Help Please: Retrieving the first populated cell value from a specific excel spreadsheet column
  1. #1
    Troy Balmer Guest
    I need help with retrieving the first populated cell value from a specific
    excel spreadsheet column. This value will then be used for later parts in
    an broader script to mark the entry as used.
    The 3rd worksheet contains 3 columns. I need this code to go through all
    the cells in the 2nd column, in order from top to bottom, and have it return
    the first value found. In this example, it should return 55553.
    Phone Free Used
    55550 55550
    55551 55551
    55552 55552
    55553 55553
    55554 55554
    55555 55555
    Due to the structure of the spreadsheet, this column contains a lot of empty
    cells.
    I've gone through a number of different script sites but never found any to
    actually automate the search and report back the first entry found from the
    required column.
    Preferably the code that returns the first cell value should be accessing
    the spreadsheet as a background process (rather than it actually opening the
    file). Hopefully it would be similar to the following which I used in
    another script:
    Const adOpenStatic = 3
    Const adLockOptimistic = 3
    Const adCmdText = &H0001
    Set objConnection = CreateObject("ADODB.Connection")
    Set objRecordSet = CreateObject("ADODB.Recordset")
    strTelExt = 69696 'The extension of a given staff member.
    IntTelExt = Len(strTelExt) 'Gets the length of the extension - used
    for prettying up a MsgBox prompt
    strFirstNum = Left(strTelExt, 1) 'Gets the first number of the
    extension in a seperate string - used for prettying up a MsgBox prompt
    strRestNum = Right(strTelExt, IntTelExt - 1) 'Gets the remaining
    numbers of the extension in a seperate string - used for prettying up a
    MsgBox prompt
    strFullTelNum = "3969" & strTelExt 'Is the full telephone number in
    the format matching the spreadsheet.
    strFullTelNum2 = "03 969" & strFirstNum & " " & strRestNum
    'Re-arranges the number in complete format - used for prettying up a MsgBox
    prompt
    objConnection.Open "Provider=Microsoft.Jet.OLEDB.4.0;" & _
    "Data Source=\\server\share\phones.xls;" & _
    "Extended Properties=""Excel 8.0;HDR=Yes;"";"
    objRecordset.Open "Select * FROM [EXTENSIONS$]", _
    objConnection, adOpenStatic, adLockOptimistic, adCmdText
    'Searches for a specific entry in the worksheet
    strSearchCriteria = "Phone = " & strFullTelNum
    objRecordSet.Find strSearchCriteria
    'As this script is to mark the extension as free, it puts that number in the
    "FREE" column.
    objRecordset("FREE") = strFullTelNum
    objRecordset.Update
    'As this script is to mark the extension as free, it removes that number
    from the "USED" column.
    objRecordset("USED") = ClearValue
    objRecordset.Update
    objRecordset.Close
    objConnection.Close
    Many thanks in advance for your help.
    Troy.
  2. #2
    Pegasus [MVP] Guest
    Re: Help Please: Retrieving the first populated cell value from a specific excel spreadsheet column
    "Troy Balmer" <troy.balmer@newsgroup> schrieb im Newsbeitrag
    news:hg454l$6p8$1@newsgroup-01.bur.connect.com.au...
    > return the first value found. In this example, it should return 55553.
    > Phone Free Used
    > 55550 55550
    > 55551 55551
    > 55552 55552
    > 55553 55553
    > 55554 55554
    > 55555 55555
    > empty cells.
    > to actually automate the search and report back the first entry found from
    > the required column.
    > the file). Hopefully it would be similar to the following which I used in
    > another script:
    > MsgBox prompt
    > strFullTelNum2 = "03 969" & strFirstNum & " " & strRestNum 'Re-arranges
    > the number in complete format - used for prettying up a MsgBox prompt
    > the "FREE" column.
    > objRecordset.Update
    > objRecordset.Update
    > objRecordset.Close
    > objConnection.Close
    > Troy.
    I'm not aware of a function built into Excel to look for a non-blank cell.
    You would therefore have to test each cell manually, e.g. like so:
    For i = 2 To iLastRow
    if oSheet.cells(i, 1) <> "" then Exit For
    Next
    Function iLastRow
    Const xlCellTypeLastCell = 11
    oSheet.UsedRange.SpecialCells(xlCellTypeLastCell).Activate
    iLastRow = oExcel.ActiveCell.Row
    oSheet.Range("A1:A1").activateEnd
    Sub
  3. #3
    Pegasus [MVP] Guest
    > Phone Free Used
    > 55550 55550
    > 55551 55551
    > 55552 55552
    > 55553 55553
    > 55554 55554
    > 55555 55555
    > empty cells.
    > another script:
    > MsgBox prompt
    > the "FREE" column.
    > objRecordset.Update
    > objRecordset.Update
    > objRecordset.Close
    > objConnection.Close
    > Troy.
    It seems there is a function in Excel to detect a non-blank cell. Here is a
    working script sample, this time without errors:
    Function sBlankCell
    Const xlCellTypeBlanks = 2
    oSheet.UsedRange.SpecialCells(xlCellTypeblanks).Activate
    sBlankCell = oExcel.ActiveCell.Address
    End Function
    You may have to experiment a little to find out what number to use for your
    special cells. 2 stands for the first cell to contain some value (but not a
    formula). 11 stands for the last non-blank cell. Other numbers have meanings
    that I do not currently know.
  4. #4
    Troy Balmer Guest
    Thanks for your help Pegasus.
    I'm unsure how to include this in a vbscript so that it will open up the
    spreadsheet, retrieve the first found value and place it into a string for
    use by other actions in the script.
    As per my example, the script needs to get '55553' into a string
    'strFreeExt'.
    Whilst the action to search for the first populated cell in a column is
    greatly appreciated, I really need it incorperated into a complete script to
    obtain this value as I don't have the knowledge to do so.
    Many thanks for your response.
    Troy.
    "Pegasus [MVP]" <news@newsgroup> wrote in message
    news:%23UFJWgOfKHA.1592@newsgroup
    >> specific excel spreadsheet column. This value will then be used for
    >> later parts in an broader script to mark the entry as used.
    >> Phone Free Used
    >> 55550 55550
    >> 55551 55551
    >> 55552 55552
    >> 55553 55553
    >> 55554 55554
    >> 55555 55555
    >> empty cells.
    >> from the required column.
    >> in another script:
    >> MsgBox prompt
    >> in the format matching the spreadsheet.
    >> the "FREE" column.
    >> objRecordset.Update
    >> objRecordset.Update
    >> objRecordset.Close
    >> objConnection.Close
    >> Troy.
    > a
    > Function sBlankCell
    > End Function
    > your
    > a
    > meanings
  5. #5
    Pegasus [MVP] Guest
    In this newsgroup you might find that respondents answer specific questions,
    e.g. how to find the first non-blank cell in a spreadsheet, or they answer
    general questions, e.g. what is the best approach to tackle a certain
    project. If you require a turn-key solution then you probably have to pay
    someone to write the complete code for you. Alternatively you could ask your
    manager to send you to a VB Script training course. While working at the SEC
    (while it still existed!) I attended similar courses.
    "Troy Balmer" <troy.balmer@newsgroup> screv in
    news:hg6dtu$c0d$1@newsgroup-01.bur.connect.com.au...
    > 'strFreeExt'.
    > to obtain this value as I don't have the knowledge to do so.
    > Troy.
    >>> all the cells in the 2nd column, in order from top to bottom, and have
    >>> it return the first value found. In this example, it should return
    >>> 55553.
    >>> Phone Free Used
    >>> 55550 55550
    >>> 55551 55551
    >>> 55552 55552
    >>> 55553 55553
    >>> 55554 55554
    >>> 55555 55555
    >>> empty cells.
    >>> accessing the spreadsheet as a background process (rather than it
    >>> actually opening the file). Hopefully it would be similar to the
    >>> following which I used in another script:
    >>> MsgBox prompt
    >>> the "FREE" column.
    >>> objRecordset.Update
    >>> objRecordset.Update
    >>> objRecordset.Close
    >>> objConnection.Close
    >>> Troy.
    >> a
    >> Function sBlankCell
    >> End Function
    >> your
    >> a
    >> meanings
  6. #6
    Reventlov Guest
    Il giorno Tue, 15 Dec 2009 09:23:51 +1100, "Troy Balmer" <troy.balmer@newsgroup> ha
    scritto:
    Set objXL = CreateObject("Excel.Application")
    objXL.visible=true
    objxl.open filename
    objXL.oSheet.UsedRange.SpecialCells(xlCellTypeblanks).Activate
    >> sBlankCell = objXL.ActiveCell.Address
    Giovanni Cenati (Bergamo, Italy)
    Write to "Reventlov" at katamail com
    http://digilander.libero.it/Cenati (Esempi e programmi in VbScript)
"To" Column Not Being Populated Roger Overout Live Mail 4 10 Sep 2009
Deleting specific columns in an Excel spreadsheet... centre21 VB Script 1 21 Jan 2009
Re: Converting a Word doc to a multi-column Excel spreadsheet Paul Randall VB Script 1 12 Jan 2009
create Excel spreadsheet without loading Excel sneaky hamster VB Script 2 21 Oct 2008
Hyperlink from web page to specific cell in specific Excel sheet Quetzalcoatl VB Script 0 03 Sep 2008
