| Vista Ultimate x64 | VPC 2007 installation problems Hello all, I just bought me a brand new computer and installed Vista Ultimate x64 on it (amongst others). Now I also want to install VPC 2007 on it and for some reason it just fails. No reason given whatsoever. It installs perfectly untill 95% or so and then starts a rollback. After that it tells me that it couldn't be installed but that I should try later. Which I did... several times, but it just won't get installed... I searched all over the web for a couple of days now, but I can't seem to find anyone with the same problem and with a solution... So I thought I'd ask you guys and hope someone has a solution for me. Greetings, Erwin "Sinedia" de Ruiter |
| Vista Ultimate 32-bit | Re: VPC 2007 installation problems Did you download VPC 2007 SP1? Also, you should take a look at the Release Notes for it: Download details: Virtual PC 2007 SP1 Release Notes |
| | Re: VPC 2007 installation problems "LeeTutor" wrote: Quote: > > Did you download VPC 2007 SP1? Also, you should take a look at the > Release Notes for it: > > 'Download details: Virtual PC 2007 SP1 Release Notes' > (http://www.microsoft.com/downloads/d...displaylang=en) > > > -- > LeeTutor > |
| | Re: VPC 2007 installation problems I cant install vpc 2007 sp1 on my vista business 64. It tells me that the wizard was aborted but i didnt do anything to cancel. Eventlogs just tells event 1063. Dont what that means. Quote: > > > "LeeTutor" wrote: > Quote: > > > > Did you download VPC 2007 SP1? Also, you should take a look at the > > Release Notes for it: > > > > 'Download details: Virtual PC 2007 SP1 Release Notes' > > (http://www.microsoft.com/downloads/d...displaylang=en) > > > > > > -- > > LeeTutor > > |
| Vista Ultimate 32-bit | Re: VPC 2007 installation problems From looking around the internet, I think the VPC 2007 installation log will be here: C:\Users\<your account name>\AppData\Local\Temp\VPCInstallLog.txt Can you search for it and see if it exists? Also, I wonder if you've tried installing VPC 2007 in safe mode? Or in normal mode with all your normal startup programs disabled using MSCONFIG.EXE? |
| | #6 (permalink) |
| | Re: VPC 2007 installation problems I have the same issue as the OP. First, the 32 bit installer fails much eariler than the 64-bit one, with a different message. Second, for some reason when I try to change the path of installation, the installer crashes. Any Ideas? Etsp === Verbose logging started: 10/12/2008 14:49:07 Build type: SHIP UNICODE 4.00.6001.00 Calling process: C:\Windows\system32\msiexec.exe === MSI (c) (2C:B0) [14:49:07:732]: Resetting cached policy values MSI (c) (2C:B0) [14:49:07:732]: Machine policy value 'Debug' is 0 MSI (c) (2C:B0) [14:49:07:733]: ******* RunEngine: ******* Product: C:\Users\CUBBAV~1\AppData\Local\Temp\Virtual_PC_2007_Install.msi ******* Action: ******* CommandLine: ********** MSI (c) (2C:B0) [14:49:07:739]: Machine policy value 'DisableUserInstalls' is 0 MSI (c) (2C:B0) [14:49:07:753]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2 MSI (c) (2C:B0) [14:49:07:804]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\CUBBAV~1\AppData\Local\Temp\Virtual_PC_2007_Install.msi' against software restriction policy MSI (c) (2C:B0) [14:49:07:804]: SOFTWARE RESTRICTION POLICY: C:\Users\CUBBAV~1\AppData\Local\Temp\Virtual_PC_2007_Install.msi has a digital signature MSI (c) (2C:B0) [14:49:07:987]: SOFTWARE RESTRICTION POLICY: C:\Users\CUBBAV~1\AppData\Local\Temp\Virtual_PC_2007_Install.msi is permitted to run at the 'unrestricted' authorization level. MSI (c) (2C:B0) [14:49:07:990]: Cloaking enabled. MSI (c) (2C:B0) [14:49:07:991]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (2C:B0) [14:49:07:994]: End dialog not enabled MSI (c) (2C:B0) [14:49:07:994]: Original package ==> C:\Users\CUBBAV~1\AppData\Local\Temp\Virtual_PC_2007_Install.msi MSI (c) (2C:B0) [14:49:07:994]: Package we're running from ==> C:\Users\CUBBAV~1\AppData\Local\Temp\2887eec.msi MSI (c) (2C:B0) [14:49:07:997]: APPCOMPAT: looking for appcompat database entry with ProductCode '{AD483998-2E9A-4405-83FF-6E503AF49CBB}'. MSI (c) (2C:B0) [14:49:07:997]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (2C:B0) [14:49:07:998]: MSCOREE not loaded loading copy from system32 MSI (c) (2C:B0) [14:49:08:000]: Machine policy value 'TransformsSecure' is 0 MSI (c) (2C:B0) [14:49:08:000]: User policy value 'TransformsAtSource' is 0 MSI (c) (2C:B0) [14:49:08:000]: Machine policy value 'DisablePatch' is 0 MSI (c) (2C:B0) [14:49:08:000]: Machine policy value 'AllowLockdownPatch' is 0 MSI (c) (2C:B0) [14:49:08:000]: Machine policy value 'DisableLUAPatching' is 0 MSI (c) (2C:B0) [14:49:08:001]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (c) (2C:B0) [14:49:08:001]: APPCOMPAT: looking for appcompat database entry with ProductCode '{AD483998-2E9A-4405-83FF-6E503AF49CBB}'. MSI (c) (2C:B0) [14:49:08:001]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (2C:B0) [14:49:08:001]: Transforms are not secure. MSI (c) (2C:B0) [14:49:08:001]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\CUBBAV~1\AppData\Local\Temp\VPCInstallLog.txt'. MSI (c) (2C:B0) [14:49:08:001]: Command Line: CURRENTDIRECTORY=C:\Program Files (x86)\Mozilla Firefox CLIENTUILEVEL=0 CLIENTPROCESSID=4908 MSI (c) (2C:B0) [14:49:08:001]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{09FDA291-9AE5-41F1-AF24-FA30640E61F3}'. MSI (c) (2C:B0) [14:49:08:001]: Product Code passed to Engine.Initialize: '' MSI (c) (2C:B0) [14:49:08:001]: Product Code from property table before transforms: '{AD483998-2E9A-4405-83FF-6E503AF49CBB}' MSI (c) (2C:B0) [14:49:08:001]: Product Code from property table after transforms: '{AD483998-2E9A-4405-83FF-6E503AF49CBB}' MSI (c) (2C:B0) [14:49:08:001]: Product not registered: beginning first-time install MSI (c) (2C:B0) [14:49:08:001]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'. MSI (c) (2C:B0) [14:49:08:001]: Entering CMsiConfigurationManager::SetLastUsedSource. MSI (c) (2C:B0) [14:49:08:001]: User policy value 'SearchOrder' is 'nmu' MSI (c) (2C:B0) [14:49:08:001]: Adding new sources is allowed. MSI (c) (2C:B0) [14:49:08:001]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'. MSI (c) (2C:B0) [14:49:08:002]: Package name extracted from package path: 'Virtual_PC_2007_Install.msi' MSI (c) (2C:B0) [14:49:08:002]: Package to be registered: 'Virtual_PC_2007_Install.msi' MSI (c) (2C:B0) [14:49:08:002]: Note: 1: 2262 2: AdminProperties 3: -2147287038 MSI (c) (2C:B0) [14:49:08:002]: Machine policy value 'DisableMsi' is 0 MSI (c) (2C:B0) [14:49:08:002]: Machine policy value 'AlwaysInstallElevated' is 0 MSI (c) (2C:B0) [14:49:08:002]: User policy value 'AlwaysInstallElevated' is 0 MSI (c) (2C:B0) [14:49:08:002]: Running product '{AD483998-2E9A-4405-83FF-6E503AF49CBB}' with user privileges: It's not assigned. MSI (c) (2C:B0) [14:49:08:002]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Program Files (x86)\Mozilla Firefox'. MSI (c) (2C:B0) [14:49:08:002]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'. MSI (c) (2C:B0) [14:49:08:002]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4908'. MSI (c) (2C:B0) [14:49:08:002]: TRANSFORMS property is now: MSI (c) (2C:B0) [14:49:08:002]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'. MSI (c) (2C:B0) [14:49:08:002]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\Favorites MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Network Shortcuts MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\Documents MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Printer Shortcuts MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Recent MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\SendTo MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Templates MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\ProgramData MSI (c) (2C:B0) [14:49:08:003]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Local MSI (c) (2C:B0) [14:49:08:004]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\Pictures MSI (c) (2C:B0) [14:49:08:004]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools MSI (c) (2C:B0) [14:49:08:004]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup MSI (c) (2C:B0) [14:49:08:004]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Start Menu\Programs MSI (c) (2C:B0) [14:49:08:004]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Start Menu MSI (c) (2C:B0) [14:49:08:004]: SHELL32::SHGetFolderPath returned: C:\Users\Cubbavich\Desktop MSI (c) (2C:B0) [14:49:08:005]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools MSI (c) (2C:B0) [14:49:08:005]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup MSI (c) (2C:B0) [14:49:08:005]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs MSI (c) (2C:B0) [14:49:08:005]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu MSI (c) (2C:B0) [14:49:08:005]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop MSI (c) (2C:B0) [14:49:08:005]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts MSI (c) (2C:B0) [14:49:08:006]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 20 MSI (c) (2C:B0) [14:49:08:007]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated. MSI (c) (2C:B0) [14:49:08:007]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'. MSI (c) (2C:B0) [14:49:08:007]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'. MSI (c) (2C:B0) [14:49:08:008]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (c) (2C:B0) [14:49:08:008]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Cubbavich'. MSI (c) (2C:B0) [14:49:08:008]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (c) (2C:B0) [14:49:08:008]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\CUBBAV~1\AppData\Local\Temp\2887eec.msi'. MSI (c) (2C:B0) [14:49:08:008]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\CUBBAV~1\AppData\Local\Temp\Virtual_PC_2007_Install.msi'. MSI (c) (2C:B0) [14:49:08:008]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\CUBBAV~1\AppData\Local\Temp\'. MSI (c) (2C:B0) [14:49:08:008]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\CUBBAV~1\AppData\Local\Temp\'. MSI (c) (2C:A4) [14:49:08:009]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '4.00'. === Logging started: 10/12/2008 14:49:08 === MSI (c) (2C:B0) [14:49:08:015]: Note: 1: 2205 2: 3: PatchPackage MSI (c) (2C:B0) [14:49:08:015]: Machine policy value 'DisableRollback' is 0 MSI (c) (2C:B0) [14:49:08:015]: User policy value 'DisableRollback' is 0 MSI (c) (2C:B0) [14:49:08:015]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'. MSI (c) (2C:B0) [14:49:08:017]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'. MSI (c) (2C:B0) [14:49:08:017]: Doing action: INSTALL Action 14:49:08: INSTALL. Action start 14:49:08: INSTALL. MSI (c) (2C:B0) [14:49:08:018]: UI Sequence table 'InstallUISequence' is present and populated. MSI (c) (2C:B0) [14:49:08:018]: Running UISequence MSI (c) (2C:B0) [14:49:08:018]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'. MSI (c) (2C:B0) [14:49:08:018]: Doing action: System64Folder.39208430_EC19_4524_A1F7_E7CE3D8BAE82 Action 14:49:08: System64Folder.39208430_EC19_4524_A1F7_E7CE3D8BAE82. Action start 14:49:08: System64Folder.39208430_EC19_4524_A1F7_E7CE3D8BAE82. MSI (c) (2C:B0) [14:49:08:019]: PROPERTY CHANGE: Adding System64Folder.39208430_EC19_4524_A1F7_E7CE3D8BAE82 property. Its value is 'C:\Windows\system32\'. Action ended 14:49:08: System64Folder.39208430_EC19_4524_A1F7_E7CE3D8BAE82. Return value 1. MSI (c) (2C:B0) [14:49:08:019]: Doing action: WindowsFolder.39208430_EC19_4524_A1F7_E7CE3D8BAE82 Action 14:49:08: WindowsFolder.39208430_EC19_4524_A1F7_E7CE3D8BAE82. Action start 14:49:08: WindowsFolder.39208430_EC19_4524_A1F7_E7CE3D8BAE82. MSI (c) (2C:B0) [14:49:08:020]: PROPERTY CHANGE: Adding WindowsFolder.39208430_EC19_4524_A1F7_E7CE3D8BAE82 property. Its value is 'C:\Windows\'. Action ended 14:49:08: WindowsFolder.39208430_EC19_4524_A1F7_E7CE3D8BAE82. Return value 1. MSI (c) (2C:B0) [14:49:08:020]: Doing action: AppSearch Action 14:49:08: AppSearch. Searching for installed components... Action start 14:49:08: AppSearch. AppSearch: VPC2004INSTALLED AppSearch: ERROR_MUST_UNINSTALL_TRIAL AppSearch: ERROR_MUST_UNINSTALL_TRIAL AppSearch: ERROR_MUST_UNINSTALL AppSearch: ERROR_MUST_UNINSTALL AppSearch: ERROR_MUST_UNINSTALL_VS_PREVIEW Action ended 14:49:08: AppSearch. Return value 1. MSI (c) (2C:B0) [14:49:08:024]: Doing action: CA_CheckOldInstallForAllUsers Action 14:49:08: CA_CheckOldInstallForAllUsers. Action start 14:49:08: CA_CheckOldInstallForAllUsers. MSI (c) (2C:B8) [14:49:08:028]: Invoking remote custom action. DLL: C:\Users\CUBBAV~1\AppData\Local\Temp\MSI8007.tmp, Entrypoint: CheckOldInstallForAllUsers MSI (c) (2C:28) [14:49:08:029]: Cloaking enabled. MSI (c) (2C:28) [14:49:08:029]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (2C:28) [14:49:08:029]: Connected to service for CA interface. Action ended 14:49:08: CA_CheckOldInstallForAllUsers. Return value 1. MSI (c) (2C:B0) [14:49:08:078]: Doing action: FindRelatedProducts Action 14:49:08: FindRelatedProducts. Searching for related applications Action start 14:49:08: FindRelatedProducts. Action ended 14:49:08: FindRelatedProducts. Return value 1. MSI (c) (2C:B0) [14:49:08:079]: Skipping action: Error_FutureBuildInstalled (condition is false) MSI (c) (2C:B0) [14:49:08:079]: Doing action: ValidateProductID Action 14:49:08: ValidateProductID. Action start 14:49:08: ValidateProductID. Action ended 14:49:08: ValidateProductID. Return value 1. MSI (c) (2C:B0) [14:49:08:080]: Doing action: CostInitialize Action 14:49:08: CostInitialize. Computing space requirements Action start 14:49:08: CostInitialize. MSI (c) (2C:B0) [14:49:08:080]: Machine policy value 'MaxPatchCacheSize' is 10 MSI (c) (2C:B0) [14:49:08:082]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'G:\'. MSI (c) (2C:B0) [14:49:08:082]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'. Action ended 14:49:08: CostInitialize. Return value 1. MSI (c) (2C:B0) [14:49:08:083]: Doing action: FileCost Action 14:49:08: FileCost. Computing space requirements Action start 14:49:08: FileCost. MSI (c) (2C:B0) [14:49:08:083]: Note: 1: 2205 2: 3: MsiAssembly MSI (c) (2C:B0) [14:49:08:083]: Note: 1: 2205 2: 3: Class MSI (c) (2C:B0) [14:49:08:083]: Note: 1: 2205 2: 3: Extension MSI (c) (2C:B0) [14:49:08:083]: Note: 1: 2205 2: 3: TypeLib Action ended 14:49:08: FileCost. Return value 1. MSI (c) (2C:B0) [14:49:08:083]: Doing action: CostFinalize Action 14:49:08: CostFinalize. Computing space requirements Action start 14:49:08: CostFinalize. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'. MSI (c) (2C:B0) [14:49:08:084]: Note: 1: 2205 2: 3: Patch MSI (c) (2C:B0) [14:49:08:084]: Note: 1: 2205 2: 3: Condition MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'G:\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding VIRTUALPCINSTALLDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding VMMDRIVERDIRECTORY.39208430_EC19_4524_A1F7_E7CE3D8BAE82 property. Its value is 'C:\Windows\system32\Drivers\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding UTILITYDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Utility\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding VMNETSRVDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Utility\VMNetSrv\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding VPCNETDRIVERDIRECTORY.E52D3A36_FBCC_4151_8571_C76B1AD08115 property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Utility\VMNetSrv\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding VPCNETDRIVERS64.E52D3A36_FBCC_4151_8571_C76B1AD08115 property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Utility\VMNetSrv\x64\'. MSI (c) (2C:B0) [14:49:08:084]: PROPERTY CHANGE: Adding DrWatsonItalianFolder property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\1040\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding DOCSDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Documentation\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding SPANISHREADMEDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Documentation\Spanish\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding JAPANESEREADMEDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Documentation\Japanese\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding ITALIANREADMEDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Documentation\Italian\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding GERMANREADMEDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Documentation\German\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding FRENCHREADMEDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Documentation\French\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding ENGLISHREADMEDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Documentation\English\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding ADDITIONSDIRECTORY property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\Virtual Machine Additions\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding DrWatsonJapaneseFolder property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\1041\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding DrWatsonSpanishFolder property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\3082\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding DrWatsonEnglishFolder property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\1033\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding DrWatsonGermanFolder property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\1031\'. MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding DrWatsonFrenchFolder property. Its value is 'C:\Program Files (x86)\Microsoft Virtual PC\1036\'. MSI (c) (2C:B0) [14:49:08:085]: Target path resolution complete. Dumping Directory table... MSI (c) (2C:B0) [14:49:08:085]: Note: target paths subject to change (via custom actions or browsing) MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: TARGETDIR , Object: G:\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: ProgramMenuFolder , Object: C:\Users\Cubbavich\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: WindowsFolder , Object: C:\Windows\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: SystemFolder , Object: C:\Windows\SysWOW64\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files (x86)\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: VIRTUALPCINSTALLDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: INSTALLDIR , Object: C:\Program Files (x86)\Microsoft Virtual PC\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: WindowsFolder.39208430_EC19_4524_A1F7_E7CE3D8BAE82 , Object: C:\Windows\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: System64Folder.39208430_EC19_4524_A1F7_E7CE3D8BAE82 , Object: C:\Windows\system32\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: VMMDRIVERDIRECTORY.39208430_EC19_4524_A1F7_E7CE3D8BAE82 , Object: C:\Windows\system32\Drivers\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: UTILITYDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Utility\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: VMNETSRVDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Utility\VMNetSrv\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: VPCNETDRIVERDIRECTORY.E52D3A36_FBCC_4151_8571_C76B1AD08115 , Object: C:\Program Files (x86)\Microsoft Virtual PC\Utility\VMNetSrv\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: VPCNETDRIVERS64.E52D3A36_FBCC_4151_8571_C76B1AD08115 , Object: C:\Program Files (x86)\Microsoft Virtual PC\Utility\VMNetSrv\x64\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: DrWatsonItalianFolder , Object: C:\Program Files (x86)\Microsoft Virtual PC\1040\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: DOCSDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Documentation\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: SPANISHREADMEDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Documentation\Spanish\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: JAPANESEREADMEDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Documentation\Japanese\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: ITALIANREADMEDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Documentation\Italian\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: GERMANREADMEDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Documentation\German\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: FRENCHREADMEDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Documentation\French\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: ENGLISHREADMEDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Documentation\English\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: ADDITIONSDIRECTORY , Object: C:\Program Files (x86)\Microsoft Virtual PC\Virtual Machine Additions\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: DrWatsonJapaneseFolder , Object: C:\Program Files (x86)\Microsoft Virtual PC\1041\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: DrWatsonSpanishFolder , Object: C:\Program Files (x86)\Microsoft Virtual PC\3082\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: DrWatsonEnglishFolder , Object: C:\Program Files (x86)\Microsoft Virtual PC\1033\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: DrWatsonGermanFolder , Object: C:\Program Files (x86)\Microsoft Virtual PC\1031\ MSI (c) (2C:B0) [14:49:08:085]: Dir (target): Key: DrWatsonFrenchFolder , Object: C:\Program Files (x86)\Microsoft Virtual PC\1036\ MSI (c) (2C:B0) [14:49:08:085]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'. MSI (c) (2C:B0) [14:49:08:085]: Note: 1: 2205 2: 3: MsiAssembly MSI (c) (2C:B0) [14:49:08:085]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ? Action ended 14:49:08: CostFinalize. Return value 1. MSI (c) (2C:B0) [14:49:08:086]: Doing action: InstallWelcomeDialog Action 14:49:08: InstallWelcomeDialog. Action start 14:49:08: InstallWelcomeDialog. Info 2898. For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set, of 16 pixels height. Info 2898. For MSSansBold8 textstyle, the system created a 'MS Shell Dlg' font, in 0 character set, of 16 pixels height. Action 14:49:08: InstallWelcomeDialog. Dialog created MSI (c) (2C:48) [14:49:08:100]: Note: 1: 2205 2: 3: _RemoveFilePath MSI (c) (2C:48) [14:49:08:102]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'. MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2205 2: 3: BindImage MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2205 2: 3: ProgId MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2205 2: 3: PublishComponent MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2205 2: 3: SelfReg MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2205 2: 3: Extension MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2205 2: 3: Font MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2205 2: 3: Class MSI (c) (2C:48) [14:49:08:104]: Note: 1: 2727 2: MSI (c) (2C:A4) [14:49:08:879]: Doing action: CA_CheckIfWeCanInstall Action 14:49:08: CA_CheckIfWeCanInstall. Determining if the installation can continue... Action start 14:49:08: CA_CheckIfWeCanInstall. MSI (c) (2C:38) [14:49:08:882]: Invoking remote custom action. DLL: C:\Users\CUBBAV~1\AppData\Local\Temp\MSI8352.tmp, Entrypoint: CheckIfWeCanInstall Action ended 14:49:08: CA_CheckIfWeCanInstall. Return value 1. Action ended 14:49:08: InstallWelcomeDialog. Return value 1. MSI (c) (2C:B0) [14:49:08:894]: Skipping action: ErrorAdminPrivilegeDialog (condition is false) MSI (c) (2C:B0) [14:49:08:894]: Skipping action: ErrorMustUninstallDialog (condition is false) MSI (c) (2C:B0) [14:49:08:894]: Skipping action: ErrorMustUninstallTrialDialog (condition is false) MSI (c) (2C:B0) [14:49:08:894]: Skipping action: ErrorMustUninstallVPC52Dialog (condition is false) MSI (c) (2C:B0) [14:49:08:894]: Skipping action: ErrorMustUninstallVSPreviewDialog (condition is false) MSI (c) (2C:B0) [14:49:08:894]: Skipping action: ErrorUnsupportedOSDialog (condition is false) MSI (c) (2C:B0) [14:49:08:894]: Skipping action: WarningUnsupportedInstallationDialog (condition is false) MSI (c) (2C:B0) [14:49:08:894]: Doing action: LicenseAgreementDialog Action 14:49:08: LicenseAgreementDialog. Action start 14:49:08: LicenseAgreementDialog. Action 14:49:08: LicenseAgreementDialog. Dialog created MSI (c) (2C:A4) [14:49:09:878]: PROPERTY CHANGE: Modifying AgreeToLicense property. Its current value is 'No'. Its new value: 'Yes'. Action 14:49:10: CustomerInformationDialog. Dialog created MSI (c) (2C:A4) [14:49:11:327]: Doing action: CA_ValidatePID Action 14:49:11: CA_ValidatePID. Validating the product key Action start 14:49:11: CA_ValidatePID. MSI (c) (2C:5C) [14:49:11:330]: Invoking remote custom action. DLL: C:\Users\CUBBAV~1\AppData\Local\Temp\MSI8CE4.tmp, Entrypoint: ValidateProductID MSI (c) (2C:28) [14:49:11:331]: Cloaking enabled. MSI (c) (2C:28) [14:49:11:331]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (2C:28) [14:49:11:331]: Connected to service for CA interface. MSI (c) (2C!50) [14:49:11:525]: PROPERTY CHANGE: Adding CCPTrigger property. Its value is '1'. MSI (c) (2C!50) [14:49:11:525]: PROPERTY CHANGE: Adding PKU property. Its value is '0'. MSI (c) (2C!50) [14:49:11:525]: PROPERTY CHANGE: Adding PIDSEQ property. Its value is '270000000'. MSI (c) (2C!50) [14:49:11:525]: PROPERTY CHANGE: Adding PID property. Its value is '74216-270-8229511-41359'. MSI (c) (2C!50) [14:49:11:525]: PROPERTY CHANGE: Adding ProductID property. Its value is '74216-270-8229511-41359'. MSI (c) (2C!50) [14:49:11:525]: PROPERTY CHANGE: Adding DPID property. Its value is '#xA40000000300000037343231362D3237302D383232393531312D34313335390052000000000000000000000000000000000000001CFA20066AC2474D0FEC44135C76020000000000670EF248AB8D880203000000000000000000000000000000000000000000000033333032340000000000000000000000CAF22C40FF0F00009001000000000000000000000000000000000000000000000000000000000000C809F71A'. MSI (c) (2C!50) [14:49:11:525]: PROPERTY CHANGE: Adding DigitalProductID property. Its value is '#xA40000000300000037343231362D3237302D383232393531312D34313335390052000000000000000000000000000000000000001CFA20066AC2474D0FEC44135C76020000000000670EF248AB8D8802030000000000000000000000000000000000000000000000333330323400 "LeeTutor" wrote: Quote: > > From looking around the internet, I think the VPC 2007 installation log > will be here: > > C:\Users\<your account name>\AppData\Local\Temp\VPCInstallLog.txt > > Can you search for it and see if it exists? > > Also, I wonder if you've tried installing VPC 2007 in safe mode? Or in > normal mode with all your normal startup programs disabled using > MSCONFIG.EXE? > > > -- > LeeTutor > |
| EXCEL 2007 INSTALLATION | .NET General | |||
| VPC 2007 installation | Virtual PC | |||
| Project 2007 trial installation problems | .NET General | |||
| Installation of MS Office 2007 on Vista. | Vista account administration | |||
| Madden 2007 Installation Problems... | Vista Games | |||
