| | How to create a virtual lan Hey guys, I am using virtual PC 2007 on a Windows XP machine. The XP machine has one network adapter. Let's assume the host IP is 192.168.1.1 I want to create two virtual pc's running windows server 2008. I will set the first server IP to 10.10.1.1 and the second server IP to 10.10.1.2 I want the two servers to be able to see each other on their subnet. How do I do this? Thanks, Larry |
| | Re: How to create a virtual lan Hey, one way would be setting network settings on both VPCs to local only, in this way both VPCs will see each other ... Marek Quote: > Hey guys, > > I am using virtual PC 2007 on a Windows XP machine. > > The XP machine has one network adapter. Let's assume the host IP is > 192.168.1.1 > > I want to create two virtual pc's running windows server 2008. I will > set the first server IP to 10.10.1.1 and the second server IP to 10.10.1.2 > > I want the two servers to be able to see each other on their subnet. > > How do I do this? > > Thanks, > Larry |
| | Re: How to create a virtual lan On Mon, 22 Sep 2008 15:00:15 -0400, "Larry" <horsemenl@xxxxxx> wrote: Quote: >Hey guys, > >I am using virtual PC 2007 on a Windows XP machine. > >The XP machine has one network adapter. Let's assume the host IP is >192.168.1.1 > >I want to create two virtual pc's running windows server 2008. I will set >the first server IP to 10.10.1.1 and the second server IP to 10.10.1.2 > >I want the two servers to be able to see each other on their subnet. > >How do I do this? enable one NIC and set it to "Local Only". Then after starting up each guest inside the guest itself set the network card TCP/IP properties to a fixed address (use the ones above for instance). Now the two guests will be able to communicate with each other but not to the host or to the physical network or the Internet. -- Bo Berglund (Sweden) |
| | Re: How to create a virtual lan On Mon, 22 Sep 2008 15:30:39 -0400, "Larry" <horsemenl@xxxxxx> wrote: Quote: >Thanks. Let's complicate things now. > >What if I wanted to be able to hit the internet from both servers to do >updates? > >Larry > running Linux, Windows Server with RRAS, etc. VPC does not offer any virtual routing/virtual LAN capability on its own. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ I do not work for Microsoft. |
| Virtual PC 2007 - Create New Virtual Machine | Tutorials | |||
| create a virtual drive with subst | Vista file management | |||
| Create Virtual Direcotry on Remote IIS using PowerShell | PowerShell | |||
| How do I create virtual folders? | Vista General | |||
| Can you create more Virtual Folders ?? | Vista General | |||
