| | problem in connecting two virtual machines for local network only HI, I have Win xp professional sp3 as my host OS, have one lan card with static IP from ISP I have created two virtual machines in Microsoft VPC 2007. First virtual machine runs Win xp sp2 with only one network adapter 'local only' (in virtual machine networking settings) and have IP 192.168.1.21 Second virtual machine runs Windows Server 2003 with only one network adapter 'local only' (in virtual machine networking settings) and have IP 192.168.1.20 Now the problem is while running both virtual machines simultaneously I can ping from my XP machine to Server machine and also able to take a remote connection. But when I try to ping from Server machine to XP machine I get error request time out and also can not connect using remote desktop. |
| | Re: problem in connecting two virtual machines for local network only That sounds like a firewall problem. If you can ping one way, your network setup is correct. The ping request can travel from one machine to the other and the pin reply can travel from the target machine back to the original requesting machine. "amitsgokhale" <amitsgokhale@xxxxxx> wrote in message news:0A8FFC98-7C15-4E0F-8716-9F56263E716D@xxxxxx Quote: > HI, > I have Win xp professional sp3 as my host OS, have one lan card with > static > IP from ISP > > I have created two virtual machines in Microsoft VPC 2007. > > First virtual machine runs Win xp sp2 with only one network adapter 'local > only' (in virtual machine networking settings) and have IP 192.168.1.21 > Second virtual machine runs Windows Server 2003 with only one network > adapter 'local only' (in virtual machine networking settings) and have IP > 192.168.1.20 > > Now the problem is while running both virtual machines simultaneously I > can > ping from my XP machine to Server machine and also able to take a remote > connection. But when I try to ping from Server machine to XP machine I get > error request time out and also can not connect using remote desktop. |
| | Re: problem in connecting two virtual machines for local network only On Fri, 17 Oct 2008 05:43:01 -0700, amitsgokhale <amitsgokhale@xxxxxx> wrote: Quote: >HI, >I have Win xp professional sp3 as my host OS, have one lan card with static >IP from ISP > >I have created two virtual machines in Microsoft VPC 2007. > >First virtual machine runs Win xp sp2 with only one network adapter 'local >only' (in virtual machine networking settings) and have IP 192.168.1.21 >Second virtual machine runs Windows Server 2003 with only one network >adapter 'local only' (in virtual machine networking settings) and have IP >192.168.1.20 > >Now the problem is while running both virtual machines simultaneously I can >ping from my XP machine to Server machine and also able to take a remote >connection. But when I try to ping from Server machine to XP machine I get >error request time out and also can not connect using remote desktop. default behaviour from SP2 onwards. You need to change the setting for the firewall to allow ping (and also the other protocols you want to use between the two machines). In fact, since both are on local only it seems like there is no need for a firewall at all, there is no outside connection to worry about. So you can disable the firewall altogether on the XP machine. -- Bo Berglund (Sweden) |
| | Re: problem in connecting two virtual machines for local network o Thanks for reply. The solution worked. "Bo Berglund" wrote: Quote: > On Fri, 17 Oct 2008 05:43:01 -0700, amitsgokhale > <amitsgokhale@xxxxxx> wrote: > Quote: > >HI, > >I have Win xp professional sp3 as my host OS, have one lan card with static > >IP from ISP > > > >I have created two virtual machines in Microsoft VPC 2007. > > > >First virtual machine runs Win xp sp2 with only one network adapter 'local > >only' (in virtual machine networking settings) and have IP 192.168.1.21 > >Second virtual machine runs Windows Server 2003 with only one network > >adapter 'local only' (in virtual machine networking settings) and have IP > >192.168.1.20 > > > >Now the problem is while running both virtual machines simultaneously I can > >ping from my XP machine to Server machine and also able to take a remote > >connection. But when I try to ping from Server machine to XP machine I get > >error request time out and also can not connect using remote desktop. > The firewall on the XP machine is blocking ping responses. This is the > default behaviour from SP2 onwards. You need to change the setting for > the firewall to allow ping (and also the other protocols you want to > use between the two machines). > In fact, since both are on local only it seems like there is no need > for a firewall at all, there is no outside connection to worry about. > So you can disable the firewall altogether on the XP machine. > > -- > > Bo Berglund (Sweden) > |
| Managing network adapter availability for virtual machines | Virtual PC | |||
| RE: connecting XP and Win2003 Server Virtual Machines | Virtual PC | |||
| Microsoft Learning - Virtual Machines Problem | Virtual Server | |||
| Vista connecting to webserver on local network | Vista networking & sharing | |||
