| | Problem reading the registry Hi, I'm using Microsoft Virtual PC 2007, with Windows 2000 SP4 loaded, to test some software. I need to read the registry from a DLL created from C/C++, but when I run it this happens: RegOpenKeyEx returns a 2, and GetLastError returns 0xb7 - "Cannot create a file when that file already exists." My code is: static HKEY OpenRegistryUser() { **HKEY hKey; **LONG status; **//Open the Registry keys **status = RegOpenKeyEx(HKEY_CURRENT_USER, *****TEXT(RegString), *****0, *****KEY_READ, *****&hKey); **if( status != ERROR_SUCCESS ) **{ *****DWORD lastError = GetLastError(); *****LPVOID lpMsgBuf; *****FormatMessage( *********FORMAT_MESSAGE_ALLOCATE_BUFFER | *********FORMAT_MESSAGE_FROM_SYSTEM | *********FORMAT_MESSAGE_IGNORE_INSERTS, *********NULL, *********lastError, *********MAKELANGID(LANG_NEUTRAL, SUBLANG_DEFAULT), // Default language *********(LPTSTR) &lpMsgBuf, *********0, *********NULL *****); **} **return hKey; } I can run the above-mentioned DLL on a WinXP machine, and the call works. I don't have any development tools installed on my virtual PC, so I can't research the accuracy of the source code. Can anyone tell me what's wrong? Or perhaps provide some source code that runs on a VirtualPC to read a Win2000 registry? Thanks in advance for any help ... B |
| Problem reading registry remotely | PowerShell | |||
| Reading from the registry | VB Script | |||
| Clearing strValue when reading registry. | VB Script | |||
| Remotely reading HKLM registry key | Vista security | |||
| reading/writing registry values | PowerShell | |||
