Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Re: Networking trouble using RDP to VPC
Old 10-19-2008   #1 (permalink)
Mike Williams
Mike Williams wrote:
Quote:
> Hi,
> I have a VPC guest O/S (Win2k3) which I need to have connect to my
> office using a VPC connection. The VPN connection requires the use of a
> smartcard reader. VPC does not support reading a smartcard reader that
> is plugged into the host computer. The workaround that is commonly cited
> on the Internet is to use a remote desktop connection (mstsc.exe) to log
> into the guest O/S and the USB smartcard is passed through to the guest
> O/S.
> I am able to successfully log into my guest O/S using the Virtual PC
> client and my domain credentials, presumably because the credentials are
> cached. All networking activities work as expected.
> When I try to log into my guest O/S using a Remote Desktop connection
> and my domain credentials, it fails, with the following message:
> The system cannot log you on due to the following error: The specified
> domain either does not exist or could not be contacted.
> and local administrator credentials, I am able to successfully log in.
> However, I cannot access any Internet resources (no Google, MSN, etc.).
> I am able to ping them.
> What's really weird, is that if I have logged into the guest O/S, using
> the Virtual PC console and Remote Desktop connection (so I have both
> windows open at the same time), Internet networking works in the Virtual
> PC console connection, but not in the Remote Desktop connection.
> Any ideas on how to fix?
> -Michael
Figured it out and thought I would post in case anyone else has this
trouble. IE was configured to use a proxy server which is required at
work, but not when at home.
-Mike
Old 10-19-2008   #2 (permalink)
Robert Comer
Thanks for posting the answer, I'll remember it, and it'll hang around
for the next guy that has a problem!
Bob Comer
On Sun, 19 Oct 2008 13:24:10 -0700, Mike Williams <abcd@xxxxxx>
wrote:
Quote:
>> Hi,
>> O/S.
>> -Michael
>-Mike
Trouble Networking a Printer Network & Sharing
Trouble w/ VPC-2K7 & Networking Virtual PC
Having trouble with Vista networking in a Domain Vista General
Wireless networking trouble with Vista Vista General
Having trouble networking my 2 PCs Vista networking & sharing
