Here is a function test to see if the address is alive, hope it helps
Function Reachable(strComputer)
' On Error Resume Next
Dim wmiQuery, objWMIService, objPing, objStatus
wmiQuery = "Select * From Win32_PingStatus Where Address = '" & strComputer
Set objWMIService = GetObject("winmgmts:\\.\root\cimv2")
Set objPing = objWMIService.ExecQuery(wmiQuery)
For Each objStatus in objPing
If IsNull(objStatus.StatusCode) Or objStatus.Statuscode<>0 Then
Reachable = False 'if computer is unreacable, return False
Else
Reachable = True 'if computer is reachable, return true
End If
Next
End Function
"ccc2501" wrote:
> Ok, here's my need. I am writing a script that does a few things, but
> I'm having trouble just pulling the "production" IP address into a
> variable, to then use in the rest of the script. I've see plenty of
> scripts to ping remote hosts, but that's not what I need. I've also
> worked up a few scripts on my own, but they all pull every IP on the
> machine, or require you to know the intenal ID of the NIC interface you
> need queried. The issue with this is that the ID is assigned randomly,
> and it's something you just have to know.
> I'm rather new at VBScript, and I've tried to muddle through it on my
> own before asking, but now I need help. Any advice would be greatly
> appreciated.
> ccc2501
