How to execute dos cmds in the prompt opened using VBScript?
  1. #1
    AuHuman Guest
    Dim shell
    Dim oExec
    Set shell = CreateObject("wscript.shell")
    Set oExec = shell.Exec("cmd.exe")
    oExec.StdIn.Write("exit")
    oExec.StdIn.Write VbCrLf
    Do While oExec.Status = 0
    WScript.Sleep 100
    Loop
    WScript.Echo oExec.Status
    Above code is not executing the exit command in the command prompt opened by
    shell.Exec("cmd.exe").
    Nothing is happening until i close the prompt manually by clicking the close
    button.
    How to execute dos commands in the prompt opened by shell.Exec("cmd.exe") ?.
    [i looked into the msdn library but its not clearing my above doubt]
  2. #2
    Tom Lavedas Guest
    Re: How to execute dos cmds in the prompt opened using VBScript?
    On Jan 26, 3:09*pm, AuHuman <AuHu...@newsgroup> wrote:
    > Dim shell
    > Dim oExec
    > WScript.Sleep 100
    > Loop
    > Above code is not executing the exit command in the command prompt openedby
    > button.
    > How to execute dos commands in the prompt opened by shell.Exec("cmd.exe")?.
    This worked for me ...
    Dim shell, oExec
    Const delay = 5
    Set oExec = shell.Exec("cmd.exe /k echo Will close in " & delay & "
    second(s)>con")
    for n = delay to 1 step - 1
    WScript.Sleep 1000
    oExec.StdIn.Writeline "echo " & n & " > con"
    Next
    oExec.StdIn.Writeline "echo Closing > con"
    WScript.Sleep 1000
    oExec.StdIn.Writeline "exit"
    _____________________
    Tom Lavedas
  3. #3
    AuHuman Guest
    Thanks a lot Tom Lavedas. Your post showed me the right way of resolving the
    error i was facing.
    "Tom Lavedas" wrote:
    > On Jan 26, 3:09 pm, AuHuman <AuHu...@newsgroup> wrote:
    > > Dim shell
    > > Dim oExec
    > > WScript.Sleep 100
    > > Loop
    > > button.
    > Dim shell, oExec
    > Const delay = 5
    > second(s)>con")
    > WScript.Sleep 1000
    > Next
    > WScript.Sleep 1000
    > Tom Lavedas
  4. #4
    mr_unreliable Guest
    Suggest using:
    Set oExec = shell.Exec("%comspec% /k echo Will (blah, blah,.. )
    instead of:
    Set oExec = shell.Exec("cmd.exe /k echo Will (blah, blah,.. )
    cheers, nitpickers anonymous
  5. #5
    Tom Lavedas Guest
    On Jan 31, 11:58*am, mr_unreliable
    > Suggest using:
    > * *Set oExec = shell.Exec("%comspec% /k echo Will (blah, blah,.. )
    > instead of:
    > * *Set oExec = shell.Exec("cmd.exe /k echo Will (blah, blah,.. )
    A nit picking Win98 user. I wonder how many of you there are
    left ;^))
    I always use COMSPEC, myself, but chose to stick with the formulation
    used by the OP in this case.
    Tom Lavedas
Execute vbscript using cscript.exe on remote machine using Powershell proxb PowerShell 12 04 Aug 2009
execute mysql query using vbscript James VB Script 0 09 Jun 2009
Execute VBScript from a floating popup menu crashRCFlyer VB Script 1 29 Aug 2008
Execute error: Type Mismatch: 'Execute' kellym-global.co.uk VB Script 2 21 Aug 2008
vbscript and UAC prompt dak Vista General 3 02 Mar 2007
