Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Network Problem After installing VPC2007 On Vista x64
Old 10-26-2008   #1 (permalink)
ShahinD
Hello
I've recently installed VPC2007 on windows Vista Ultimate SP1.
after each reboot my network adopter on host windows does not work, I should
disable and re-enable network adopter after every reboot to make it work.
I have installed latest driver for network adopter.
Network adopter is Nvidia.
please guide me to resolve this problem.
thanks
Old 10-28-2008   #2 (permalink)
Melelina
Re: Network Problem After installing VPC2007 On Vista x64
"ShahinD" <ShahinD@xxxxxx> wrote in message
news:E61BA4E9-C9C4-4ED9-9EEC-4FF49876AC2A@xxxxxx
Quote:
> Hello
> should
> thanks
Do you have the latest nVidia drivers? I have nVidia network adapter
(nForce4) with no problems with VPC with Vista Ultimate installed. I have
not installed SP1 for Vista but I doubt that would make any difference.
Old 10-30-2008   #3 (permalink)
ShahinD
Yes ,I've installed latest nvidia adopter driver.my mailboard chipset in
nforce 4 AMD
OS: Vista Uptimate x64 SP1
Quote:
> > Hello
> > should
> > thanks
Old 01-10-2009   #4 (permalink)
PaulMoritz
RE: Network Problem After installing VPC2007 On Vista x64
I have a similar problem - after installing VPC 2007 my Host System gets a
BSOD whenever the network is used - it is the same if I use the NIC or Wlan!
I had to uninstall VPC 2007 - is there any solution to this problem?
"FFF" wrote:
Quote:
Quote:
> > Hello
> > thanks
> I have the same problem. How do you fix this?
> Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com
Old 01-10-2009   #5 (permalink)
Bo Berglund
On Sat, 10 Jan 2009 05:30:00 -0800, PaulMoritz
This is most likely a network card driver problem. You should first
make sure that you have the most recent driver for the NIC.
Next, if you have multiple network interfaces (wired and wifi for
instance) you can go into the properties of the wifi NIC and uncheck
"Virtual Machine Network Services". THis will make the wifi card
unavailable for VPC2007 and hence will not interfere with your network
usage on that interface.
Bo Berglund (Sweden)
Internet problem after installing vista 64 bit, Unidentified network, limited/noconne Network & Sharing
Dell E6400 and VPC2007-SP1 latency problem update? Virtual PC
Vista Home Premium, VPC2007, Network problems Virtual PC
VPC2007 Network Issue Virtual PC
sysprep; Vista; VPC2007 Vista installation & setup
