Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Re: Default location of virtual machines
Old 07-07-2008   #1 (permalink)
Robert Comer
http://blogs.msdn.com/virtual_pc_guy...13/407796.aspx
Bob Comer <Microsoft MVP Windows - Virtual Machine>
On Mon, 07 Jul 2008 20:08:06 +0200, Jos Roijakkers <jos@xxxxxx-video.nl>
wrote:
Quote:
>Virtual PC uses a default location for storing the virtual machine and
>virtual disk files (My Documents\My Virtual Machines).
>I always store my (data) files on another disk. I would like to this for
>the VPC-files as well. I can, of course, manually select any location I
>want, but would prefer to do this automatically. Is there a way to
>change the default location? I checked the Windows registry and looked
>for a configuration file in the program files folder but did not find
>what I was looking for.
>Thanks in advance.
>Jos
Change location of "My Virtual Machines" Virtual PC
XP SP3 updated 3 virtual machines Virtual PC
Re: Default location of virtual machines Virtual PC
a tip for virtual machines Vista General
RE: Default Users/My User location, is it possible to move the default to D:/ drive? Vista General
