| | Resolution problem with Win 98 SE under MS VPC 2007 This is not actually a problem, but more of an unexplained situation. When I start the Win98 SE VM, it is in 640 x 480 mode. I can change it and it stays at the upped resolution throughout the session. It does not stick between sessions though. Other system configuration changes do. Anyone else have this happening? FACE |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 Have you installed the virtual machine additions in the guest? "FACE" <AFaceInTheCrowd@xxxxxx> wrote in message news:n9op6453gunhadpo7lgur9ptja1ijeqi2v@xxxxxx Quote: > This is not actually a problem, but more of an unexplained situation. > > When I start the Win98 SE VM, it is in 640 x 480 mode. I can change it > and it stays at the upped resolution throughout the session. > > It does not stick between sessions though. > > Other system configuration changes do. > > Anyone else have this happening? > > FACE > > |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 Yes. From "Colin Barnhorst" <c.barnhorst@xxxxxx>, in microsoft.public.virtualpc on Thu, 3 Jul 2008 09:21:32 -0600 : Quote: >Have you installed the virtual machine additions in the guest? > >"FACE" <AFaceInTheCrowd@xxxxxx> wrote in message >news:n9op6453gunhadpo7lgur9ptja1ijeqi2v@xxxxxx Quote: >> This is not actually a problem, but more of an unexplained situation. >> >> When I start the Win98 SE VM, it is in 640 x 480 mode. I can change it >> and it stays at the upped resolution throughout the session. >> >> It does not stick between sessions though. >> >> Other system configuration changes do. >> >> Anyone else have this happening? >> >> FACE >> >> |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 From "Colin Barnhorst" <c.barnhorst@xxxxxx>, in microsoft.public.virtualpc on Thu, 3 Jul 2008 11:32:09 -0600 : Quote: >I suspect the issue is in Win98. The vm console will open to the resolution >of the guest so it is apparently not holding in the guest. So the question >is why isn't Win98 itself remembering the resolution. What is the name >(exact entry) of the display adaptor showing in Device Mananger? Quote: >In Win98 >Device Manager is a tab on the System Properties page (right click on My >Compuer and select Properties). VM Additions Trio32/64 PCI(732/764) FACE Quote: > >"FACE" <AFaceInTheCrowd@xxxxxx> wrote in message >news:umsp6410qud8asqadbb73p17lqedc50b38@xxxxxx Quote: >> Yes. >> >> From "Colin Barnhorst" <c.barnhorst@xxxxxx>, in >> microsoft.public.virtualpc on Thu, 3 Jul 2008 09:21:32 -0600 : >> Quote: >>>Have you installed the virtual machine additions in the guest? >>> >>>"FACE" <AFaceInTheCrowd@xxxxxx> wrote in message >>>news:n9op6453gunhadpo7lgur9ptja1ijeqi2v@xxxxxx >>>> This is not actually a problem, but more of an unexplained situation. >>>> >>>> When I start the Win98 SE VM, it is in 640 x 480 mode. I can change it >>>> and it stays at the upped resolution throughout the session. >>>> >>>> It does not stick between sessions though. >>>> >>>> Other system configuration changes do. >>>> >>>> Anyone else have this happening? >>>> >>>> FACE >>>> >>>> |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 On Thu, 03 Jul 2008 14:05:33 -0400, FACE <AFaceInTheCrowd@xxxxxx> wrote: Quote: >From "Colin Barnhorst" <c.barnhorst@xxxxxx>, in >microsoft.public.virtualpc on Thu, 3 Jul 2008 11:32:09 -0600 : > Quote: >>I suspect the issue is in Win98. The vm console will open to the resolution >>of the guest so it is apparently not holding in the guest. So the question >>is why isn't Win98 itself remembering the resolution. What is the name >>(exact entry) of the display adaptor showing in Device Mananger? Quote: >>In Win98 >>Device Manager is a tab on the System Properties page (right click on My >>Compuer and select Properties). >The exact name is > >VM Additions Trio32/64 PCI(732/764) > >FACE > plug-n-play. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| | #6 (permalink) |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 From Steve Jain <noreply.-@-.essjae.com>, in microsoft.public.virtualpc on Thu, 03 Jul 2008 12:21:40 -0700 : Quote: >On Thu, 03 Jul 2008 14:05:33 -0400, FACE <AFaceInTheCrowd@xxxxxx> >wrote: > Quote: >>From "Colin Barnhorst" <c.barnhorst@xxxxxx>, in >>microsoft.public.virtualpc on Thu, 3 Jul 2008 11:32:09 -0600 : >> Quote: >>>I suspect the issue is in Win98. The vm console will open to the resolution >>>of the guest so it is apparently not holding in the guest. So the question >>>is why isn't Win98 itself remembering the resolution. What is the name >>>(exact entry) of the display adaptor showing in Device Mananger? Quote: >>>In Win98 >>>Device Manager is a tab on the System Properties page (right click on My >>>Compuer and select Properties). >>The exact name is >> >>VM Additions Trio32/64 PCI(732/764) >> >>FACE >> >Check the monitor, if it is set to default, try changing it to >plug-n-play. "device manager". FACE |
| | #7 (permalink) |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 On 7ÔÂ3ÈÕ, ÏÂÎç10ʱ49·Ö, FACE <AFaceInTheCr...@xxxxxx> wrote: Quote: > This is not actually a problem, but more of an unexplained situation. > > When I start the Win98 SE VM, it is in 640 x 480 mode. I can change it > and it stays at the upped resolution throughout the session. > > It does not stick between sessions though. > > Other system configuration changes do. > > Anyone else have this happening? > > FACE |
| | #8 (permalink) |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 >>> Quote: Quote: >> >>Check the monitor, if it is set to default, try changing it to >>plug-n-play. > Thanks. I'll look into that. It is now set as "default" according to > "device manager". > > FACE > |
| | #9 (permalink) |
| | Re: Resolution problem with Win 98 SE under MS VPC 2007 From "Colin Barnhorst" <c.barnhorst@xxxxxx>, in microsoft.public.virtualpc on Sat, 5 Jul 2008 21:38:23 -0600 : Quote: Quote: Quote: >>>> >>> >>>Check the monitor, if it is set to default, try changing it to >>>plug-n-play. >> Thanks. I'll look into that. It is now set as "default" according to >> "device manager". >> >> FACE >> It now does that. I have not changed the monitor properties. I will at some time as an exercise. What worked: I went into "not running" settings of the VM I clicked on "display" and changed that from "use any screen resolution" to "use guest operating machine resolution" That worked. It starts fullscreen (checked) at 800 x 600 (internal guest VM screen properties). FACE |
| Resolution Problem | Graphic cards | |||
| RE: Virtual PC 2007 :: Screen resolution workaround? | Virtual PC | |||
| Resolution problem | Graphic cards | |||
| Word 2007 changes screen resolution? | Vista General | |||
| Resolution problem | Vista performance & maintenance | |||
