output to cmd with | symbol
  1. #1
    Hylle Guest
    Hi.
    I am trying to call a cmd with some parameters. Unfortunately one of
    them is the | symbol.
    Here is the call i make:
    cmd="cmd /c" & chr(34) & "Echo WEBTST" & vbtab & "Check Backup status"
    & vbtab & status & vbtab & "Backup completed ok" & chr(124) &
    "files=" & files & ", folders=" & folders &", bytes=" & bytes &
    chr(34) & "|c:\repbcklog\send_nsca.exe -H nagios2 -c C:\repbcklog
    \send_nsca.cfg"
    wscript.echo cmd
    The call is trying to send input to the send_nsca.exe program, which
    requires TAB as the delimiter, and the chr(124) is the pipe symbol,
    the other pipe sign is working fine. I have tested including the ^
    sign before the chr(124). If i try to enter the command manually on a
    command prompt it works fine, but if it is the vbscript that does it,
    it complains that "files" is not a command. How do I escape the | sign
    so it works?
    Any hints?
    regards
    Jens Hyllegaard
  2. #2
    Pegasus [MVP] Guest
    Re: output to cmd with | symbol
    "Hylle" <jens.hyllegaard@newsgroup> wrote in message
    news:2e5512c7-7e24-4223-9a61-d6c6a1f2ac3a@newsgroup
    > Hi.
    > \send_nsca.cfg"
    > wscript.echo cmd
    > so it works?
    > Any hints?
    > regards
    > Jens Hyllegaard
    Let's have a look at the script line that actually invokes the command!
  3. #3
    Tom Lavedas Guest
    On May 25, 10:02*am, Hylle <jens.hyllega...@newsgroup> wrote:
    > Hi.
    > & vbtab & status & vbtab & "Backup completed ok" *& chr(124) &
    > \send_nsca.cfg"
    > wscript.echo cmd
    > so it works?
    > Any hints?
    > regards
    > Jens Hyllegaard
    It appears to me that there is a problemwith the two Chr(34)s. They
    are creating an invalid statement. In addition, I found that the
    escape character needs to be escaped, so that it requires THREE carats
    to make the statement work. Try this ...
    cmd="cmd /c" & "Echo WEBTST" & vbtab & "Check Backup status" _
    & vbtab & status & vbtab & "Backup completed ok^^^|" _
    & "files=" & files & ", folders=" & folders &", bytes=" & bytes _
    \send_nsca.cfg"
    wscript.echo cmd
    _____________________
    Tom Lavedas
  4. #4
    Hylle Guest
    On 25 Maj, 16:36, "Pegasus [MVP]" <n...@newsgroup> wrote:
    > "Hylle" <jens.hyllega...@newsgroup> wrote in message
    > > Hi.
    > > \send_nsca.cfg"
    > > wscript.echo cmd
    > > so it works?
    > > Any hints?
    > > regards
    > > Jens Hyllegaard
    Sorry, I thought I had put it in.
    here it is, pretty simple:
    result = objShell.run (cmd)
    I then check the value of result
    Regards
    Jens
  5. #5
    Hylle Guest
    > > Hi.
    > > \send_nsca.cfg"
    > > wscript.echo cmd
    > > so it works?
    > > Any hints?
    > > regards
    > > Jens Hyllegaard
    > It appears to me that there is a problemwith the two Chr(34)s. *They
    > are creating an invalid statement. *In addition, I found that the
    > to make the statement work. *Try this ...
    > \send_nsca.cfg"
    > wscript.echo cmd
    > Tom Lavedas
    Hi.
    Thanks that did it. It was due to the triple ^
    Here is what is working for me now.
    & vbtab & status & vbtab & "Backup completed ok^^^" & chr(124) &
    \send_nsca.cfg"
    test = objShell.run (cmd)
    wscript.echo cmd
output to cmd with | symbol problems?
@ symbol won't work wicksbc Vista mail 1 09 Feb 2010
Re: Why does the > symbol appear on some replies but not on others? Gary VanderMolen Vista mail 0 10 Jul 2009
Symbol definition Jay Vista mail 1 24 Feb 2009
Calendar Symbol Jeremiah Benes Vista mail 1 04 Jun 2008
Euro symbol Ingrid Vista mail 2 05 Sep 2007
