| | Total fresh virgin newbie question I am just geting my feet wet in virtual machine technology. I just bought a computer with Vista 64 bit installed. I had XP before and ran a software that the creator provides free, is 32 bit, and will not be updated beyond its current version because the creator has a competing commercial product that they sell for an arm. In order to continue using this software, which Vista refuses to install, I thought I'd try VM. If there is a better alternative please inform. From what I have read, a guest OS can communicate with the host through network services. That said, is there a way for me to send instructions from a program running in the host to the guest that will initiate running a program installed on the guest? If so, can someone point me to documentation that explains this technology. |
| | Re: Total fresh virgin newbie question "JonWayn" <JonWayn@xxxxxx> wrote in message news:E610F4A1-9FCE-45FF-BBEA-8BCD034861B6@xxxxxx Quote: > In order to continue using this software, which Vista refuses to install, > I thought I'd try VM. install"... How are you trying to install it? Are you running the installation as administrator? What error messages are you getting? Quote: > From what I have read, a guest OS can communicate with the host through > network services. / domain and you should have no problems at all. As you're new to software virtualisation, the most important point to remember is that there is *NO* difference between a physical machine (like your host) and a virtual machine (like your guest) as far as the software running on it is concerned - both are *REAL* machines. When you create your first VM and then install e.g. Windows XP on it, Windows XP will have no the slightest notion that it's being installed on a virtual machine as opposed to a physical machine - it has no need whatsoever to know this. Whenever you encounter an issue with software virtualisation, the question to ask is "How would I do this on a physical machine?" and you will almost always arrive at the answer. Quote: > That said, is there a way for me to send instructions from a program > running in > the host to the guest that will initiate running a program installed on > the guest? opposed to one physical machine and one virtual machine - how would you do it...? You might also find this newsgroup's FAQ useful: http://vpc.visualwin.com/ngfaq.aspx -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | Re: Total fresh virgin newbie question Thanks for the reply. Here is further information pursuant to the questions you asked: Quote: > What error messages are you getting? version of this file is not compatible with the version of Windows you're running. Check your computer system's information to see whether you need an x86 (32 bit) or x64 (64 bit) version of the program and then contact the provider. Or something to that effect. As stated in the opening thread, there is no contacting the provider for this one as they will not support it in any way. Quote: > How are you trying to install it? message pops up I was aware that a VM is not very different from a real computer and no different at all as far as it sees itself. I am not a network savvy person and have never known how a client asks a server to run a program residing on the server. So, that is my main concern here. How do I get the host to signal the guest to start a program? "Mark Rae [MVP]" wrote: Quote: > "JonWayn" <JonWayn@xxxxxx> wrote in message > news:E610F4A1-9FCE-45FF-BBEA-8BCD034861B6@xxxxxx > Quote: > > In order to continue using this software, which Vista refuses to install, > > I thought I'd try VM. > Firstly, can you please clarify what you mean by "which Vista refuses to > install"... > How are you trying to install it? > Are you running the installation as administrator? > What error messages are you getting? > Quote: > > From what I have read, a guest OS can communicate with the host through > > network services. > That's right. Make sure that the host and guest(s) are in the same workgroup > / domain and you should have no problems at all. > > As you're new to software virtualisation, the most important point to > remember is that there is *NO* difference between a physical machine (like > your host) and a virtual machine (like your guest) as far as the software > running on it is concerned - both are *REAL* machines. When you create your > first VM and then install e.g. Windows XP on it, Windows XP will have no the > slightest notion that it's being installed on a virtual machine as opposed > to a physical machine - it has no need whatsoever to know this. Whenever you > encounter an issue with software virtualisation, the question to ask is "How > would I do this on a physical machine?" and you will almost always arrive at > the answer. > Quote: > > That said, is there a way for me to send instructions from a program > > running in > > the host to the guest that will initiate running a program installed on > > the guest? > As above. Supposing you had two physical machines on the same network as > opposed to one physical machine and one virtual machine - how would you do > it...? > > You might also find this newsgroup's FAQ useful: > http://vpc.visualwin.com/ngfaq.aspx > > > -- > Mark Rae > ASP.NET MVP > http://www.markrae.net > > |
| | Re: Total fresh virgin newbie question "JonWayn" <JonWayn@xxxxxx> wrote in message news:6B21C3F0-DDC0-4818-894A-27EAD70C96DA@xxxxxx [please don't top-post] Quote: > Thanks for the reply. Here is further information pursuant to the > questions > you asked: > Quote: >> What error messages are you getting? > version of this file is not compatible with the version of Windows you're > running. Check your computer system's information to see whether you need > an > x86 (32 bit) or x64 (64 bit) version of the program and then contact the > provider. install the app - in fact, it's the app's installer that is refusing to install itself on your version of Vista. That may sound pedantic, but the two scenarios are not the same thing at all... Quote: Quote: >> How are you trying to install it? > message pops up Administrator? Quote: > I was aware that a VM is not very different from a real computer is made of software and not hardware is completely irrelevant. Quote: > I am not a network savvy person and have never known how a client asks a > server to > run a program residing on the server. So, that is my main concern here. > How do I get > the host to signal the guest to start a program? physical machine to start a program on another physical machine - nothing to do with Virtual PC per se. How you will *actually* go about doing this will depend on what the remote process is, whether it provides any sort of interface for remote launch, whether it runs as a service etc... E.g. if SQL Server stops running on a remote server, it's possible for an administrator to start it up again remotely - but only because SQL Server provides a mechanism for this sort of remote control... -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | Re: Total fresh virgin newbie question On 15/09/2008 in message <6B21C3F0-DDC0-4818-894A-27EAD70C96DA@xxxxxx> JonWayn wrote: Quote: Quote: >>What error messages are you getting? >version of this file is not compatible with the version of Windows you're >running. Check your computer system's information to see whether you need >an >x86 (32 bit) or x64 (64 bit) version of the program and then contact the >provider. 16 bit installers so they won't install on XP x64. Do you want to install this app on the main PC or the virtual PC? -- Jeff Gaines Damerham Hampshire UK There are 3 types of people in this world. Those who can count, and those who can't. |
| | #6 (permalink) |
| | Re: Total fresh virgin newbie question I'd love if I could install it on the main PC. The only reason the whole idea of the VPC came up was this program. "Jeff Gaines" wrote: Quote: > On 15/09/2008 in message > <6B21C3F0-DDC0-4818-894A-27EAD70C96DA@xxxxxx> JonWayn wrote: > Quote: Quote: > >>What error messages are you getting? > >version of this file is not compatible with the version of Windows you're > >running. Check your computer system's information to see whether you need > >an > >x86 (32 bit) or x64 (64 bit) version of the program and then contact the > >provider. > I wonder if it has a 16 bit installer, I have a couple of 32 bit apps with > 16 bit installers so they won't install on XP x64. > > Do you want to install this app on the main PC or the virtual PC? > > -- > Jeff Gaines Damerham Hampshire UK > There are 3 types of people in this world. Those who can count, and those > who can't. > |
| | #7 (permalink) |
| | Re: Total fresh virgin newbie question The whole time I had been logged on as an administrator. I am the only user of the computer and my default account is administrative in nature. So, when AutoPlay fails or I close its dialog, I open the CD image and double-click the Setup file. There are only a few files and setup is the only logical one that performs the installation process. However, I just get the same message described earlier. I doubt this little program provides any specific mechanism to be controlled or launched remotely. A little more details than I gave before: I run a number of MSAccess databases. Each database, after doing her magic with the data contained, exports the data to a text file and then uses Shell or ShellExecute to launch this program that we are talking about, then from Access, I detect the presence of the new window with API calls and use its menu system to get the window to act on the exported file. Of course, that was the scenario before I got Vista. So, basically, all I have is the path to this program's executable. It takes no arguments. Armed with just that, is there a way to send a file's path from one computer to another on the same network? Actually, if you could tell me how to send any old piece of information over a network, I should be able to figure out from there how to detect the presence of it on the receiving computer and do what I need to do upon its arrival. Thanks "Mark Rae [MVP]" wrote: Quote: > "JonWayn" <JonWayn@xxxxxx> wrote in message > news:6B21C3F0-DDC0-4818-894A-27EAD70C96DA@xxxxxx > > [please don't top-post] > Quote: > > Thanks for the reply. Here is further information pursuant to the > > questions > > you asked: > > Quote: > >> What error messages are you getting? > > version of this file is not compatible with the version of Windows you're > > running. Check your computer system's information to see whether you need > > an > > x86 (32 bit) or x64 (64 bit) version of the program and then contact the > > provider. > Ah, but that's not what you reported! You said that Vista was refusing to > install the app - in fact, it's the app's installer that is refusing to > install itself on your version of Vista. That may sound pedantic, but the > two scenarios are not the same thing at all... > Quote: Quote: > >> How are you trying to install it? > > message pops up > So what happens when you cancel AutoPlay and try to install the app as > Administrator? > Quote: > > I was aware that a VM is not very different from a real computer > A VM *IS* a real computer - this is absolutely fundamental. The fact that it > is made of software and not hardware is completely irrelevant. > Quote: > > I am not a network savvy person and have never known how a client asks a > > server to > > run a program residing on the server. So, that is my main concern here. > > How do I get > > the host to signal the guest to start a program? > Again, without wishing to be dismissive, the same way as you would get one > physical machine to start a program on another physical machine - nothing to > do with Virtual PC per se. How you will *actually* go about doing this will > depend on what the remote process is, whether it provides any sort of > interface for remote launch, whether it runs as a service etc... E.g. if SQL > Server stops running on a remote server, it's possible for an administrator > to start it up again remotely - but only because SQL Server provides a > mechanism for this sort of remote control... > > > -- > Mark Rae > ASP.NET MVP > http://www.markrae.net > > |
| | #8 (permalink) |
| | Re: Total fresh virgin newbie question On Mon, 15 Sep 2008 10:38:07 -0700, in microsoft.public.virtualpc, JonWayn <JonWayn@xxxxxx>, wrote Quote: >I doubt this little program provides any specific mechanism to be controlled >or launched remotely. A little more details than I gave before: I run a >number of MSAccess databases. Each database, after doing her magic with the >data contained, exports the data to a text file and then uses Shell or >ShellExecute to launch this program that we are talking about, then from >Access, I detect the presence of the new window with API calls and use its >menu system to get the window to act on the exported file. Of course, that >was the scenario before I got Vista. So, basically, all I have is the path to >this program's executable. It takes no arguments. Armed with just that, is >there a way to send a file's path from one computer to another on the same >network? Actually, if you could tell me how to send any old piece of >information over a network, I should be able to figure out from there how to >detect the presence of it on the receiving computer and do what I need to do >upon its arrival. FACE |
| | #9 (permalink) |
| | Re: Total fresh virgin newbie question Normally, with the old program, you open it, select a menu command that brings up the File/Open dialog, navigate that dialog to a file somewhere (the program couldnt care less where), then finally hit some button to gt it to act on that file. At the end it throws a dialog to indicate completion of its action. Throughout its action, which may take seconds or minutes depending on the size of the file it imports, my Access database is periodically sniffing for the completion dialog that this program throws through a form's timer event. That brings me to another issue: is it possible to send API messages across the network and how? To directly answer your question, yes, or I am pretty sure, that the program would be able to read shared folders. However, just for my edification, what is the mechanism for sending bits from one computer to another through the network? As I said earlier, I am a network novice. We all use it everyday just by using the internet but I was never concerned before about the underworkings of data transfer. Now I am "FACE" wrote: Quote: > On Mon, 15 Sep 2008 10:38:07 -0700, in microsoft.public.virtualpc, > JonWayn <JonWayn@xxxxxx>, wrote > Quote: > >I doubt this little program provides any specific mechanism to be controlled > >or launched remotely. A little more details than I gave before: I run a > >number of MSAccess databases. Each database, after doing her magic with the > >data contained, exports the data to a text file and then uses Shell or > >ShellExecute to launch this program that we are talking about, then from > >Access, I detect the presence of the new window with API calls and use its > >menu system to get the window to act on the exported file. Of course, that > >was the scenario before I got Vista. So, basically, all I have is the path to > >this program's executable. It takes no arguments. Armed with just that, is > >there a way to send a file's path from one computer to another on the same > >network? Actually, if you could tell me how to send any old piece of > >information over a network, I should be able to figure out from there how to > >detect the presence of it on the receiving computer and do what I need to do > >upon its arrival. > Can your first program work on shared access drive network files? > > FACE > > |
| | #10 (permalink) |
| | Re: Total fresh virgin newbie question On Mon, 15 Sep 2008 15:01:03 -0700, in microsoft.public.virtualpc, JonWayn <JonWayn@xxxxxx>, wrote Quote: >Normally, with the old program, you open it, select a menu command that >brings up the File/Open dialog, navigate that dialog to a file somewhere (the >program couldnt care less where), then finally hit some button to gt it to >act on that file. At the end it throws a dialog to indicate completion of its >action. Throughout its action, which may take seconds or minutes depending on >the size of the file it imports, my Access database is periodically sniffing >for the completion dialog that this program throws through a form's timer >event. That brings me to another issue: is it possible to send API messages >across the network and how? To directly answer your question, yes, or I am >pretty sure, that the program would be able to read shared folders. However, >just for my edification, what is the mechanism for sending bits from one >computer to another through the network? As I said earlier, I am a network >novice. We all use it everyday just by using the internet but I was never >concerned before about the underworkings of data transfer. Now I am Well I see that you knew exactly what I was getting at -- running both programs in the VM and using a shared folder which would be the location of your MSAccess files. As far as starting the VM and the program, that would be a single click situation with the VM pulled from the VPC console to the desktop and the VM having the program in it's start file. (launched in the VM with the VM.) I have watched the progress of your situation since this morning and am pretty much thinking you will need a remote desktop type application to actually send commands to the VM and remain in the host. I am very light on networking between workgroups myself. I am sure that other's here have experience in that though..... I will say that with the little that I do know that Server may best fit the approach you outline and may be the best vehicle. I admit I wonder why you might not take the approach of bumping the VM from the host desktop and running both programs in the VM with a shared folder of your MSAccess files, though -- it would just be another window............. FACE Quote: > >"FACE" wrote: > Quote: >> On Mon, 15 Sep 2008 10:38:07 -0700, in microsoft.public.virtualpc, >> JonWayn <JonWayn@xxxxxx>, wrote >> Quote: >> >I doubt this little program provides any specific mechanism to be controlled >> >or launched remotely. A little more details than I gave before: I run a >> >number of MSAccess databases. Each database, after doing her magic with the >> >data contained, exports the data to a text file and then uses Shell or >> >ShellExecute to launch this program that we are talking about, then from >> >Access, I detect the presence of the new window with API calls and use its >> >menu system to get the window to act on the exported file. Of course, that >> >was the scenario before I got Vista. So, basically, all I have is the path to >> >this program's executable. It takes no arguments. Armed with just that, is >> >there a way to send a file's path from one computer to another on the same >> >network? Actually, if you could tell me how to send any old piece of >> >information over a network, I should be able to figure out from there how to >> >detect the presence of it on the receiving computer and do what I need to do >> >upon its arrival. >> Can your first program work on shared access drive network files? >> >> FACE >> >> |
| I am a total newbie and confused | Media Center | |||
| newbie question | Virtual PC | |||
| Upgrading RAM in laptop, quick question about the RAM size/total, etc... | General Discussion | |||
| Total Newbie: mail problem | Live Mail | |||
| Total Novice-Question Regarding Sharing Wireless Internet | Vista networking & sharing | |||
