"Jason" <nospam@newsgroup> wrote in message
news:e3ScMUhxKHA.1692@newsgroup
> Hello
> I've got a to use the subst cmd on a PC, and when the script is run I
> won't know what drives are mapped at that time, so I'd like to be able to
> find a letter that isn't mapped, then I'll just use that in the subst cmd.
> My question, is how do i find a drive letter that isn't mapped?
> The Drives collection of the FileSystemObject is a collection of all known
drives. You could enumerate all drives, network and local, with:
Set objFSO = CreateObject("Scripting.FileSystemObject")
For Each objDrive In objFSO.Drives
Wscript.Echo objDrive.DriveLetter & ", " & objDrive.Path
Next
You could setup a dictionary object of known letters, then test a letter to
see if it is used. Better might be to just test using the DriveExists
method. For example:
If (objFSO.DriveExists("K:") = False) Then
' Drive K: is not used.
Next
You could even loop through several candidate letters until you find one
available. For example:
arrDrives = Array("K:", "M:", "J:", "E:", "N:")
For Each strDrive In arrDrives
If (objFSO.DriveExists(strDrive) = False) Then
strAvailable = strDrive
Exit For
End If
Next
The value of strAvailable will be the first drive letter available. If it is
blank, none are available.
Richard Mueller
MVP Directory Services
Hilltop Lab -
http://www.rlmueller.net
