Re: Default location of virtual machines
  1. #1
    Mark Rae [MVP] Guest
    "Jos Roijakkers" <jos@xxxxxx-video.nl> wrote in message
    news:OB4bpxF4IHA.4340@xxxxxx
    > Virtual PC uses a default location for storing the virtual machine and
    > virtual disk files (My Documents\My Virtual Machines).
    > I always store my (data) files on another disk. I would like to this for
    > the VPC-files as well. I can, of course, manually select any location I
    > want, but would prefer to do this automatically. Is there a way to change
    > the default location? I checked the Windows registry and looked for a
    > configuration file in the program files folder but did not find what I was
    > looking for.
    You won't believe this, but you actually need to set up an environment
    variable:
    http://blogs.msdn.com/virtual_pc_guy...13/407796.aspx
    Mark Rae
    ASP.NET MVP
    http://www.markrae.net
  2. #2
    David Trimboli Guest
    >> for the VPC-files as well. I can, of course, manually select any
    >> location I want, but would prefer to do this automatically. Is there a
    >> way to change the default location? I checked the Windows registry and
    >> looked for a configuration file in the program files folder but did
    >> not find what I was looking for.
    > variable:
    I don't believe it! For years I've been living with the "My Virtual
    Machines" folder hidden, and with a shortcut inside it pointing to the
    desired location!
    This is much better.
    David
    Stardate 8516.8
  3. #3
    Paul Adare - MVP Guest
    > desired location!
    This is documented with the product.
    Paul Adare
    MVP - Identity Lifecycle Manager
    http://www.identit.ca
    There must be more to life than compile-and-go.
  4. #4
    >> desired location!
    And I'm the only person I know personally who has actually read any of
    the documentation, but I never noticed that before.
    As for the "I don't believe it," I was just playing off of Mark's
    comment, "You won't believe this..."
    David
    Stardate 8519.7
  5. #5
    On Tue, 08 Jul 2008 17:14:38 -0400, FACE wrote:
    > From David Trimboli <trimboli@xxxxxx>, in microsoft.public.virtualpc on
    > Tue, 08 Jul 2008 16:24:02 -0400 :
    >>>> desired location!
    > Waa'll, Whee Doggies! Don't that beat all!
    > Notes
    > Virtual PC also creates and maintains shortcut files for all registered
    > virtual machines; the shortcut files are located in the Documents and
    > Settings\user name\Application Data\Microsoft\Virtual PC folder.
    Which really has nothing at all to do with the subject at hand, namely
    changing the default location of virtual machines.
    Paul Adare
    As of next week, passwords will be entered in Morse code.
  6. #6
    On Tue, 08 Jul 2008 22:09:08 -0400, FACE wrote:
    > From Paul Adare - MVP <pkadare@xxxxxx>, in microsoft.public.virtualpc on
    > Tue, 8 Jul 2008 21:59:54 -0400 :
    >>>>>> desired location!
    >>> Notes
    > How ridiculously stuffy of you. That was the exact subject of the
    > sub-thread to which i replied.
    > Lighten up.
    No, it wasn't. This thread is about the default location of virtual
    machines and how to change the default location. What you've posted above
    has nothing to do with either the default location of the virtual machines
    nor how to change said location. If one does change the default location
    for virtual machines the shortcut location does not change.
    Please try to get your facts straight before you start calling people names
    and telling them to lighten up.
    Paul Adare
    Any program that runs right is obsolete.
  7. #7
    FACE Guest
    Tue, 8 Jul 2008 23:49:00 -0400 :
    >>>>>>> desired location!
    >>>> Notes
    >> Lighten up.
    You have a bad attitude
  8. #8
    And you're still wrong.
    Paul Adare
    Vacuum type: A derogatory term. See "bubble memory."
  9. #9
    FACE Guest
    Wed, 9 Jul 2008 07:11:41 -0400 :
    You are not a team player
  10. #10
    This isn't a team and even if it were, I still would not let erroneous
    information go uncorrected.
    Paul Adare
    No program done by an undergrad will work after she graduates.
Page 1 of 4 123 ... LastLast
Re: Default location of virtual machines problems?
Re: Virtual Machines can't see VM's on other Virtual Server Bill Grant Virtual Server 0 16 Jul 2009
Change location of "My Virtual Machines" Magnusb Virtual PC 0 16 Oct 2008
Re: Default location of virtual machines Robert Comer Virtual PC 0 07 Jul 2008
a tip for virtual machines Taibear ios Vista General 1 16 Oct 2007
RE: Default Users/My User location, is it possible to move the default to D:/ drive? William Topping Vista General 2 08 Oct 2006
