| 05-21-2008 | #1 (permalink) |
| | Install Virtual Machine Additions unavailable (greyed out) I am trying to install the Virtual Machine Additions from the action menu in a virtual machine (windows XP Pro, sp3 in host and VM). The item for doing so is grey and not available. I have logged on as an administrator and as "Administrator" (to the virtual machine) to no avail. Anyone have any suggestions as to how to get this selection available? -- arf |
| My System Specs |
| 05-21-2008 | #2 (permalink) |
| | Re: Install Virtual Machine Additions unavailable (greyed out) Hi, This sounds like "Windows" was not the selection made when creating the machine. I'm not sure how to change this after creating the VM (possibly by editing the configuration file manually), however you can install the Additions manually by mounting the ISO image located at: <drive>:\Program Files\Microsoft Virtual PC\Virtual Machine Additions\VMAdditions.iso You can mount an image by right-clicking the CD icon in the bottom part of the running virtual machine -- --Jonathan Maltz [Microsoft MVP - Windows - Virtual Machine] http://www.visualwin.com - A Windows Server 2003 visual, step-by-step tutorial site :-) http://vpc04.visualwin.com - Does <insert OS name> work on VPC 2004? Find out here Only reply by newsgroup. I do not do technical support via email. Any emails I have not authorized are deleted before I see them. "ARF" <ARF@xxxxxx> wrote in message news:95673D18-896E-4E8B-A894-870E73F58170@xxxxxx Quote: >I am trying to install the Virtual Machine Additions from the action menu >in > a virtual machine (windows XP Pro, sp3 in host and VM). The item for > doing > so is grey and not available. I have logged on as an administrator and as > "Administrator" (to the virtual machine) to no avail. Anyone have any > suggestions as to how to get this selection available? > -- > arf |
| My System Specs |
| 05-21-2008 | #3 (permalink) |
| | Re: Install Virtual Machine Additions unavailable (greyed out) On Wed, 21 May 2008 20:02:10 -0400, Jonathan Maltz [MS-MVP] wrote: Quote: > This sounds like "Windows" was not the selection made when creating the > machine. I'm not sure how to change this after creating the VM (possibly by > editing the configuration file manually) determines the initial amount of RAM suggested, and determines the initial amount of disk space suggested. It does not in any way, shape or form determine whether or not you can install the Additions. If the VM is running, that option is always available, whether or not the running OS supports the installation. -- Paul Adare http://www.identit.ca One picture is worth 128K words. |
| My System Specs |
| 05-22-2008 | #4 (permalink) |
| | Re: Install Virtual Machine Additions unavailable (greyed out) On Thu, 22 May 2008 00:45:23 -0400, Paul Adare <pkadare@xxxxxx> wrote: Quote: >On Wed, 21 May 2008 20:02:10 -0400, Jonathan Maltz [MS-MVP] wrote: > Quote: >> This sounds like "Windows" was not the selection made when creating the >> machine. I'm not sure how to change this after creating the VM (possibly by >> editing the configuration file manually) >Selecting the OS when creating the VM does two things, and two things only; >determines the initial amount of RAM suggested, and determines the initial >amount of disk space suggested. It does not in any way, shape or form >determine whether or not you can install the Additions. If the VM is >running, that option is always available, whether or not the running OS >supports the installation. must select Vista as the OS during the new pc wizard for the correct sound card to be configured. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| My System Specs |
| 05-22-2008 | #5 (permalink) |
| | Re: Install Virtual Machine Additions unavailable (greyed out) On Wed, 21 May 2008 23:16:22 -0700, Steve Jain wrote: Quote: > I believe it does one other thing, with regards to Vista guests. You > must select Vista as the OS during the new pc wizard for the correct > sound card to be configured. :-) -- Paul Adare http://www.identit.ca Breakthrough: It finally booted on the first try. |
| My System Specs |
| 05-23-2008 | #6 (permalink) |
| | Re: Install Virtual Machine Additions unavailable (greyed out) Thanks for the help. Worked like a charm! -- arf "Jonathan Maltz [MS-MVP]" wrote: Quote: > Hi, > > This sounds like "Windows" was not the selection made when creating the > machine. I'm not sure how to change this after creating the VM (possibly by > editing the configuration file manually), however you can install the > Additions manually by mounting the ISO image located at: > > <drive>:\Program Files\Microsoft Virtual PC\Virtual Machine > Additions\VMAdditions.iso > > You can mount an image by right-clicking the CD icon in the bottom part of > the running virtual machine > > -- > --Jonathan Maltz [Microsoft MVP - Windows - Virtual Machine] > http://www.visualwin.com - A Windows Server 2003 visual, step-by-step > tutorial site :-) > http://vpc04.visualwin.com - Does <insert OS name> work on VPC 2004? Find > out > here > Only reply by newsgroup. I do not do technical support via email. Any > emails I have not authorized are deleted before I see them. > > > "ARF" <ARF@xxxxxx> wrote in message > news:95673D18-896E-4E8B-A894-870E73F58170@xxxxxx Quote: > >I am trying to install the Virtual Machine Additions from the action menu > >in > > a virtual machine (windows XP Pro, sp3 in host and VM). The item for > > doing > > so is grey and not available. I have logged on as an administrator and as > > "Administrator" (to the virtual machine) to no avail. Anyone have any > > suggestions as to how to get this selection available? > > -- > > arf |
| My System Specs |
| Similar topics to: Install Virtual Machine Additions unavailable (greyed out) | ||||
| Virtual PC 2007 - Install Virtual Machine Additions | Tutorials | |||
| Install Virtual Machine additions on Server 2008 server core. | Virtual PC | |||
| Install Virtual Machine Additions | Virtual PC | |||
| How to install Virtual Machine Additions before OS loaded | Virtual Server | |||
| Uninstalling Virtual Machine Additions | Vista General | |||
