Problems with VBScript - RegRead when running as a service
  1. #1
    Brandon Guest
    I am working on a script that runs under a custom installation
    utility, which is running as a service. To get the current user name
    the script executes this command:
    str_Acct_Name_Val = "HKCU\Software\Microsoft\Windows\CurrentVersion
    \Explorer\Logon User Name"
    str_Acct_Name = RegRead(str_Acct_Name_Val)
    When I run the script from the command prompt, it can read that value
    just fine (under an administrator account). When the value is
    attempted to be read with service/local system privileges, the read
    fails.
    What is the problem here?
  2. #2
    Brandon Guest
    Re: Problems with VBScript - RegRead when running as a service
    Some additional information. When running as a service calling the
    current user name returns "SYSTEM" and my guess is that HKCU doesn't
    "exist" under the view of the SYSTEM, since there is technically no
    current user. There is a user logged in at the time, but not in the
    scope of the running script. Maybe there is somewhere in HKLM I could
    find the currently logged on user?
  3. #3
    LikeToCode Guest
    RE: Problems with VBScript - RegRead when running as a service
    So why not query the owner of a specific process like "explorer.exe".
    Option Explicit
    Dim objWMIService, colProcessList, objProcess, colProperties
    Dim strUserDomain, strUserName
    Set objWMIService =
    GetObject("winmgmts:{impersonationLevel=impersonate}!\\.\root\cimv2")
    Set colProcessList = objWMIService.ExecQuery("Select * from Win32_Process")
    For Each objProcess in colProcessList
    If objProcess.name = "explorer.exe" Then
    colProperties = objProcess.GetOwner(strUserName,strUserDomain)
    Wscript.Echo "The current User is: " & strUserDomain & "\" &
    strUserName & "."
    End If
    Next
Problems with VBScript - RegRead when running as a service problems?
Running exchange powershell command from vbscript Sofia VB Script 0 17 Mar 2010
Running exchange powershell command from vbscript Sofia PowerShell 0 16 Mar 2010
VBScript to get the Dell Service Tag.....I know...I know.... Cary Shultz VB Script 7 07 Jun 2009
VBScript problem in running Stored Query Codeblack VB Script 6 24 Sep 2008
Running an executable within a VBscript CLARK, GLENN B VB Script 3 22 Jul 2008
