Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Problem : Reboot of Physical PC
Old 10-10-2008   #1 (permalink)
Sam Vimaire
Hello
VirtualPC 2007 on Windows XP SP3.
I am trying to install Windows XP SP2 on a virtual machine.
The physical computer *always* reboots during the "Windows XP Prepare for Installation"
(This may not be the exact sentence for English OS !)
I think the problem occurs when loading the drivers in memory.
Any Idea ?
Thanks.
Sam Vimaire <sam.vimaire@xxxxxx-morpork.com>
Old 10-10-2008   #2 (permalink)
Steve Jain [MVP]
Re: Problem : Reboot of Physical PC
On Fri, 10 Oct 2008 11:22:52 +0200, Sam Vimaire
<sam.vimaire@xxxxxx-morpork.com> wrote:
Quote:
>Hello
>Any Idea ?
>Thanks.
Probably either a BIOS issue or a driver issue.
If you have hardware virtualization turned on, turn it off on VPC and
see if you can install then. If so, then you need to update your
BIOS.
Next, you could try updating your NIC drivers.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
installed physical memory vs total physical memory General Discussion
sp2 reboot problem Windows Updates
Vista 64 Installed Physical Memory vs Total Physical Memory Vista General
Installed Physical Memory/Total Physical Memory Vista installation & setup
Reboot problem Vista General
