| Guest | running Dos 6.2 inside Virtual PC I set up VPC (6.0.192.0) and linked my virtual disk via the import wizard and it imported the disk, but I dose not find the system. I 'sys'ed a floppy disk and copied Sys.com to it. When I start the vpc it won't find the system on the vir disk, but If I have the floppy with the system in the floppy drive it will find it and boot successfully. I can use the vpc and run the programs that it had on it. Now I should be able to Sys the C: drive and it states "system transferred successfully" But when I restart the vpc it fails to find any OS. How can I get the sys back on the virt drive ? Thanks |
| Guest | Re: running Dos 6.2 inside Virtual PC Did you FDISK (partition the disk) and FORMAT the C: drive? -- Bob Comer On Fri, 15 Aug 2008 10:22:24 -0700 (PDT), sid <sidwelle@xxxxxx> wrote: Quote: >I set up VPC (6.0.192.0) and linked my virtual disk via the import >wizard and it imported the disk, but I dose not find the system. > >I 'sys'ed a floppy disk and copied Sys.com to it. When I start the >vpc it won't find the system on the vir disk, but If I have the floppy >with the system in the floppy drive it will find it and boot >successfully. I can use the vpc and run the programs that it had on >it. > >Now I should be able to Sys the C: drive and it states "system >transferred successfully" >But when I restart the vpc it fails to find any OS. > >How can I get the sys back on the virt drive ? > >Thanks > > > > |
| Guest | Re: running Dos 6.2 inside Virtual PC On Fri, 15 Aug 2008 10:22:24 -0700 (PDT), sid <sidwelle@xxxxxx> wrote: Quote: >I set up VPC (6.0.192.0) and linked my virtual disk via the import >wizard and it imported the disk, but I dose not find the system. > >I 'sys'ed a floppy disk and copied Sys.com to it. When I start the >vpc it won't find the system on the vir disk, but If I have the floppy >with the system in the floppy drive it will find it and boot >successfully. I can use the vpc and run the programs that it had on >it. > >Now I should be able to Sys the C: drive and it states "system >transferred successfully" >But when I restart the vpc it fails to find any OS. > >How can I get the sys back on the virt drive ? > >Thanks > -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| Guest | Re: running Dos 6.2 inside Virtual PC On Aug 15, 2:41*pm, Steve Jain <norepl...@-.essjae.com> wrote: Quote: > On Fri, 15 Aug 2008 10:22:24 -0700 (PDT), sid <sidwe...@xxxxxx> > wrote: > > > > > Quote: > >I set up VPC (6.0.192.0) and linked my virtual disk via the import > >wizard and it imported the disk, but I dose not find the system. Quote: > >I 'sys'ed a floppy disk and copied Sys.com to it. *When I start the > >vpc it won't find the system on the vir disk, but If I have the floppy > >with the system in the floppy drive it will find it and boot > >successfully. *I *can use the vpc and run the programs that it had on > >it. Quote: > >Now I should be able to Sys the C: drive and it states "system > >transferred successfully" > >But when I restart the vpc it fails to find any OS. Quote: > >How can I get the sys back *on the virt drive ? Quote: > >Thanks > Run FDISK and make sure that the partition is set to be active. > > -- > Cheers, > Steve Jain, Virtual Machine MVPhttp://vpc.essjae.com/ > I do not work for Microsoft.- Hide quoted text - > > - Show quoted text - It shows only one partition and at the bottom it reads: "The only startable partition on Drive 1 is already set active." |
| Guest | Re: running Dos 6.2 inside Virtual PC "sid" <sidwelle@xxxxxx> wrote in message news:a8f183b9-60e5-4841-b575-6f9d6817f61e@xxxxxx Quote: > Ran 'Fdisk' and selected option '2. Set active partition' > > It shows only one partition and at the bottom it reads: > "The only startable partition on Drive 1 is already set active." 2) As soon as the boot process starts, hit the Delete key to enter the BIOS 3) Using the arrow keys, move the the Boot tab and hit Enter to enter the Boot Device Priority tab What do you see in priorities 1 to 4...? It's a huge long shot, but I'm wondering whether somehow the virtual hard disk is no longer configured as a bootable device in the virtual machine's BIOS... -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #6 (permalink) |
| Guest | Re: running Dos 6.2 inside Virtual PC On Aug 15, 5:02*pm, "Mark Rae [MVP]" <m...@xxxxxx> wrote: Quote: > "sid" <sidwe...@xxxxxx> wrote in message > > news:a8f183b9-60e5-4841-b575-6f9d6817f61e@xxxxxx > Quote: > > Ran 'Fdisk' and selected option '2. *Set active partition' Quote: > > It shows only one partition and at the bottom it reads: > > "The only startable partition on Drive 1 is already set active." > 1) Reboot the VM > > 2) As soon as the boot process starts, hit the Delete key to enter the BIOS > > 3) Using the arrow keys, move the the Boot tab and hit Enter to enter the > Boot Device Priority tab > > What do you see in priorities 1 to 4...? > > It's a huge long shot, but I'm wondering whether somehow the virtual hard > disk is no longer configured as a bootable device in the virtual machine's > BIOS... > > -- > Mark Rae > ASP.NET MVPhttp://www.markrae.net virt bios is there. I created a new VM and new VHD and then format /s to get a good format and a system transfer the way that it wanted it. Then create a 2nd temp VHD attach it to the original VM and Xcopy the whole drive to it. Turn off that VM, attach the 2nd temp VHD to the new VM and start, xcopy all that stuff back to the new VHD. Stop, start, boots correctly ... One question though, On the first xcopy from the original vhd created by the disk wizard I got a couple of read failures, "could not read from sector, fail, ignore, abort ... " I ignored twice and the copy went on, and I noticed that the folder that was currently being copied was probably not used any more. But why did that happen ? Shouldn't the disk wizard checked all that stuff on the way in or did it just perform a image copy ? Thanks Sid. |
| | #7 (permalink) |
| Guest | Re: running Dos 6.2 inside Virtual PC On Fri, 15 Aug 2008 15:25:38 -0700 (PDT), sid <sidwelle@xxxxxx> wrote: Quote: >On Aug 15, 5:02*pm, "Mark Rae [MVP]" <m...@xxxxxx> wrote: Quote: >> "sid" <sidwe...@xxxxxx> wrote in message >> >> news:a8f183b9-60e5-4841-b575-6f9d6817f61e@xxxxxx >> Quote: >> > Ran 'Fdisk' and selected option '2. *Set active partition' Quote: >> > It shows only one partition and at the bottom it reads: >> > "The only startable partition on Drive 1 is already set active." >> 1) Reboot the VM >> >> 2) As soon as the boot process starts, hit the Delete key to enter the BIOS >> >> 3) Using the arrow keys, move the the Boot tab and hit Enter to enter the >> Boot Device Priority tab >> >> What do you see in priorities 1 to 4...? >> >> It's a huge long shot, but I'm wondering whether somehow the virtual hard >> disk is no longer configured as a bootable device in the virtual machine's >> BIOS... >> >> -- >> Mark Rae >> ASP.NET MVPhttp://www.markrae.net >virt bios is there. > >I created a new VM and new VHD and then format /s to get a good format >and a system transfer the way that it wanted it. Then create a 2nd >temp VHD attach it to the original VM and Xcopy the whole drive to it. >Turn off that VM, attach the 2nd temp VHD to the new VM and start, >xcopy all that stuff back to the new VHD. Stop, start, boots >correctly ... > >One question though, On the first xcopy from the original vhd created >by the disk wizard I got a couple of read failures, "could not read >from sector, fail, ignore, abort ... " I ignored twice and the copy >went on, and I noticed that the folder that was currently being copied >was probably not used any more. But why did that happen ? Shouldn't >the disk wizard checked all that stuff on the way in or did it just >perform a image copy ? > >Thanks > >Sid. in order for it to boot. Copying boot files does not make an HD bootable, only format /s or SYS C: will do that. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| | #8 (permalink) |
| Guest | Re: running Dos 6.2 inside Virtual PC On Aug 15, 5:51*pm, Steve Jain <norepl...@-.essjae.com> wrote: Quote: > On Fri, 15 Aug 2008 15:25:38 -0700 (PDT), sid <sidwe...@xxxxxx> > wrote: > > > > > Quote: > >On Aug 15, 5:02*pm, "Mark Rae [MVP]" <m...@xxxxxx> wrote: Quote: > >> "sid" <sidwe...@xxxxxx> wrote in message Quote: Quote: > >>news:a8f183b9-60e5-4841-b575-6f9d6817f61e@xxxxxx Quote: Quote: > >> > Ran 'Fdisk' and selected option '2. *Set active partition' Quote: Quote: > >> > It shows only one partition and at the bottom it reads: > >> > "The only startable partition on Drive 1 is already set active." Quote: Quote: > >> 1) Reboot the VM Quote: Quote: > >> 2) As soon as the boot process starts, hit the Delete key to enter theBIOS Quote: Quote: > >> 3) Using the arrow keys, move the the Boot tab and hit Enter to enter the > >> Boot Device Priority tab Quote: Quote: > >> What do you see in priorities 1 to 4...? Quote: Quote: > >> It's a huge long shot, but I'm wondering whether somehow the virtual hard > >> disk is no longer configured as a bootable device in the virtual machine's > >> BIOS... Quote: Quote: > >> -- > >> Mark Rae > >> ASP.NET MVPhttp://www.markrae.net > >virt bios is there. Quote: > >I created a new VM and new VHD and then format /s to get a good format > >and a system transfer the way that it wanted it. *Then create a 2nd > >temp VHD attach it to the original VM and Xcopy the whole drive to it. > >Turn off that VM, attach the 2nd temp VHD to the new VM and start, > >xcopy all that stuff back to the new VHD. *Stop, start, boots > >correctly ... Quote: > >One question though, On the first xcopy from the original vhd created > >by the disk wizard I got a couple of read failures, "could not read > >from sector, fail, ignore, abort ... " *I ignored twice and the copy > >went on, and I noticed that the folder that was currently being copied > >was probably not used any more. But why did that happen ? * Shouldn't > >the disk wizard checked all that stuff on the way in or did it just > >perform a image copy ? Quote: > >Thanks Quote: > >Sid. > If you xcopy files you still need to run the SYS command on the drive > in order for it to boot. *Copying boot files does not make an HD > bootable, only format /s or SYS C: will do that. > > -- > Cheers, > Steve Jain, Virtual Machine MVPhttp://vpc.essjae.com/ > I do not work for Microsoft.- Hide quoted text - > > - Show quoted text - But how did I get sector read fails from a virtual disk ? |
| | #9 (permalink) |
| Guest | Re: running Dos 6.2 inside Virtual PC On Fri, 15 Aug 2008 16:40:08 -0700 (PDT), sid <sidwelle@xxxxxx> wrote: Quote: > >Thats what I did. > >But how did I get sector read fails from a virtual disk ? Weird things happen with computers ![]() -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| Running a command from inside a script, command line is corrupted | PowerShell | |||
| RE: Running OS X on Virtual PC | Virtual PC | |||
| Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 | Virtual Server | |||
| Virtual Server inside Virtual PC | Virtual Server | |||
| what is this virtual inside vista? | Vista General | |||
