| | Using QEMM in a virtual machine Hi, all: I have DOS 6.22 and WFWG running in a VM and I wanted to experiment with wringing the last bit of conventional memory out of the configuration by using one of my favorite memory managers of that era, Quarterdeck QEMM 7.5. Has anyone been able to get this to work successfully under VPC? During the optimization part of the install, I get a GPF during the optimization, followed by an invalid opcode fault (06). Although this question is specific to VPC2007, I've tried this under other virtual machine technologies (like Parallels) and QEMM doesn't work there either. What about QEMM do the VMs not like? Does VPC not emulate every type of CPU instruction? Thanks for the info! |
| | Re: Using QEMM in a virtual machine On Sat, 25 Oct 2008 10:31:01 -0700, Rich Cini <Rich Cini@xxxxxx> wrote: Quote: >Hi, all: > > I have DOS 6.22 and WFWG running in a VM and I wanted to experiment with >wringing the last bit of conventional memory out of the configuration by >using one of my favorite memory managers of that era, Quarterdeck QEMM 7.5. >Has anyone been able to get this to work successfully under VPC? During the >optimization part of the install, I get a GPF during the optimization, >followed by an invalid opcode fault (06). > > Although this question is specific to VPC2007, I've tried this under other >virtual machine technologies (like Parallels) and QEMM doesn't work there >either. What about QEMM do the VMs not like? Does VPC not emulate every type >of CPU instruction? means that the host CPU is actually running the code in your virtual machine at full speed during the time slices it gets to use it. Maybe QEMM is not compatible with today's CPU:s??? -- Bo Berglund (Sweden) |
| | Re: Using QEMM in a virtual machine "Bo Berglund" wrote: Quote: > As far as I know the CPU is *not* emulated, it is virtualized. This > means that the host CPU is actually running the code in your virtual > machine at full speed during the time slices it gets to use it. > Maybe QEMM is not compatible with today's CPU:s??? environment. I'm used to real CPU emulation (since I work on cross-platform stuff more frequently). I wonder if something in Intel's virtualization hardware creates a subtle, but incompatible change to some aspect of the instruction set that causes problems for these older programs? I wonder if disabling host CPU virtualization support will change anything? I may also have a closer look at the faulting instruction and see if that provides any clues. Thanks. |
| | Re: Using QEMM in a virtual machine On Sat, 25 Oct 2008 10:31:01 -0700, Rich Cini <Rich Cini@xxxxxx> wrote: Quote: >Hi, all: > > I have DOS 6.22 and WFWG running in a VM and I wanted to experiment with >wringing the last bit of conventional memory out of the configuration by >using one of my favorite memory managers of that era, Quarterdeck QEMM 7.5. >Has anyone been able to get this to work successfully under VPC? During the >optimization part of the install, I get a GPF during the optimization, >followed by an invalid opcode fault (06). > > Although this question is specific to VPC2007, I've tried this under other >virtual machine technologies (like Parallels) and QEMM doesn't work there >either. What about QEMM do the VMs not like? Does VPC not emulate every type >of CPU instruction? > > Thanks for the info! QEMM. I have no idea what they are any more, unfortunately. I'll look through my old CNTX stuff and see if I have a reference anywhere. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| | Re: Using QEMM in a virtual machine "Steve Jain [MVP]" wrote: Quote: > On Sat, 25 Oct 2008 10:31:01 -0700, Rich Cini <Rich > Cini@xxxxxx> wrote: > Quote: > >Hi, all: > > > > I have DOS 6.22 and WFWG running in a VM and I wanted to experiment with > >wringing the last bit of conventional memory out of the configuration by > >using one of my favorite memory managers of that era, Quarterdeck QEMM 7.5. > >Has anyone been able to get this to work successfully under VPC? During the > >optimization part of the install, I get a GPF during the optimization, > >followed by an invalid opcode fault (06). > > > > Although this question is specific to VPC2007, I've tried this under other > >virtual machine technologies (like Parallels) and QEMM doesn't work there > >either. What about QEMM do the VMs not like? Does VPC not emulate every type > >of CPU instruction? > > > > Thanks for the info! > With VPC there are specific address ranges you need to exclude in > QEMM. I have no idea what they are any more, unfortunately. > I'll look through my old CNTX stuff and see if I have a reference > anywhere. > > -- > Cheers, > Steve Jain, Virtual Machine MVP > http://vpc.essjae.com/ Oh, yes, I remember those! I actually found the solution, and it didn't involve manual range excludes (see below). The success of using QEMM depends on the version of QEMM you use. I had been trying to use QEMM 7.5 which clearly didn't work. I found a copy of QEMM8 and that worked perfectly -- no special incantations necessary. The install completed fine, as did the automatic "optimize" function. When it was done, the command line included an aweful lot of include/exclude ranges. I did not try to use QEMM97 (the final version before Quarterdeck Office Systems went bye-bye), but I would imagine that it would work as well. Your comment about the range excludes reminded me of all of the manual tweaking required back then. I remember spending hours trying to squeeze one last driver into the configuration. Ah, those were the days. Regards, Rich |
| | #6 (permalink) |
| | Re: Using QEMM in a virtual machine In message <7A7C74A5-16F6-4283-B99E-BA6B464789C9@xxxxxx> Rich Cini <RichCini@xxxxxx> was claimed to have wrote: Quote: > Your comment about the range excludes reminded me of all of the manual >tweaking required back then. I remember spending hours trying to squeeze one >last driver into the configuration. Ah, those were the days. suspicion that you could get another KB of free memory by reorganizing too, or changing the load order. Whether the fact that kids these days never get to learn that is a blessing or a curse, I don't know. |
| | #7 (permalink) |
| | Re: Using QEMM in a virtual machine "DevilsPGD" wrote: Quote: > Forget one last driver, even then, there was always the nagging > suspicion that you could get another KB of free memory by reorganizing > too, or changing the load order. > > Whether the fact that kids these days never get to learn that is a > blessing or a curse, I don't know. Seriously, this kind of hand optimization turned into an art that is lost on kids these days. Also, having two kids in grammar school, I think there is a big missing opportunity in teaching BASIC. I learned a lot about logical thinking and breaking problems down into smaller and easier parts. Now, don't get me wrong -- the computer classes they take are pretty good, but they are task-oriented classes: how to make graphs using Excel, that kind of stuff. Regards, Rich |
| | #8 (permalink) |
| | Re: Using QEMM in a virtual machine "DevilsPGD" <spam_narf_spam@xxxxxx> wrote in message news:hpf7g4h6l17dg9kektr1rm41qvhh0t0lqg@xxxxxx Quote: > In message <7A7C74A5-16F6-4283-B99E-BA6B464789C9@xxxxxx> Rich > Cini <RichCini@xxxxxx> was claimed to have wrote: > Quote: >> Your comment about the range excludes reminded me of all of the manual >>tweaking required back then. I remember spending hours trying to squeeze >>one >>last driver into the configuration. Ah, those were the days. > Forget one last driver, even then, there was always the nagging > suspicion that you could get another KB of free memory by reorganizing > too, or changing the load order. > > Whether the fact that kids these days never get to learn that is a > blessing or a curse, I don't know. programmers in general) don't know squat about computers in general it seems. I remember Qemm very well, along with Tems and a few others that didn't work so well. That last few versions of Qemm were quite good - the 6.x versions were pure crap. And I remember very well juggling drivers to get the cursed thing to load! I remember having 3 or 4 different boot floppies for different tasks LOL. Ahhh...the good old days. Ask kids these days what extended or expanded memory is. You get blank stares. |
| | #9 (permalink) |
| | Re: Using QEMM in a virtual machine Rich Cini <RichCini@xxxxxx> wrote: Quote: > Your comment about the range excludes reminded me of all of the manual >tweaking required back then. I remember spending hours trying to squeeze one >last driver into the configuration. Ah, those were the days. on it. I wrote an article or two on these for an IBM midrange magazine (IBM AS/400) on this topic back in about 1990 or so. Tony -- Tony Toews, Microsoft Access MVP Please respond only in the newsgroups so that others can read the entire thread of messages. Microsoft Access Links, Hints, Tips & Accounting Systems at http://www.granite.ab.ca/accsmstr.htm Tony's Microsoft Access Blog - http://msmvps.com/blogs/access/ |
| | #10 (permalink) |
| | Re: Using QEMM in a virtual machine In message <C1371B29-2F74-4058-97C4-6B1446749A66@xxxxxx> Rich Cini <RichCini@xxxxxx> was claimed to have wrote: Quote: >Seriously, this kind of hand optimization turned into an art that is lost on >kids these days. (Okay seriously, I was a Much Music fan when I was a kid too, whereas my kids probably haven't watched 30 minutes of MM/MTV in their lives) Quote: >Also, having two kids in grammar school, I think there is a >big missing opportunity in teaching BASIC. I learned a lot about logical >thinking and breaking problems down into smaller and easier parts. Now, don't >get me wrong -- the computer classes they take are pretty good, but they are >task-oriented classes: how to make graphs using Excel, that kind of stuff. forbid kids from going into Tools --> Options and rearranging toolbars or similar personalization. (And yes, said school board does have per-user accounts, and the machines are properly configured so that one kids' changes won't impact the next user of the machine) It's no wonder that when these kids hit the work force they're totally unprepared for anything other then the specific activity which they were taught. |
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 | Virtual Server | |||
| Unable to install Virtual Guest Services on virtual machine | Virtual Server | |||
| RE: Virtual PC could not open the Virtual Machine Network Services driver | Virtual PC | |||
| Moving Virtual Machine from Hyper-v to Virtual Server 2005 | Virtual Server | |||
