Vista - Simulating a button click to bypass a prompt
Old 4 Weeks Ago   #1 (permalink)
piancu
Hi everyone. I'm trying to use VB script to load a table from a HTML
page to a text file. The problem is that the webpage has a EULA
agreement prompt which i need to get past in order to download the
table. I get an error message about button sometimes but at times the
button is being clicked, although IE.document.body is non-existent and
nothing gets written to the file.
Do any of you know how I can click the button that appears but at the
same time be able to access the document body of the page I get to.
Thanks
Paul
Dim strContents
Dim row
Dim Tables, Table
Dim IE, IE2, IE3
Dim TableData, Td, Tr, Trs
Dim Data, Data1
Set IE = CreateObject("InternetExplorer.Application")
IE.Visible = True
IE.Navigate ("https://www.noridianmedicare.com/p-medb/enroll/
optout/oregon_optout.html")
Do While IE.Busy
Loop
wscript.sleep(100)
strContents = Space(1)
IE.document.getElementbyID("eula-accept").click()
Set Tables = IE.document.Body.getElementsbyTagName("table")
Set myFSO = CreateObject("Scripting.FileSystemObject")
Set WriteStuff = myFSO.OpenTextFile("\\db1\production\Files
\MedicareOptoutProviderList\medicareoptout.txt", 2, True)
For Each Table In Tables
Set TableData = Tables.Item(0)
Set Trs = TableData.getElementsbyTagName("tr")
For Each Tr In Trs
Set Data = Tr.getElementsbyTagName("td")
For Each Td In Data
row = row & Td.innertext & vbTab
Next
row = Replace(row, vbCrLf, strContents)
WriteStuff.WriteLine(row)
row = ""
Next
Next
WriteStuff.Close
IE.Quit
Old 3 Weeks Ago   #2 (permalink)
Pegasus [MVP]
Re: Simulating a button click to bypass a prompt
"piancu" <paul.r.iancu@newsgroup> wrote in message
news:e1f622dc-d889-407b-bcf7-12761ee94675@newsgroup
> Thanks
> Paul
> Dim strContents
> Dim row
> Dim Tables, Table
> Dim IE, IE2, IE3
> Dim Data, Data1
> IE.Visible = True
> Do While IE.Busy
> Loop
> wscript.sleep(100)
> For Each Tr In Trs
> For Each Td In Data
> Next
> row = ""
> Next
> Next
> WriteStuff.Close
> IE.Quit
If you open the three web pages below in the shown order then you should be
able to access your table:
1. https://www.noridianmedicare.com/p-m...on_optout.html
2. https://www.noridianmedicare.com/eul...oll%2F&agree=1
3. https://www.noridianmedicare.com/p-m...on_optout.html
Old 3 Weeks Ago   #3 (permalink)
piancu
On Oct 30, 3:17*am, "Pegasus [MVP]" <n...@newsgroup> wrote:
Quote:
> "piancu" <paul.r.ia...@newsgroup> wrote in message
Quote:
> > Thanks
> > Paul
Quote:
> > * *Dim strContents
> > * *Dim row
> > * *Dim Tables, Table
> > * *Dim IE, IE2, IE3
> > * *Dim TableData, Td, Tr, Trs
> > * *Dim Data, Data1
> > * *Set IE = CreateObject("InternetExplorer.Application")
> > * *IE.Visible = True
> > * *IE.Navigate ("https://www.noridianmedicare.com/p-medb/enroll/
> > * *Do While IE.Busy
> > * *Loop
> > * *wscript.sleep(100)
Quote:
> > * *strContents = Space(1)
> > * *IE.document.getElementbyID("eula-accept").click()
Quote:
> > * *Set Tables = IE.document.Body.getElementsbyTagName("table")
Quote:
> > * *Set myFSO = CreateObject("Scripting.FileSystemObject")
> > * *Set WriteStuff = myFSO.OpenTextFile("\\db1\production\Files
Quote:
> > * *For Each Table In Tables
> > * * * *Set TableData = Tables.Item(0)
> > * * * *Set Trs = TableData.getElementsbyTagName("tr")
> > * * * *For Each Tr In Trs
> > * * * * * *Set Data = Tr.getElementsbyTagName("td")
> > * * * * * *For Each Td In Data
> > * * * * * * * *row = row & Td.innertext & vbTab
> > * * * * * *Next
> > * * * * * *row = Replace(row, vbCrLf, strContents)
> > * * * * * *WriteStuff.WriteLine(row)
> > * * * * * *row = ""
> > * * * *Next
> > * *Next
> > * *WriteStuff.Close
> > * *IE.Quit
> 1.https://www.noridianmedicare.com/p-m...on_optout.html
> 2.https://www.noridianmedicare.com/eul...Fenroll%2F&agr....
> 3.https://www.noridianmedicare.com/p-m...n_optout.html- Hide quoted text -
> - Show quoted text -
Thank You! The navigation works but the document body doesn't seem to
have anything in it.
Do While IE.Busy
Loop
IE.Navigate ("https://www.noridianmedicare.com/%2Fp-medb%2Fenroll
%2F&agree=1")
Do While IE.Busy
Loop
Do While IE.Busy
Loop
wscript.sleep(100)
Old 3 Weeks Ago   #4 (permalink)
piancu
Quote:
Quote:
> > > Thanks
> > > Paul
Quote:
Quote:
> > > * *Dim strContents
> > > * *Dim row
> > > * *Dim IE, IE2, IE3
> > > * *Dim Data, Data1
> > > * *Do While IE.Busy
> > > * *Loop
> > > * * * * * *Next
> > > * * * * * *row = ""
> > > * * * *Next
> > > * *Next
> > > * *WriteStuff.Close
> > > * *IE.Quit
> * * IE.Navigate ("https://www.noridianmedicare.com/p-medb/enroll/
> * * Do While IE.Busy
> * * Loop
> * * IE.Navigate ("https://www.noridianmedicare.com/%2Fp-medb%2Fenroll
> %2F&agree=1")
> * * Loop
> * * Loop
> * * wscript.sleep(100)
> * * strContents = Space(1)
> * * Set Tables = IE.document.Body.getElementsbyTagName("table")- Hide quoted text -
I found the problem. I had to use the url of the I Agree button, the
url that appears at the bottom of the browser window when the mouse is
over the button.
IE.Navigate ("https://www.noridianmedicare.com/eula.php?t=%2Fp-medb
%2Fenroll%2Foptout2Foregon_optout.html&agree=1")
Old 3 Weeks Ago   #5 (permalink)
Pegasus [MVP]
news:6a962ee1-e96a-496d-bc2d-e36305890821@newsgroup
Quote:
Quote:
> > > Thanks
> > > Paul
Quote:
Quote:
> > > Dim strContents
> > > Dim row
> > > Dim Tables, Table
> > > Dim IE, IE2, IE3
> > > Dim Data, Data1
> > > IE.Visible = True
> > > Do While IE.Busy
> > > Loop
> > > wscript.sleep(100)
> > > For Each Tr In Trs
> > > For Each Td In Data
> > > Next
> > > row = ""
> > > Next
> > > Next
> > > WriteStuff.Close
> > > IE.Quit
> > be
> Do While IE.Busy
> Loop
> %2F&agree=1")
> Do While IE.Busy
> Loop
> Do While IE.Busy
> Loop
> wscript.sleep(100)
> text -
over the button.
Thanks for the feedback.
Visual Basic simple Prompt window with Minimize button VB Script
Click Once Publish from DOS prompt. .NET General
New tool available to selectively bypass the UAC prompt Vista General
How to click a mouse button Vista General
