| | Vista Home Premium, VPC2007, Network problems Hi I would welcome some advice please. I have been happily running a VA LAMP server on VPC 2007 on Windows XP Home for web development for some time. I have just bought a Dell Inspiron with Vista Home Premium and want to get the set-up working again, but have had constant network related problems. The LAMP server when starting up would not see the network so I could not connect to it, and ifconfig showed that eth0 couldn't see the network. Anyway back on to Windows stuff. I decided to run up a Windows XP image and again had the same problems... it couldn't see the network. An ipconfig showed that it hasn't picked up an ipaddress and an ipconfig /renew timed out. I then decided to try using Vmware, which had some success and then the images developed the same problems. I have Kaspersky firewall and anti virus and I've tried disabling that which makes no difference. I've run Virtual PC as an Administrator again to no avail. So it seems to be to do with Vista or VPC. What am I missing? Thanks for any help. Dave |
| | Re: Vista Home Premium, VPC2007, Network problems On Sat, 20 Sep 2008 14:00:53 -0700 (PDT), kwaka <david.slater2@xxxxxx> wrote: Quote: >I have been happily running a VA LAMP server on VPC 2007 on Windows XP >Home for web development for some time. Quote: >I have just bought a Dell Inspiron with Vista Home Premium and want to >get the set-up working again, but have had constant network related >problems. - Install VPC2007 on the new laptop? - Copy the vhd file over from the old host PC? - Create a new guest in the new laptop and point it to the copied vhd file? - Set the guest networking to use the host's network adapter? Quote: >The LAMP server when starting up would not see the network so I could >not connect to it, and ifconfig showed that eth0 couldn't see the >network. Anyway back on to Windows stuff. I decided to run up a >Windows XP image and again had the same problems... it couldn't see >the network. An ipconfig showed that it hasn't picked up an ipaddress >and an ipconfig /renew timed out. to make valid advice. There could be several items: - You have not set the new guest to use the host's NIC - The network drivers on the new laptop are not up-to-date By the way, what version of Vista are you using on the host laptop? (x64 or x86). And how is the host PC getting its network config? From a *wired* LAN behind a DSL router/dhcp server???? If you use WiFi, then this might be the root cause of your problem.... Quote: >I then decided to try using Vmware, which had some success and then >the images developed the same problems. > >I have Kaspersky firewall and anti virus and I've tried disabling that >which makes no difference. >I've run Virtual PC as an Administrator again to no avail. Quote: >So it seems to be to do with Vista or VPC. >What am I missing? They are known to be causing connectivity problems if they are not the absolute most recent ones. And if you use WiFi, try switching to wired Ethernet instead. -- Bo Berglund (Sweden) |
| | Re: Vista Home Premium, VPC2007, Network problems On Sep 20, 11:10*pm, Bo Berglund <bobergl...@xxxxxx> wrote: <snip> Quote: > > I think that you need updated network drivers for your new laptop. > They are known to be causing connectivity problems if they are not the > absolute most recent ones. > And if you use WiFi, try switching to wired Ethernet instead. > > -- > > Bo Berglund (Sweden) After reading your response it dawned on me what the problems was and I'm afraid to say that it was user error! ;-) In the network settings for the VPC it had defaulted to the wired NIC. For some reason I had assumed that this was the emulation for the guest OS in the VPC! I do use a wireless connection and normally disable the wired NIC so previously it had defaulted to the wireless one and just worked. Anyway it's all great now. Thanks for the input much appreciated. |
| Problems printing to a network Vista home premium computer | Vista print fax & scan | |||
| Network Problem After installing VPC2007 On Vista x64 | Virtual PC | |||
| Can Vista Home Premium network with Win 98? | Vista networking & sharing | |||
| Can I network Windows Vista Home Premium onto a Workgroup network? | Vista networking & sharing | |||
| Vista Home premium home network with XP using workgroup (no domain | Vista networking & sharing | |||
