| | "Not running on supported OS" It's been a while since I ran on VPC, and when I start now, I get a pane saying "You are not running on a supported Operating System". I don't recall getting that warning earlier this year. I'm running Windows 98 as a VPC, under Windows XP Home/SP2. What is it trying to tell me? Where do I find the "Microsoft Virtual PC Help" that it refers me to? Thank you. |
| | Re: "Not running on supported OS" William B. Lurie wrote: Quote: > It's been a while since I ran on VPC, and when I start > now, I get a pane saying "You are not running on a > supported Operating System". I don't recall getting > that warning earlier this year. I'm running Windows 98 > as a VPC, under Windows XP Home/SP2. What is it trying > to tell me? Quote: > > Where do I find the "Microsoft Virtual PC Help" that > it refers me to? > > Thank you. |
| | Re: "Not running on supported OS" "William B. Lurie" <billurie@xxxxxx> wrote in message news:%23od7e3IIJHA.4896@xxxxxx Quote: > What is it trying to tell me? host OS. The supported host OS for VPC 2007 are Vista Ultimate, Vista Enterprise, Vista Business, Windows Server 2003 Standard x64 Edition, XP Professional, XP Tablet PC Edition. XP Home is not a supported host OS. However, all this means is that it isn't supported - it will still work... Quote: > Where do I find the "Microsoft Virtual PC Help" that it refers me to? -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | Re: "Not running on supported OS" "David Sanders" <news@xxxxxx> wrote in message news:%23$FqL5JIJHA.3668@xxxxxx Quote: Quote: >> What is it trying to tell me? > SP3? -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | Re: "Not running on supported OS" Mark Rae [MVP] wrote: Quote: > "David Sanders" <news@xxxxxx> wrote in message > news:%23$FqL5JIJHA.3668@xxxxxx > Quote: Quote: >>> What is it trying to tell me? >> SP3? > Nothing to do with the service pack - XP Home is not a supported host OS... > > Gary helped me update 98 in the VPC, I never got that message. If I did, I'd have asked about it then. I wonder why it's warning me now. Oh, well.....it does work. |
| | #6 (permalink) |
| | Re: "Not running on supported OS" "William B. Lurie" <billurie@xxxxxx> wrote in message news:udG9X9LIJHA.4408@xxxxxx Quote: Quote: Quote: >>>> What is it trying to tell me? >>> >>> SP3? >> Nothing to do with the service pack - XP Home is not a supported host >> OS... >> > Gary helped me update 98 in the VPC, I never got that > message. If I did, I'd have asked about it then. I > wonder why it's warning me now. Oh, well.....it does > work. thing... A host is an operating system on which Virtual PC is installed. A guest is an operating system running in a virtual machine. XP Home and Windows 98 are supported *guests* - they are not supported *hosts*... Open up the help file and have a look at the topic entitled "Evaluating requirements". -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #7 (permalink) |
| | Re: "Not running on supported OS" Mark Rae [MVP] wrote: Quote: > Seems like you're confusing hosts and guests - they are not the same > thing... > > A host is an operating system on which Virtual PC is installed. > > A guest is an operating system running in a virtual machine. > > XP Home and Windows 98 are supported *guests* - they are not supported > *hosts*... > > Open up the help file and have a look at the topic entitled "Evaluating > requirements". He *is* talking about the host. Maybe he was warned when he first installed VPC on XP Home, but his recollection is that he was not previously warned every time he started it. But now he is. -- David Wilkinson Visual C++ MVP |
| | #8 (permalink) |
| | Re: "Not running on supported OS" David Wilkinson wrote: Quote: > Mark Rae [MVP] wrote: Quote: >> Seems like you're confusing hosts and guests - they are not the same >> thing... >> >> A host is an operating system on which Virtual PC is installed. >> >> A guest is an operating system running in a virtual machine. >> >> XP Home and Windows 98 are supported *guests* - they are not supported >> *hosts*... >> >> Open up the help file and have a look at the topic entitled >> "Evaluating requirements". > Mark: > > He *is* talking about the host. Maybe he was warned when he first > installed VPC on XP Home, but his recollection is that he was not > previously warned every time he started it. But now he is. > at all. But it works on my XP/Home, so I'll just continue to ignore it. It don't seem to be broke, so it don't need no fixin'. |
| | #9 (permalink) |
| | Re: "Not running on supported OS" "David Wilkinson" <no-reply@xxxxxx> wrote in message news:uzrQbQMIJHA.1156@xxxxxx Quote: > He *is* talking about the host. Maybe he was warned when he first > installed VPC on XP Home, but his recollection is that he was not > previously warned every time he started it. But now he is. -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | #10 (permalink) |
| | RE: "Not running on supported OS" Don't mind, if the product works on your OS. You just should understand, that in such context "supported" means, that developer *guarantee*, that product works on listed platforms; but "compatible" usually lists strict list of compatible platforms (where the product can work) regardless supported platforms. "William B. Lurie" wrote: Quote: > It's been a while since I ran on VPC, and when I start > now, I get a pane saying "You are not running on a > supported Operating System". I don't recall getting > that warning earlier this year. I'm running Windows 98 > as a VPC, under Windows XP Home/SP2. What is it trying > to tell me? > > Where do I find the "Microsoft Virtual PC Help" that > it refers me to? > > Thank you. > |
| do not display "ERRORS" when running script without using $erroractionpreference = "SilentlyContinue" | PowerShell | |||
| "Not running on supported OS" on Vista?? | Virtual PC | |||
| Error on return from function call in ASP.NET "Operation is not supported on this platform." | .NET General | |||
| "Setup is unable to detect a supported product on your system." | Sound & Audio | |||
| "No such interface supported" error in Slide Show Gadget | Vista General | |||
