Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - 16-bit Palm Desktop using USB Cradle for Synchronization
Old 07-06-2008   #1 (permalink)
HLNOVIT
I'd like to run a legacy 16-bit windows application program and believe there
is no problem doing so on Vista 64 using Virtual PC.
I also need to use a Palm Desktop application (Version 4.1.4) via a USB
connected cradle to synchronize data between the virtual host and PalmOS PDA.
Can Virtual PC handle a USB-connected device or am I going to have problems
finding a special 64-bit driver for the Palm cradle device.
Old 07-06-2008   #2 (permalink)
Mark Rae [MVP]
Re: 16-bit Palm Desktop using USB Cradle for Synchronization
"HLNOVIT" <HLNOVIT@xxxxxx> wrote in message
news:2578DCD8-1937-4C77-B3CE-63BE0F6A7D44@xxxxxx
> there
Largely depends what your legacy app does and, more specifically, whether it
needs any specific hardware or not... 64-bit Vista is irrelevant here, as
your legacy app will have no knowledge of it - all it will know about is the
OS in the VM on which it's running...
> PDA.
> problems
VPC doesn't support USB at all, unless the USB device can be shared via
standard networking...
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 07-06-2008   #3 (permalink)
HLNOVIT
Thanks, Mar. That pretty much says "No go" at this end. Appreciate the
comments.
> > there
> > PDA.
> > problems
> Mark Rae
> ASP.NET MVP
Old 07-06-2008   #4 (permalink)
pie8ter
Can someone tell me how in the world I create a new post to this news group?
Thanks
"HLNOVIT" wrote:
> comments.
> > > there
> > > PDA.
> > > problems
> > Mark Rae
> > ASP.NET MVP
Old 07-07-2008   #5 (permalink)
Colin Barnhorst
"pie8ter" <pie8ter@xxxxxx> wrote in message
news:BBA8180D-F76B-48CF-953F-B443EE1DB50C@xxxxxx
> group?
> Thanks
> "HLNOVIT" wrote:
>> comments.
>> > > believe
>> > > there
>> > whether it
>> > as
>> > is the
>> > > USB
>> > > PalmOS
>> > > PDA.
>> > > problems
>> > Mark Rae
>> > ASP.NET MVP
What newsreader are you using?
Old 07-07-2008   #6 (permalink)
Colin Barnhorst
"Robert Riebisch" <Robert.Riebisch@xxxxxx> wrote in message
news:4871c226$0$27445$9b4e6d93@xxxxxx-online.net...
Quote:
> Colin Barnhorst wrote:
> "Microsoft CDO for Windows 2000" ;-(
> Robert Riebisch
> Bitte NUR in der Newsgroup antworten!
> Please reply to the Newsgroup ONLY!
I'm not familiar with it but you are looking for a New Message button.
Old 07-07-2008   #7 (permalink)
Paul Adare - MVP
>> Robert Riebisch
It is the web UI as should be fairly self-evident given the
@discussions.microsoft.com email address of the poster. It is also trivial
to determine what news client someone is using by looking at the headers of
their posts.
Paul Adare
MVP - Identity Lifecycle Manager
http://www.identit.ca
Hardware: Typically boots, leather, and chains. Contrast with software.
Old 07-07-2008   #8 (permalink)
DevilsPGD
In message <2578DCD8-1937-4C77-B3CE-63BE0F6A7D44@xxxxxx> HLNOVIT
One option might be to use a serial cradle instead, going from memory,
all Palm PDAs that came with that version could use serial or USB
cradles.
Palm Zire Hotsync with Palm Desktop OS in Vista Vista General
Palm Desktop will not open Vista hardware & devices
palm desktop compatability Vista General
Palm Desktop won't install Vista hardware & devices
