Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Misc Newsgroups > Virtual PC
Vista - VPC 2007 SP1, Virtual Machine Additions causing problems.
06-03-2008   #1 (permalink)
Peter C. Chapin
I just upgraded my Virtual PC 2007 installation to VPC2007 SP1. The
installation of the new system appeared to be successful. My host is
Windows XP SP3. I then booted my guest (Vista, no service pack) and all
appeared normal. Next I installed Virtual Machine Additions in my guest
figuring that I should update the Additions along with Virtual PC (I had
the Additions from the old version of Virtual PC installed previously).
Now, alas, my guest is nearly unusable. It is extremely slow and Virtual
PC consumes 100% of one of my cores (my host is a dual core machine). It
certainly appears that Virtual Machine Additions is at fault because the
guest ran fine before I installed the new version of the Additions.
What should I be looking at the hopefully fix this problem? Uninstalling
Virtual Machine Additions doesn't seem like the right answer even if it
works.
Peter
06-03-2008   #2 (permalink)
Colin Barnhorst
Re: VPC 2007 SP1, Virtual Machine Additions causing problems.
Don't upgrade the Vista guest until it is at service pack level one. Until
you do reinstall the vmadds for VPC 2007 rtm. If you need the vmadds .iso
for VPC 2007 rtm you can download VPC 2007 from
http://www.microsoft.com/downloads/d...displaylang=en
and install in a vm. That will extract the vmadds.iso. Naturally, VPC 2007
won't run in a guest but it will install and that is the easiest way to get
the .iso.
"Peter C. Chapin" <Peter.Chapin@xxxxxx> wrote in message
news:eO341WaxIHA.516@xxxxxx
> works.
> Peter
06-03-2008   #3 (permalink)
Peter C. Chapin
Colin Barnhorst wrote:
> Until you do reinstall the vmadds for VPC 2007 rtm. If you need the
> vmadds .iso for VPC 2007 rtm you can download VPC 2007 from
> 2007 won't run in a guest but it will install and that is the easiest
> way to get the .iso.
Okay, thanks. I'll give it a shot.
Peter
 VPC 2007 SP1, Virtual Machine Additions causing problems. problems?
Similar topics to: VPC 2007 SP1, Virtual Machine Additions causing problems.
Virtual PC 2007 - Install Virtual Machine Additions Tutorials
VPC 2007 SP1 - Virtual Machine Additions crashes Virtual PC
Install Virtual Machine Additions Virtual PC
Vista and Virtual Machine Additions Virtual PC
Uninstalling Virtual Machine Additions Vista General
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
