| | RE: Virtual PC will not respond to RightAlt-Delete... Quote: > Hi all, i am having a problem with a Virtual PC Machine. this Machine has > been used for some time. The Virtual Machine (appears) to boot up fine, > until it gets to the Ctrl-Alt-Del screen. At this point, it jsut sits > there... it will not respond to RightAlt-Delete, the mouse, enter... nothing. > it will go to full screen mode and back on a RightAlt-Enter, but other than > that, it does nothing... > > Has anybody ever ran into this and now a solution? > > thanks > Gary instead of pressing 'ctrl+alt+del' just press 'right alt+del' Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com |
| | Virtual PC will not respond to RightAlt-Delete... Have you changed your host key? If you open the Virtual PC Console and select Options from the File menu you'll open the Virtual PC Options window. In the left windows you should see the Keyboard option. The Host key should be listed beside it. If it's not Right Alt then you've changed it. To change it back, click on the Keyboard option, and then click in the host key window and press the Right Alt key. "Felix" <felix152s@xxxxxx> wrote in message news:eea68b0b-3a7a-4ad8-89a4-8fccc454147d@xxxxxx Quote: > Quote: >> Hi all, i am having a problem with a Virtual PC Machine. this Machine >> has >> been used for some time. The Virtual Machine (appears) to boot up fine, >> until it gets to the Ctrl-Alt-Del screen. At this point, it jsut sits >> there... it will not respond to RightAlt-Delete, the mouse, enter... >> nothing. >> it will go to full screen mode and back on a RightAlt-Enter, but other >> than >> that, it does nothing... >> >> Has anybody ever ran into this and now a solution? >> >> thanks >> Gary > SOLUTION > > > instead of pressing 'ctrl+alt+del' just press 'right alt+del' > > Posted via http://www.VirtualServerFaq.com - Brought to you by Business > Information Technology Shop - http://www.bitshop.com |
| Not respond | Vista General | |||
| How To: Windows Performance Monitor Virtual Switch Port instance IDto Virtual NIC or VM | Virtual Server | |||
| the following url don't respond | Vista performance & maintenance | |||
| I'll ask again, please respond ! | Vista performance & maintenance | |||
| RightAlt+s shortcut hijacked by HP | Vista General | |||
