Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Re: Microsoft Virtual Machine stopped working. please help.
Old 08-06-2008   #1 (permalink)
Gary S. Terhune
I dunno. I just thought I'd Google your problem and that one caught my eye.
I don't know a *lot* about VPC, especially not VPC running on Vista. I much
prefer multi-booting. But Permissions issues are everywhere in Windows
Vista, so I thought the article might at least put you on the right trail.
I do recommend the addition of the VPC group to this thread (which I just
did), and the cutting out of at least the two non-general XP groups and the
Vista Setup group. After all, it isn't the XP installation you're having
problems with, or even Vista Setup/Installation. Your problem is a Win2K
installation on VPC on Vista. Concentrate your efforts in those arenas.
Gary S. Terhune
MS-MVP Shell/User
http://grystmill.com
"Steven Wabik" <Stevenw45@xxxxxx> wrote in message
news:e3yanuD%23IHA.872@xxxxxx
Quote:
> well, i tried what it said in the artical and it did not work. now what?
> "Gary S. Terhune" <none> wrote in message
> news:umlvzqD%23IHA.3656@xxxxxx
Quote:
>> It's microsoft.public.virtualpc
>> Anything in that article I referenced grab you?
>> Gary S. Terhune
>> MS-MVP Shell/User
>> news:OvKc1oD%23IHA.3396@xxxxxx
Quote:
>>>I did not know that there was a vitual PC group. if i knew that, i would
>>>have posted this question in that newsgroup as well. i looked through the
>>>news groups and i did not see one for that.
>>> news:%23fI$clD%23IHA.2060@xxxxxx
>>>>I don't for the life of me understand why you included *any* XP groups,
>>>>much less three, and did NOT include the VPC group. But I thought this
>>>>might give you some hints.
>>>> http://www.gregcons.com/KateBlog/Dis...unOnVista.aspx
>>>> Gary S. Terhune
>>>> MS-MVP Shell/User
>>>> news:B38F0F43-6B81-4E13-A969-999BBAA29B3C@xxxxxx
>>>>>I need help with Microsoft virtual Machine. I setup a windows 2000 and
>>>>>a Windows XP virtual machine. I'm using them to run different
>>>>>applications that Windows Vista cannot run.
>>>>> anyways, after backing up the virtual machine files to a external hard
>>>>> drive, the windows 2000 virtual machine stopped working. does anyone
>>>>> have any seggestion for fixing it. the virtual machine witll not boot.
>>>>> when i click the "start" to start the virtual machine I just get a
>>>>> blank window.
>>>>> if i boot the XP virtual machine and have set it up so that its 2nd
>>>>> hard drive is the primary hard drive from the windows 2000 virtual
>>>>> machine. it shows that all of the files from the windows 2000 virtual
>>>>> machine are still there. does anyone have any ideas of why the windows
>>>>> 2000 virtual machine is not starting. please help me fix this.
>>>>> From,
>>>>> Steven Wabik
Old 08-07-2008   #2 (permalink)
Steven Wabik
oddly I prefer multi booting or dual booting as well, but I decided to try
this for once since my OEM provider does not support dual booting. at least
they still support Windows 2000, even on the PCs that are "Vista certified".
Most manufacturers dropped support for windows 2000 years ago. now some of
them are even dropping support for Windows XP because of Windows Vista. what
the heck is wrong with them. I just hope windows 7 is a heck of a lot better
than vista so that we can all just throw vista in the trash. yet, some of us
might still be using Windows XP for our businesses if we have to.
anyways, will someone please just help me fix this virtual PC issue that i
am having....
news:uOsFyAE%23IHA.4156@xxxxxx
> the Vista Setup group. After all, it isn't the XP installation you're
> having problems with, or even Vista Setup/Installation. Your problem is a
> Win2K installation on VPC on Vista. Concentrate your efforts in those
> arenas.
> Gary S. Terhune
> MS-MVP Shell/User
>>> Gary S. Terhune
>>> MS-MVP Shell/User
>>>>the news groups and i did not see one for that.
>>>>> Gary S. Terhune
>>>>> MS-MVP Shell/User
>>>>>> hard drive, the windows 2000 virtual machine stopped working. does
>>>>>> anyone have any seggestion for fixing it. the virtual machine witll
>>>>>> not boot. when i click the "start" to start the virtual machine I
>>>>>> just get a blank window.
>>>>>> windows 2000 virtual machine is not starting. please help me fix
>>>>>> this.
>>>>>> From,
>>>>>> Steven Wabik
Old 08-07-2008   #3 (permalink)
Gary S. Terhune
If no luck after a day or so, repost the question.
Gary S. Terhune
MS-MVP Shell/User
news:F6C22228-D941-4777-B127-D08BEBFDCE98@xxxxxx
> least they still support Windows 2000, even on the PCs that are "Vista
> certified". Most manufacturers dropped support for windows 2000 years ago.
> now some of them are even dropping support for Windows XP because of
> Windows Vista. what the heck is wrong with them. I just hope windows 7 is
> a heck of a lot better than vista so that we can all just throw vista in
> the trash. yet, some of us might still be using Windows XP for our
> am having....
>>eye. I don't know a *lot* about VPC, especially not VPC running on Vista.
>>I much prefer multi-booting. But Permissions issues are everywhere in
>>Windows Vista, so I thought the article might at least put you on the
>>right trail.
>> arenas.
>> Gary S. Terhune
>> MS-MVP Shell/User
>>>> Gary S. Terhune
>>>> MS-MVP Shell/User
>>>>>would have posted this question in that newsgroup as well. i looked
>>>>>through the news groups and i did not see one for that.
>>>>>>groups, much less three, and did NOT include the VPC group. But I
>>>>>>thought this might give you some hints.
>>>>>> Gary S. Terhune
>>>>>> MS-MVP Shell/User
>>>>>>>and a Windows XP virtual machine. I'm using them to run different
>>>>>>> virtual machine are still there. does anyone have any ideas of why
>>>>>>> the windows 2000 virtual machine is not starting. please help me fix
>>>>>>> this.
>>>>>>> From,
>>>>>>> Steven Wabik
Old 08-07-2008   #4 (permalink)
Bill Grant
>>>>>>> this.
>>>>>>> From,
>>>>>>> Steven Wabik
The first thing I would try would be to delete the .vmc file for the w2k
vm and try to create a new virtual machine (from the new virtual machine
wizard) linked to the existing .vhd file.
Old 08-07-2008   #5 (permalink)
Gary S. Terhune
Steven, even though he was a jerk, Jack caused me to flash on the reason you
couldn't find microsoft.public.virtualpc is probably because it isn't
included on your ISP's news server (or whatever posting host you're using,
and in your case it looks like a different one each time.)
Try msnews.microsoft.com (no username/password required.) And STOP using
your real email address in news posts. No quicker way to get onto SPAM
mailing lists. Don't use one that could possibly be someone else's, but more
along the lines of notme@xxxxxx In OE, it doesn't even need to be in
email address format using the @, but I was using <none> for a log time and
recently a bunch of my posts got deleted from the server, probably because
that <none> triggered some stupid attempt at SPAM filtering.
Gary S. Terhune
MS-MVP Shell/User
> am having....
>>right trail.
>> arenas.
>> Gary S. Terhune
>> MS-MVP Shell/User
>>>> Gary S. Terhune
>>>> MS-MVP Shell/User
>>>>>> Gary S. Terhune
>>>>>> MS-MVP Shell/User
>>>>>>> this.
>>>>>>> From,
>>>>>>> Steven Wabik
Old 08-07-2008   #6 (permalink)
Steven Wabik
well, I got good news, I some how fixed the windows 2000 virtual machine. I
found a 2nd backup of the virtual machine that I never remembered creating
in the first place...
the odd thing was that the backup of the .vhd file was on the drive that I
used to create the .vhd image in the first place, so I have no idea of how
it got there. and the other hard drive that I backed up the .vhd hard drive
file to, well somehow the file got corrupted to the point where it could not
boot.
now i'm just happy that I found a backup of the file. its just to bad it was
the original version of the file that was created and not the most recent
version of the backup. but hey, its better than nothing.
now i just have to find a way to stop these files to stop corrupting
themselves in the first place and if i cannot find a way to do that, I need
to find a way to recover the files. afterall the corruption was caused by
trying to backup the .vhd files in the first place. any ideas?
From,
Steven Wabik
"Bill Grant" <not.available@xxxxxx> wrote in message
news:%23CfvgjE%23IHA.3392@xxxxxx
>>>>>>>> fix this.
>>>>>>>> From,
>>>>>>>> Steven Wabik
Old 08-07-2008   #7 (permalink)
Robert Comer
Make sure your AV or backup software is set to ignore the .vhd files,
that's one of the biggest causes of corrupted VM's that I've seen.
I've also seen corrupted copies when backing up VM's to USB drives and
I'm not sure what to say except have more than 1 backup if that's how
you're backing it up.
I'm afraid that recovering a vhd after corruption is not a real doable
thing, it's just like the hard drive went out on a real PC and
corruption can run pretty deep. You may be able to copy files off of
it by attaching it to a working VM, but that's about it.
Bob Comer <Microsoft MVP Windows - Virtual Machine>
On Thu, 7 Aug 2008 17:06:53 -0400, "Steven Wabik"
>boot.
>From,
>Steven Wabik
>>>>>>>>> fix this.
>>>>>>>>> From,
>>>>>>>>> Steven Wabik
Old 08-07-2008   #8 (permalink)
FACE
On Thu, 7 Aug 2008 17:06:53 -0400, in microsoft.public.virtualpc,
>boot.
A straight copy seems to work very well. Also, I have used pkzip and rar
and f7 (zip) on them with no ill effects. I have, but have not used, the
pre-compactor. Maybe I was lucky? ;-) As far as corrupting in place,
vista VHDs seem pretty finicky and though I have not had any go to 'not
bootable' , I have had them degrade in performance and a windows VM
undocumented excursion that had worked fine with previous Windows VMs,
including the NT kernel ones, balked badly on a Vista VM.
(Vista is a curse)
FACE
Quote:
>From,
>Steven Wabik
>>>>>>>>> fix this.
>>>>>>>>> From,
>>>>>>>>> Steven Wabik
Old 08-07-2008   #9 (permalink)
Gary S. Terhune
How are you "backing up" these files? You haven't really said.
Don't bother to answer if you still think I'm should be damned. I'm a
volunteer here, one that has given you assistance for no reason other than I
like helping people and solving problems. But I didn't insult you in the
slightest and I believe you owe ME an apology, which I will accept because I
recognize that you made a stupid mistake.
Gary S. Terhune
MS-MVP Shell/User
news:F9C05790-9F6A-4AC2-B56A-7501D063330A@xxxxxx
> I found a 2nd backup of the virtual machine that I never remembered
> creating in the first place...
> drive file to, well somehow the file got corrupted to the point where it
> could not boot.
> was the original version of the file that was created and not the most
> recent version of the backup. but hey, its better than nothing.
> need to find a way to recover the files. afterall the corruption was
> caused by trying to backup the .vhd files in the first place. any ideas?
> From,
> Steven Wabik
>>>>>>>>> witll not boot. when i click the "start" to start the virtual
>>>>>>>>> machine I just get a blank window.
>>>>>>>>> 2nd hard drive is the primary hard drive from the windows 2000
>>>>>>>>> virtual machine. it shows that all of the files from the windows
>>>>>>>>> 2000 virtual machine are still there. does anyone have any ideas
>>>>>>>>> of why the windows 2000 virtual machine is not starting. please
>>>>>>>>> help me fix this.
>>>>>>>>> From,
>>>>>>>>> Steven Wabik
>> w2k vm and try to create a new virtual machine (from the new virtual
>> machine wizard) linked to the existing .vhd file.
Old 08-07-2008   #10 (permalink)
Steven Wabik
yea, vita does have its issues, thats why I am going to upgrade to windows 7
when it comes out. thank goodness I am able to beta test this new operating
system. so far it works better than vista. when windows 7 comes out vista is
gone.
for the older operating systems, I may just use them in virtual machine, or
use them in a dual boot. it just depends on the applications that i will be
using with that specific operating system.
"FACE" <AFaceInTheCrowd@xxxxxx> wrote in message
news:f8um949rhlalvqruk4gnm9c5o43kvi5mfv@xxxxxx
>>I
>>drive
>>not
>>boot.
>>was
>>need
> (Vista is a curse)
> FACE
Quote:
>>From,
>>Steven Wabik
>>>>>>>>>> does
>>>>>>>>>> witll
>>>>>>>>>> 2nd
>>>>>>>>>> virtual
>>>>>>>>>> why
>>>>>>>>>> fix this.
>>>>>>>>>> From,
>>>>>>>>>> Steven Wabik
>>> w2k
Microsoft Hyper-V Server 2008 - create virtual machine Virtual Server
Microsoft Virtual Machine stopped working. please help. Vista installation & setup
Microsoft Virtual Machine stopped working. please help. Vista General
Microsoft Virtual Machine Vista performance & maintenance
Visa installation and Microsoft Virtual Machine Vista installation & setup
