On May 5, 2:53*pm, SammyL <sam...@newsgroup> wrote:
> Hi All,
> I am using a vbs to create an excel file from sql data, I then add and
> run a macro to format the excel, *and then remove the macro using
> "xlbook.VBProject.VBComponents.Remove
> xlbook.VBProject.VBComponents("Module1") " in order to send the users
> a clean excel without the macro. When the user tries to download using
> pop3 it results in an error and the file cannot download. There seems
> to be something remaining in the file after removing the macro that is
> causing it to drive pop3 crazy. it seems that there is remnant of the
> macro after removal.
> If i skip creation of the macro i can send successfully, but the users
> need it formatted.
> I also tried formatting from vbs, such as
> xlapp.ActiveSheet.PageSetup.Orientation = xlapp.xlLandScape and keep
> getting an error that i cannot set the properties.
> Please help! The xLwhatever constants cannot be accessed (at least not easily) from
a VBScript. Rather, their value needs to be hard coded into your
script. For example, add the definition for the xlLandScape in your
script and drop the object preface ...
Const xlLandScape = 2
xlapp.ActiveSheet.PageSetup.Orientation = xlLandScape
Do similar for all of the other xl constants and your script should be
able to do all of the formatting without resorting to calling an Excel
macro.
_____________________
Tom Lavedas
