" & Line > * * * *Case REG_DWORD > * * * * * oReg.GetDWORDValue HKLM, sKeyPath, aEntryNames(i),dwValue > * * * * * WScript.Echo "DWORD=" & dwValue > * * * *Case REG_MULTI_SZ > * * * * * oReg.GetMultiStringValue HKLM, sKeyPath, aEntryNames(i), aValues > * * * * *Line = "" > * * * * * For Each sValue In aValues > * * * * * * *Line = Line & sValue & vbLf > * * * * * Next > * * * * * WScript.Echo "Multi String=" & Line > *End Select > Next before. I should be able to modify it. My requirements are a bit more convoluted. In a nutshell all the systems were cloned and deployed with the incorrect WSUS information if any. I need to verify the server in the registry if the key exists, and if it doesn't then i need to delete another key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft \Windows\CurrentVersion\WindowsUpdate. This will force the system to register with the WSUS box. I was hoping to make it modular enough that i could use it to check other things in the registry. All this would be run during the initial logon for the box. |
| | Re: Help with VBScripts "Matthew" <mkruer@newsgroup> wrote in message news:eae77240-031e-4454-bd95-507ab390b926@newsgroup <snip> Thanks for the follow up. I have come across that particular script before. I should be able to modify it. My requirements are a bit more convoluted. In a nutshell all the systems were cloned and deployed with the incorrect WSUS information if any. I need to verify the server in the registry if the key exists, and if it doesn't then i need to delete another key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft \Windows\CurrentVersion\WindowsUpdate. This will force the system to register with the WSUS box. I was hoping to make it modular enough that i could use it to check other things in the registry. All this would be run during the initial logon for the box. ============= The script I posted can easily be modified to suit your requirement. You can use it to read any value of any type in any hive. |
| Create mutiple PCs in the Domain using vbScripts | VB Script | |||
| What is the executable associated with running VBScripts? | VB Script | |||
| VBScripts in Vista | Vista General | |||
