I need a logoff script (with conditions and cancellation dialog box)
  1. #1
    Henninger5 Guest
    Platform: Windows XP SP3, domain workstation.
    I need a script that:
    1. Checks the username of the logged on user.
    - If the user is one of two specific users, it logs them off
    immediately.
    - If the user is not one of two specific users, proceed to step 2.
    2. Display a dialog box with a timer ticking down the seconds from 20
    minutes. Also in the dialog box, show the caption, "Unless the
    countdown is cancelled, the user will be automatically logged off." At
    the bottom of the dialog box, show a button that reads "Cancel
    Logoff".
    - If the button is clicked, the dialog box disappears and the
    countdown is cancelled.
    - If the timer counts all the way down, the user is immediately logged
    off.
    Can someone please help me? Thank you.
  2. #2
    Pegasus [MVP] Guest
    Re: I need a logoff script (with conditions and cancellation dialog box)
    "Henninger5" <ffrugone@newsgroup> wrote in message
    news:3810abd1-caf2-4a7e-b598-aabfc7c8d61c@newsgroup
    > immediately.
    > Logoff".
    > off.
    I recommend you download the helpfile script56.chm from the Microsoft site,
    then use it to put together a framework that meets most of your
    requirements. You then post your code and ask for assistance on some of the
    finer details.
vbs with conditions Amir VB Script 1 26 Apr 2010
Random Memory Errors at Logoff (and ONLY Logoff) Fergie General Discussion 4 31 Oct 2008
upgrade cancellation MIGUEL Vista installation & setup 2 17 Jan 2008
echo cancellation gram Vista General 0 14 Nov 2007
Can not view html with script dialog box Orione Vista General 0 06 Jun 2007
