help with software on XP Pro guest
  1. #1
    run4it Guest
    I'm at my wits end trying to find a solution. VPCs are new to me, so hoping
    someone has an idea. Host: Vista Home Premium 64-bit. Guest XP Pro. I set
    up the VPC because I have an old navigation program (ChartView Planner) that
    won't install on the new 64-bit box. I installed ChartView on the guest, but
    there is a particular map, that everytime I access it and move it around or
    zoom in, I get a General Protection Fault error. This did not happen on my
    old box. I have reinstalled numerous times, I have increased RAM to 2GB. I
    don't know what else to do. This software is no longer made and I hate to
    not be able to use it. I thought about using a KVM switch and keep it running
    on the old box but I really don't have the room for two towers. I haven't
    tried a dual boot. Don't know how to do that and I'm exhaused from trying to
    get this to work. About to give up...
  2. #2
    Mark Rae [MVP] Guest
    Re: help with software on XP Pro guest
    "run4it" <run4it@xxxxxx> wrote in message
    news:E41765D7-9DA8-4EF3-9394-2420D851492A@xxxxxx
    > hoping
    > set
    > that
    > but
    > or
    > I
    It's important to remember that, apart from the CPU and RAM, all of the
    "hardware" inside a virtual machine is emulated, and some of this emulated
    hardware is not very modern, particularly the graphics card. Are you sure
    that the app in question doesn't need more sophisticated graphics than are
    available with the emulated S3 Trio? From your description, that sounds very
    much like it could be the case, in which case, regrettably VPC isn't the
    solution for you... FWIW, all other software virtualisation products (VMWare
    etc) work in a similar way...
    > I haven't tried a dual boot. Don't know how to do that
    Dual booting involves installing another operating system in a different
    partition on the same machine. This partition could be on your primary hard
    disk, or on a secondary hard disk. If on your primary hard disk, you'll need
    to invest in a partitioning program such as Partition Magic which can
    partition your disk without destroying its existing contents. Once you have
    the second partition available, it's a simple matter of installing the other
    operating system on it. Modern OS like XP Pro will "see" the two partitions
    during installation and ask you which one it should install itself onto.
    Then, at bootup time, you'll be presented with a menu asking you which OS
    you want to use.
    The advantage of this, in your particular case, is that it will almost
    certainly allow your old app to work. The disadvantage, of course, is that
    (unlike with VPC) both OS can't be running at the same time...
    Mark Rae
    ASP.NET MVP
    http://www.markrae.net
  3. #3
    David Wilkinson Guest
    run4it:
    If you want to try multi-boot, I would highly recommend a third party boot
    manager like the excellent BootIt NG, rather than the Vista boot manager.
    But really, any kind of multi-boot is very inconvenient if you want to use both
    computers all the time (virtualization is much better in this regard).
    If you want to use your old box, you do not necessarily need a KVM switch;
    rather you might try remote desktop. Then you can put your old machine in some
    other location, and just run an ethernet cable to it. Try it!
    David Wilkinson
    Visual C++ MVP
  4. #4
    run4it Guest
    Mark - if this was a VPC hardware issue, wouldn't the GPF error happen when
    accessing all the maps? Why would it only happen on one map?
    > > hoping
    > > set
    > > that
    > > but
    > > or
    > > I
    > you want to use.
    > Mark Rae
    > ASP.NET MVP
  5. #5
    news4020C1A-EA0D-4F8F-ADBE-49DCDF212D72@xxxxxx
    [top-posting corrected]
    >> emulated
    >> are
    >> very
    >> (VMWare
    > when
    I don't know - I'm not familiar with the software at all...
    Maybe the map in question is corrupt in some way...?
    Mark Rae
    ASP.NET MVP
  6. #6
    run4it Guest
    I have updated to XP SP3 and I have set the compatability mode back to
    Windows 98 (which is what ChartView was written for). Still no luck. Again,
    the GPF error only occurs on ONE map, all the others work fine. This error
    never happened on my old box with XP Pro SP2. Can anyone figure out why this
    would happen on only ONE map while on the VPC? I mean if the map data file
    was corrupt wouldn't it happen on my old box too? I wonder if I have an old
    copy of Windows 98 around and created a new VPC with that installed, do you
    think that might work better? Is it the OS in the VPC, or the VPC itself?
    It has been suggested to me by a co-worker to try VMWare instead. Any
    opinions?
    > run4it:
    > David Wilkinson
    > Visual C++ MVP
  7. #7
    Robert Comer Guest
    Go into the performance settings for the Video in your Win98 VM and
    turn the acceleration down some, that might make a difference.
    Bob Comer
    On Sat, 14 Jun 2008 08:20:01 -0700, run4it
    >opinions?
    >> run4it:
    >> David Wilkinson
    >> Visual C++ MVP
  8. #8
    Bill Leary Guest
    news:1BA2CB72-ED44-4C06-B711-9C54A7255D7A@xxxxxx
    > Again,
    > error
    > this
    > file
    The file is bit-for-bit identical to the one that work(s/ed) on the physical
    Win98 machine?
    - Bill
  9. #9
    FACE Guest
    From run4it <run4it@xxxxxx>, in
    microsoft.public.virtualpc on Sat, 14 Jun 2008 08:20:01 -0700 :
    >opinions?
    >> run4it:
    >> David Wilkinson
    >> Visual C++ MVP
    I think I have the profile of your problem, correct me if I am wrong:
    1. Chartview ran fine on a physical XP Pro SP2 64 bit physical machine.
    2. You created an XP machine as a guest to the XP host and upgraded to SP3.
    it is also 64bit.
    3. After installing Chartview on the XP Pro SP3 guest it gets a GPF.
    Question: Is there a reason not to have a second VM?
    FACE
  10. #10
    "FACE" <AFaceInTheCrowd@xxxxxx> wrote in message
    news:mk4854dsfvkaplhs7hfioflsgnto3vct61@xxxxxx
    > SP3.
    > it is also 64bit.
    Virtual PC does not support 64-bit guests...
    Mark Rae
    ASP.NET MVP
Page 1 of 2 12 LastLast
help with software on XP Pro guest problems?
How to determine the VIRTUAL guest is running Microsoft guest or VMWARE guest ? IT Staff PowerShell 4 26 Jan 2010
Host: Vista, Guest: XP - using guest for MP3 player? Kelsey Virtual PC 1 27 Dec 2008
can I autorun a programme in a guest when starting guest? Wasted Virtual PC 3 27 Nov 2008
Does Software Restriction Policy on Host Affect a Guest OS? LeftFoot Virtual PC 1 03 Aug 2008
Networking Guest to Host and Host to Guest GaryPod Virtual PC 2 02 Jul 2008
