Vista - Problem with recursion and objfolder.size
Old 2 Weeks Ago   #1 (permalink)
Jeremy
1l The purpose of the following script is to return attributes of subfolders
into an Excel spread sheet. The way it is now, it only gives the attirbutes
for the root folder. I know I need to add a for...next. I just don't know
what to put after the for.
2. I get a permissions error with the objfolderf.size line, but not with
other lines.
Any suggestions please?
'Script to get info on sub folders
'Section 1 - Excel Stuff
Set objExcel = CreateObject("Excel.Application")
objExcel.Visible = True
objExcel.Workbooks.Add
intRow = 2
objExcel.Cells(1, 1).Value = "Date Created"
objExcel.Cells(1, 2).Value = "Date Last Accessed"
objExcel.Cells(1, 3).Value = "Date Last Modified"
objExcel.Cells(1, 4).Value = "Name"
objExcel.Cells(1, 5).Value = "Path"
objExcel.Cells(1, 6).Value = "Size"
objExcel.Cells(1, 7).Value = "Type"
'Section 2 - Find folder Attributes
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFolder = objFSO.GetFolder("f:\jeremy-data")
'For each objFolder in objFSO.GetFolder
objExcel.Cells(intRow, 1).Value = objFolder.DateCreated
objExcel.Cells(intRow, 2).Value = objFolder.DateLastAccessed
objExcel.Cells(intRow, 3).Value = objFolder.DateLastModified
objExcel.Cells(intRow, 4).Value = objFolder.Name
objExcel.Cells(intRow, 5).Value = objFolder.Path
objExcel.Cells(intRow, 6).Value = objFolder.Size
objExcel.Cells(intRow, 7).Value = objFolder.Type
'Next
Old 2 Weeks Ago   #2 (permalink)
Pegasus [MVP]
Re: Problem with recursion and objfolder.size
"Jeremy" <Jeremy@newsgroup> wrote in message
news:A199E020-3C43-4FF0-8023-F170B091547D@newsgroup
> subfolders
> attirbutes
> know
> other lines.
> intRow = 2
> 'Next
It helps to see things more clearly if you add a little more structure to
your code. The script below should emphasizes the recursive component of
your code. Its core is the subroutine "ProcessFolder". You first call it
with the root folder name "f:\jeremy-data", then from within itself with the
name of each subfolder that exists.
sFolder = "f:\jeremy-data"
ProcessFolder(sFolder)
Sub ProcessFolder(sFolderName)
Set objFolder = objFSO.GetFolder(sFolderName)
For Each objSubFolder In objFolder.SubFolders
DoExcelStuff objSubFolder
ProcessFolder(objSubFolder.Path)
Next
End Sub
Sub DoExcelStuff (objFolder)
WScript.Echo objFolder.DateCreated
WScript.Echo objFolder.DateLastAccessed
WScript.Echo objFolder.DateLastModified
WScript.Echo objFolder.Name
WScript.Echo objFolder.Path
WScript.Echo objFolder.Size
WScript.Echo objFolder.Type
End Sub
Old 2 Weeks Ago   #3 (permalink)
Jeremy
RE: Problem with recursion and objfolder.size
Solved the recursive part, see below. Now just need help with the
permissions issue when asking for the folder size attribute.
intRow = 2
for each objFolder in objFolder.SubFolders
'objExcel.Cells(intRow, 6).Value = objFolder.Size
intRow = intRow + 1
Next
> other lines.
> intRow = 2
> 'Next
Old 2 Weeks Ago   #4 (permalink)
Jeremy
I'm wrong, what I have below only recurses one level. How do I get this to
apply to all sub folders? Thx, Jeremy
> other lines.
> intRow = 2
> 'Next
Old 2 Weeks Ago   #5 (permalink)
Tom Lavedas
On Nov 5, 11:01*am, Jeremy <Jer...@newsgroup> wrote:
Quote:
> I'm wrong, what I have below only recurses one level. *How do I get this to
> apply to all sub folders? *Thx, Jeremy
Here is an example I had handy ...
' A simple example of making a recursive list of files in a
' folder and all of its subfolders
' Derived from examples by Michael Harris, Torgier Bakken and
' others
Dim ofs ' a global reference to an instance of the FileSystemObject
Dim aFileSpecs
With CreateObject("WScript.Shell")
dpath = .SpecialFolders("MyDocuments")
End With
Set ofs = CreateObject("Scripting.FileSystemObject")
' One way to use the list is to break it up into an array
aFileSpecs = Split(getList(dPath, ofs), vbNewline)
wsh.echo "Found:", UBound(aFileSpecs), "file(s)"
wsh.echo Join(aFileSpecs, vbNewLine)
Function getList(sPath, ofs)
Dim s
s = ""
With ofs.GetFolder(sPath)
s = s & sPath & vbNewLine
if .SubFolders.Count > 0 Then
For each folder in .SubFolders
' Change this part to collect the information you want
s = s & getList(sPath & "\" & folder.Name, ofs)
Next
End if
End With
getList = s
End Function
_____________________
Tom Lavedas
Old 2 Weeks Ago   #6 (permalink)
Pegasus [MVP]
news:2591F773-4282-4B91-BFAA-2D75A7982147@newsgroup
> to
Did you actually read my detailed response to your first post?
Old 1 Week Ago   #7 (permalink)
Jeremy
Thank you both for your help. I'm reading through your suggestions, (which
I've only seen now, for some reason, I never see responses right away,
anyway....). I did find another script on another forum that helped me mash
out what I want to do. I've modified it to my needs and it seems to work
well. It saves everything to a text file we I can then open in Excel. So
just a few extra steps are required to convert the text data into Excel
format. But now that I think I have the concept down, I may try 'convert' it
to use Excel. There was one good point about exporting things to a log file.
It never occured to me that my users might use a comma in the name of their
word processing files! So I had to switch to using a semi colon for a
delimeter. Anyway, for anyone who is interested, here is my revised code.
And thanks again for the suggestions from both of you. Jeremy
Const ForAppending = 2
Dim objFSO:Set objFSO = CreateObject("Scripting.FileSystemObject")
Wscript.echo "Script is about to start!"
LogFile = "l:\exportme7.txt"
Dim objLogFile:Set objLogFile = objFSO.CreateTextFile(logfile, 2, True)
objStartFolder = "L:\"
Set objFolder = objFSO.GetFolder(objStartFolder)
objLogFile.write "Name;" & "Created;" & "Last Modified;" & "Size;" & "Path;"
& "Type"
objLogFile.Writeline
objLogFile.Write objFolder.Name & ";;;"
'objLogFile.Write objFolder.datecreated & ";"
'objLogFile.Write objFolder.datelastmodified & ";"
'objLogFile.Write objFolder.size & ";"
objLogFile.Write objFolder.Path & ";"
Set colFiles = objFolder.Files
For Each objFile in colFiles
objLogFile.Write objFile.Name & ";"
objLogFile.write objFile.datecreated & ";"
objLogFile.write objFile.datelastmodified & ";"
objLogFile.write objFile.size & ";"
objLogFile.Write objFile.path & ";"
objLogFile.Write objFile.Type
Next
ShowSubfolders objFSO.GetFolder(objStartFolder)
Sub ShowSubFolders(Folder)
For Each Subfolder in Folder.SubFolders
objLogfile.Write subfolder.Name & ";"
objLogFile.write subfolder.datecreated & ";"
objLogFile.write subfolder.datelastmodified & ";"
objLogFile.write subfolder.size & ";"
objLogFile.Write Subfolder.Path & ";"
objLogFile.write subfolder.Type
Set objFolder = objFSO.GetFolder(Subfolder.Path)
objLogFile.Write objFile.datecreated & ";"
objLogFile.Write objFile.datelastmodified & ";"
objLogFile.Write objFile.size & ";"
objLogFile.write objFile.type
Next
ShowSubFolders Subfolder
Next
End Sub
objLogFile.Close
wscript.echo "Script Finished!!!"
recursion help request VB Script
Xml, Recursion and Base64 PowerShell
Xml and Recursion PowerShell
Xml, recursion and Ôase64 PowerShell
How do I limit subfolder recursion? VB Script
