| | color with virtual pc additions Hi, I installed VP2007 on Vista Host with XP home as guest. When I install the virtual pc additions the colors get messed up (they go down to 4bit-- no other options). How can I get the regular colors back & keep the additions? |
| | RE: color with virtual pc additions Ok. Not a fix, but this worked: I uninstalled VPC2007sp1 and installed VPC2007 regular, then the additions. "plaguebearer" wrote: Quote: > Hi, I installed VP2007 on Vista Host with XP home as guest. When I install > the virtual pc additions the colors get messed up (they go down to 4bit-- no > other options). How can I get the regular colors back & keep the additions? |
| | RE: color with virtual pc additions I have experianced the excat same problem when installing the Additions with VPC 2007 SP1. Host is Vista Ultimiate, Guest is Win XP Pro. Anyone else come accross this? "plaguebearer" wrote: Quote: > Hi, I installed VP2007 on Vista Host with XP home as guest. When I install > the virtual pc additions the colors get messed up (they go down to 4bit-- no > other options). How can I get the regular colors back & keep the additions? |
| | Re: color with virtual pc additions >"plaguebearer" wrote: Quote: > Quote: >> Hi, I installed VP2007 on Vista Host with XP home as guest. When I install >> the virtual pc additions the colors get messed up (they go down to 4bit-- no >> other options). How can I get the regular colors back & keep the additions? Quote: >I have experianced the excat same problem when installing the Additions with >VPC 2007 SP1. Host is Vista Ultimiate, Guest is Win XP Pro. Anyone else >come accross this? > an XP Pro guest and all was well with the guest screen colors until I installed the additions (VS2005) when the colors dropped down to 4 bits and the resolution to someting ridiculously low. Uninstall the additions and all was fine, except of course for the missing mouse integration etc. Then I installed the VPC2007 additions instead, and these worked fine while running under VS2005. No more any color dept issue... Go figure.... |
| | RE: color with virtual pc additions Quote: > Hi, I installed VP2007 on Vista Host with XP home as guest. When I install > the virtual pc additions the colors get messed up (they go down to 4bit-- no > other options). How can I get the regular colors back & keep the additions? Display Properties > Setting Tab > Click Advanced > Click the Drivers Tab > Then Click to Uninstall It will ask to reboot... That's what worked for me. Hope this helps. Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com |
| | #6 (permalink) |
| Vista Ultimate x64 | Re: color with virtual pc additions Hi guys. I've been having this problem as well. I have Vista Ultimate x64, and I installed XP Pro 32 original as a guest in the Virtual Machine. Not SP2 or anything like that. As a final act of desperation I decided to try updating my XP guest to SP2, and voila! Straight after the reboot I had full control of my colour and resolution settings. Seems to be using the same video drivers, so I believe it may have had something to do with the default monitor it was using. So if you haven't tried this yet, give it a go and let us all know the result. I am using VPC 2007 SP1 by the way |
| Virtual PC 2007 - Install Virtual Machine Additions | Tutorials | |||
| Install Virtual Machine Additions | Virtual PC | |||
| Vista and Virtual Machine Additions | Virtual PC | |||
| Virtual Machine Display Resolution and VM Additions | Virtual PC | |||
| Uninstalling Virtual Machine Additions | Vista General | |||
