| Guest | Vista and Virtual Machine Additions I recently created a Vista Business Edition VPC and cannot get the Virtual Machine Additions to install properly. Though I can get the higher screen resolutions, cursor integration, and whatever other additions that allow the thing to not run like a complete dog, I cannot get the clipboard integration or shared folder functionality to work. Poking around I noticed that the following services weren't started though they're set to automatic: Virtual Machine Additions Services Application Virtual Machine Additions Shared Folder Service Attempting to start either service results in the following error message: "Windows could not start the [service name] service on the Local Computer. Error 1068: The dependency service or group failed to start." Checking on the dependencies for each service I found that the 1st relies on Virtual Machine Additions Services Driver. The 2nd relies on Virtual Machine Additions Folder Sharing Driver and Virtual Machine Additions Services Driver. I've searched Google and MSDN and can't find anything at all related to this. I've tried installing the VMA right after creating the VPC and also after I've updated it with every update Vista update to no avail. If anyone has run into this and solved it, I'd appreciate any assistance you can give. Thank you. |
| Guest | Re: Vista and Virtual Machine Additions So I take it since no one has responded in two months, that no one has ever encountered this issue? I've tried to make several Vista VPCs and in each and every case I've run into this issue. Has anyone made a VPC with Vista? Has anyone had trouble with the VMAs? I'm using Virtual PC 2007 SP1. On Sep 24, 10:16*am, Vandaveer <vandav...@xxxxxx> wrote: Quote: > I recently created a Vista Business Edition VPC and cannot get theVirtualMachineAdditionsto install properly. Though I can get the > higher screen resolutions, cursor integration, and whatever otheradditionsthat allow the thing tonotrun like a complete dog, I > cannot get the clipboard integration or shared folder functionality to > work. Poking around I noticed that the followingservicesweren't > started though they're set to automatic: > > VirtualMachineAdditionsServicesApplicationVirtualMachineAdditionsShared Folder Service > > Attempting tostarteither service results in the following error > message: > > "Windowscouldnotstartthe [service name] service on the Local > Computer. > > Error 1068: The dependency service or group failed tostart." > > Checking on the dependencies for each service I found that the 1st > relies onVirtualMachineAdditionsServicesDriver. The 2nd relies onVirtualMachineAdditionsFolder Sharing Driver andVirtualMachineAdditionsServicesDriver. > > I've searched Google and MSDN and can't find anything at all related > to this. I've tried installing the VMA right after creating the VPC > and also after I've updated it with every update Vista update to no > avail. > > If anyone has run into this and solved it, I'd appreciate any > assistance you can give. Thank you. |
| Guest | Re: Vista and Virtual Machine Additions On Fri, 14 Nov 2008 11:27:54 -0800 (PST), Vandaveer <vandaveer@xxxxxx> wrote: Quote: >So I take it since no one has responded in two months, that no one has >ever encountered this issue? Quote: > I've tried to make several Vista VPCs and >in each and every case I've run into this issue. Has anyone made a VPC >with Vista? Quote: >Has anyone had trouble with the VMAs? I'm using Virtual PC >2007 SP1. where is your Vista media from? Retail, MSDN, OEM, etc? -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| Virtual PC 2007 - Install Virtual Machine Additions | Tutorials | |||
| VPC 2007 SP1 - Virtual Machine Additions crashes | Virtual PC | |||
| Install Virtual Machine Additions | Virtual PC | |||
| How to install Virtual Machine Additions before OS loaded | Virtual Server | |||
| Uninstalling Virtual Machine Additions | Vista General | |||
