| | Running VPC from a VHD I tried to be clever and I got most of the way, but I need some help for the last leg. I am trying to run a VM from a DVD by: Creating a self-contained VM demoing our software Compressing the heck out of it Using an *.hta file to install VPC, copy the *.vmc file to a writable directory Using VBscript DOMXML to update the *.vmc file to point to the VHD running on the drive. The vhd is marked readonly We use undo disks to store the changes (possibly a differencing vhd) Here's where it gets interesting. It all works so long as its on a HDD. This makes a lot of sense. I am sure I am violating the laws of physics and good sense by trying to run it from a DVD (and storing changes on the host HDD), but here's what happens when I burn it to a dvd. The hta loads the *.vmc into VPC properly The machine starts up without a hitch Then it abruptly dies because of a Disk Read Error after the POST (inside the VM). This makes perfect sense to me. I am perfectly willing to accept this an end game, "Stop trying to run it from a DVD, idiot" scenario. However, I am curious. Is there some option I am missing? Some hidden VMC value I can flip? Some bios magic? |
| | Re: Running VPC from a VHD Where is your swap file located, on the vhd thats read only? Also where are your undo disks located? -- David Vair CNE,CNA,MCP,A+,N+ "Brian" <Brian@xxxxxx> wrote in message news 6A33465-C0B4-4EA0-9647-CB36E2BAC0EA@xxxxxxQuote: >I tried to be clever and I got most of the way, but I need some help for >the > last leg. > > I am trying to run a VM from a DVD by: > Creating a self-contained VM demoing our software > > Compressing the heck out of it > > Using an *.hta file to install VPC, copy the *.vmc file to a writable > directory > > Using VBscript DOMXML to update the *.vmc file to point to the VHD running > on the drive. > > The vhd is marked readonly > > We use undo disks to store the changes (possibly a differencing vhd) > > Here's where it gets interesting. It all works so long as its on a HDD. > This makes a lot of sense. I am sure I am violating the laws of physics > and > good sense by trying to run it from a DVD (and storing changes on the host > HDD), but here's what happens when I burn it to a dvd. > > The hta loads the *.vmc into VPC properly > The machine starts up without a hitch > Then it abruptly dies because of a Disk Read Error after the POST (inside > the VM). > > This makes perfect sense to me. I am perfectly willing to accept this an > end game, "Stop trying to run it from a DVD, idiot" scenario. However, I > am > curious. Is there some option I am missing? Some hidden VMC value I can > flip? Some bios magic? > > |
| | Re: Running VPC from a VHD On Thu, 31 Jul 2008 05:48:00 -0700, Brian <Brian@xxxxxx> wrote: Quote: >I tried to be clever and I got most of the way, but I need some help for the >last leg. > >I am trying to run a VM from a DVD by: >Creating a self-contained VM demoing our software > >Compressing the heck out of it > >Using an *.hta file to install VPC, copy the *.vmc file to a writable >directory > >Using VBscript DOMXML to update the *.vmc file to point to the VHD running >on the drive. > >The vhd is marked readonly > >We use undo disks to store the changes (possibly a differencing vhd) > >Here's where it gets interesting. It all works so long as its on a HDD. >This makes a lot of sense. I am sure I am violating the laws of physics and >good sense by trying to run it from a DVD (and storing changes on the host >HDD), but here's what happens when I burn it to a dvd. > >The hta loads the *.vmc into VPC properly >The machine starts up without a hitch >Then it abruptly dies because of a Disk Read Error after the POST (inside >the VM). > >This makes perfect sense to me. I am perfectly willing to accept this an >end game, "Stop trying to run it from a DVD, idiot" scenario. However, I am >curious. Is there some option I am missing? Some hidden VMC value I can >flip? Some bios magic? > to? What you could do is use the VHD on the DVD as a parent drive and create a differencing drive child on your local hard drive to save the changes to. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| | Re: Running VPC from a VHD To answer David and Steve: Well, you can run a readonly VHD. I successfully ran the OS using Undo disks. VPC is smart enough to store the undo disks in the run directory of the *.vmc file. In this case, the %user profile%\my documents\My Virtual Machines. As for the swap file for the vhd, it's the default. Maybe that's the deal breaker. I'm not sure how you change it (it would have to be configurable in the *.vmc to work) All I know is, you can successfully read-only VHD files (Recommended practice with differencing vhds to keep your master clean). I suspect some spooky nonsense with running from a DVD drive. "Steve Jain" wrote: Quote: > On Thu, 31 Jul 2008 05:48:00 -0700, Brian > <Brian@xxxxxx> wrote: > Quote: > >I tried to be clever and I got most of the way, but I need some help for the > >last leg. > > > >I am trying to run a VM from a DVD by: > >Creating a self-contained VM demoing our software > > > >Compressing the heck out of it > > > >Using an *.hta file to install VPC, copy the *.vmc file to a writable > >directory > > > >Using VBscript DOMXML to update the *.vmc file to point to the VHD running > >on the drive. > > > >The vhd is marked readonly > > > >We use undo disks to store the changes (possibly a differencing vhd) > > > >Here's where it gets interesting. It all works so long as its on a HDD. > >This makes a lot of sense. I am sure I am violating the laws of physics and > >good sense by trying to run it from a DVD (and storing changes on the host > >HDD), but here's what happens when I burn it to a dvd. > > > >The hta loads the *.vmc into VPC properly > >The machine starts up without a hitch > >Then it abruptly dies because of a Disk Read Error after the POST (inside > >the VM). > > > >This makes perfect sense to me. I am perfectly willing to accept this an > >end game, "Stop trying to run it from a DVD, idiot" scenario. However, I am > >curious. Is there some option I am missing? Some hidden VMC value I can > >flip? Some bios magic? > > > You can't run an OS on a read-only volume, where is it going to write > to? > What you could do is use the VHD on the DVD as a parent drive and > create a differencing drive child on your local hard drive to save the > changes to. > > -- > Cheers, > Steve Jain, Virtual Machine MVP > http://vpc.essjae.com/ > I do not work for Microsoft. > |
| | Re: Running VPC from a VHD On Thu, 31 Jul 2008 10:36:05 -0700, Brian <Brian@xxxxxx> wrote: Quote: >To answer David and Steve: > >Well, you can run a readonly VHD. I successfully ran the OS using Undo >disks. > >VPC is smart enough to store the undo disks in the run directory of the >*.vmc file. In this case, the %user profile%\my documents\My Virtual >Machines. > >As for the swap file for the vhd, it's the default. Maybe that's the deal >breaker. I'm not sure how you change it (it would have to be configurable in >the *.vmc to work) > >All I know is, you can successfully read-only VHD files (Recommended >practice with differencing vhds to keep your master clean). I suspect some >spooky nonsense with running from a DVD drive. > -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| running c++ | Software | |||
| Problems running slow after update, IE but expecially running any | Vista music pictures video | |||
| More able to directly connect an XP running computer and a Vista x64 running one | Network & Sharing | |||
| Hot running | Overclocking & Cooling | |||
| CPU running at max when running programs | Vista hardware & devices | |||
