Quote:
> I have a freshly setup Virtual PC running XP Pro.
> Setup of the Virtual PC and subsequent installation of XP Pro and all
> updates proceeded without any errors however I have a very annoying problem.
> The Virtual PC seems unable to remember the selected screen resolution
> (currently 1600 = x 1024). Everytime I start my VPC the screen resolution is
> reset to 640 x 480.
> How can I fix this ???
I have the same problem. Using Vista, I have Virtual PC with XP pro installed. Everytime I restart the Virtual XP, it changes the resolution back to 640X480. I tried to update drivers but it said I already have the best drivers installed. Did anyone find a solution to this? My long standing support of Microsoft is slowly wearing down.
Posted via
http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop -
http://www.bitshop.com
