Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Keyboard/Mouse not working, i believe its vmadditions problem?
Old 08-30-2008   #1 (permalink)
kavaman
Hi
Im getting an error there was a problem installing this hardware vm
additions pc/at enhanced ps/2 keyboard. This error started happening on a
gust operating system (winxp) when i had to do a repair installation. I
believe its a vm additions problem , but how do i uninstall / reinstall vm
additions if my keyboard and mouse are not working?
Any help would be very welcome. Thanks alot in advance.
kavaman
Old 08-30-2008   #2 (permalink)
Robert Comer
Re: Keyboard/Mouse not working, i believe its vmadditions problem?
If you can boot into safe mode the keyboard and mouse may work there
and if they do, then open device manager and delete the mouse and then
reboot and see if it changes anything. If not try deleting only the
keyboard. Once you get some input method working, then you just
uninstall the additions and reinstall them.
Bob Comer
On Sat, 30 Au 2008 09:59:00 -0700, kavaman
<kavaman@xxxxxx> wrote:
Quote:
>Hi
>kavaman
Old 08-31-2008   #3 (permalink)
FACE
On Sat, 30 Aug 2008 22:14:18 -0400, in microsoft.public.virtualpc, FACE
<AFaceInTheCrowd@xxxxxx>, wrote
Quote:
>On Sat, 30 Aug 2008 09:59:00 -0700, in microsoft.public.virtualpc,
>kavaman <kavaman@xxxxxx>, wrote
Quote:
>>Hi
>>kavaman
>You don't. If one or the other were unworkable, you could do it, but with
>both unworkable...........you don't.
>Have you checked the settings of the VM?
Stay with me here.........
With the VM running, and from the VPC console, go into settings for the
VM, click on mouse pointer integration, click it to the 'off' state, "OK"
out of settings.
On the running VM -- using the right top radio button on the VM frame,
shut down the VM.
Reboot the VM.
Any difference? IOW, do you now have a pointer that must be captured, but
which then works?
FACE
Quote:
>If the files you want off of the fupped .vhd are application files and are
>important, they are not lost, in any event..............
>FACE
Old 08-31-2008   #4 (permalink)
kavaman
Cannot get into safe mode. It stops at login because i cannot choose which
profile to login. Also the cannot shutdown guest operations system because of
an application failure because i cannot use a mouse to shutdown the
application (its an app that starts on windows startup).
Keyboard does work before booting, because i get to choose which profile i
want to login to windows.
Is there anything i could do to the inf files on command prompt to try to
restore them and get the keyboard and mouse working trough that?
thefan
"FACE" wrote:
Quote:
> On Sat, 30 Aug 2008 22:30:11 -0400, in microsoft.public.virtualpc,
> The worst case situation will be to establish a new VM using the fupped
> vhd as a "D" disk, reinstalling D apps on the new "C" to access the old
> application files on "D".
> (I sure wish that MS VPC 2007 referred to HD0 as HD0 instead of calling it
> Hard Disk 1)
> FACE
Old 08-31-2008   #5 (permalink)
kavaman
Sorry, cant pick up a profile when safe mode logs in ( i have two profiles)
administrator and my other profile. Which means keyboard and mouse do not
work when windows starts on safe mode, but before windows loads they do. I
was hoping i could delete some inf file at command prompt which seems to be
causing the problem?
"FACE" wrote:
Quote:
> Can't say that i understand all of what you wrote but............
> Start the host machine in Safe mode. (hold down f8 as it boots until you
> get the menu screen. Choose safe mode. It will only load essential
> services.
> You can manually start the VM after the host boots. Bring up VPC control
> panel. Disable fullscreen auto if it is on. Start VM machine from there.
> Hold down f8 as it boots. It will not load vm additions. It will not
> load the application. You will need to double click the safe mode dialogue
> box. That will capture the cursor for the VM.
> Go to control panel --> add/remove programs, and uninstall VM additions.
> Reboot and see what you have.
> FACE
> On Sun, 31 Aug 2008 07:46:00 -0700, in microsoft.public.virtualpc,
> >thefan
> >> Hard Disk 1)
> >> FACE
Old 09-01-2008   #6 (permalink)
FACE
A possibility of a "deadly embrace"?
<snip>
Quote:
>(literally cross-use that .vhd between two VMs. I would strongly recommend
>not having them both booted at once though)
<snip>
Has anyone heard of the "deadly embrace"?
It seems there is more possibility of this under MS VPC than other apps,
so how do MS OSes handle write collisions?
FACE
Old 09-01-2008   #7 (permalink)
Steve Jain
Re: A possibility of a "deadly embrace"?
On Mon, 01 Sep 2008 09:13:46 -0400, FACE <AFaceInTheCrowd@xxxxxx>
wrote:
Quote:
><snip>
><snip>
>FACE
You can't use one VHD with 2 VMs simultaneously...unless you've set up
differencing disks. Once the first VM uses the VHD, it is right
protected and a 2nd VM can write to it and most likely will just fail
to boot.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
I do not work for Microsoft.
Old 09-01-2008   #8 (permalink)
kavaman
So basically i can only copy the files out from the f...ed up vhd using it as
a d drive on a working vhd? Is there some way to get the non working vhd back
to working using this method? Can i somehow remove the vmadditions from the
non working vhd this way, if you know what i mean? THANKS!
"Steve Jain" wrote:
> wrote:
Quote:
> ><snip>
> ><snip>
> >FACE
> to boot.
> Cheers,
Old 09-02-2008   #9 (permalink)
Bill Grant
It is really no different from the situation with a physical hard disk
which won't boot. The only way to read it is to somehow boot the the machine
by some other means and then try to read files on the sick disk.
"kavaman" <kavaman@xxxxxx> wrote in message
news:6FC2CAE1-A538-429A-A798-C71A1664D835@xxxxxx
> as
> back
> the
> "Steve Jain" wrote:
>> wrote:
Quote:
>> ><snip>
>> >>recommend
>> ><snip>
>> >FACE
>> to boot.
>> Cheers,
Old 09-02-2008   #10 (permalink)
Bo Berglund
On Tue, 2 Sep 2008 19:50:45 +1000, "Bill Grant" <not.available@xxxxxx>
Except that with WinImage you can open a VHD file and read/extract
files from it onto the host system. Of course the VHD file must not be
in use by a running guest when this is done...
Bo Berglund (Sweden)
Keyboard/mouse not working Drivers
USB mouse and keyboard not working Drivers
USB keyboard and mouse not working Vista hardware & devices
mouse and keyboard not working Vista hardware & devices
Keyboard & Mouse not working. Vista installation & setup
